400 block clearancing #2428870
01/04/18 01:54 PM
01/04/18 01:54 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Anyone happen to have any pics of the before/after clearancing needed to install a 4.25 crank in a 400 block. Mainly curious as to how much has to be removed around the oil pickup tube location to see how much material is left to be able to use an internal pickup.
Re: 400 block clearancing [Re: DusterKid] #2428887
01/04/18 02:34 PM
01/04/18 02:34 PM
AndyF Offline
AndyF  Offline
Depends on which rods you use. If you use a 2.200 rod journal and a high quality rod like an Oliver then you might not need to clearance much at all.
Re: 400 block clearancing [Re: AndyF] #2428911
01/04/18 03:13 PM
01/04/18 03:13 PM
iagree scope
With the steel H beam BB Chevy type rod it ain't much, .060 to maybe .120 on a slope up high on the boss sawzall
Re: 400 block clearancing [Re: DusterKid] #2428915
01/04/18 03:19 PM
01/04/18 03:19 PM
Keymar, MD
Keymar, MD
Looking at the 440 source 400-512 kit at the moment. Comes with the 2.200 rod journals.
Re: 400 block clearancing [Re: DusterKid] #2428959
01/04/18 04:42 PM
01/04/18 04:42 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
This might give ya a bit of an idea.
Re: 400 block clearancing [Re: mopar dave] #2428960
01/04/18 04:43 PM
01/04/18 04:43 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
400 block with Molnar 4.250 crank and rods.
Re: 400 block clearancing [Re: DusterKid] #2428989
01/04/18 05:32 PM
01/04/18 05:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
440 source 400/4.250
Re: 400 block clearancing [Re: DusterKid] #2428990
01/04/18 05:35 PM
01/04/18 05:35 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
2
Re: 400 block clearancing [Re: DusterKid] #2429305
01/05/18 02:25 AM
01/05/18 02:25 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
The clearancing is a small amount on the pickup tube boss and that is all. It’s a piece of cake.
I also ran a 1/2 pickup tube. Had to grind the tube just a bit so I don’t recommend a 1/2 pickup
If you’re not gonna rev it that high.
