#2428386 - 01/03/18 02:38 PM Home filtration for lime build up on faucets?
StrokerPost Offline
Loc: Missouri
Since switching from our deep water well to city water we have that white build up (lime?) On all the faucets and shower heads, whats a good home filtration system for lime, or is there? Whats your exeriences and recommendations? Links would be helpful if you have them. Thanks.
Ken
BTW, im talking about a relatively cheap system, such as a filter cartridge system, not a full blown water softener. We have an older Culligan system in the house that worked well, but, something in the control head failed and was going to cost several hundred dollars to fix, so, unless fixing it turns out to be the best option, I'm trying to find something cheaper and smaller.
Edited by StrokerPost (01/03/18 03:04 PM)
67 Dart 2 dr post, 308 iron headed 414 SB. Perf 1/4 mi 10.45 @ 127
5 time Monster Mopar race winner...just sayin!!
#2428541 - 01/03/18 07:36 PM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
moparjim79 Offline
Loc: Central Pa
Sorry, but a filter is not going to solve your problems....it sounds like you have good ol hard water.
#2428653 - 01/03/18 10:23 PM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
Stanton Offline
Loc: Ontario, Canada
A water softener will solve your problem.
#2428791 - 01/04/18 09:08 AM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
DaytonaTurbo Offline
Loc: Manitoba, Canada
If you're switching over to city water, your new water supply shouldn't be that bad? I have that same build-up on some of my faucets because my well water is very hard and the house was run for many years without a softener before I bought it but with city water I think you would be ok.
#2428827 - 01/04/18 09:53 AM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
Charger727 Offline
Loc: Eau Claire, WI
It might be scale coming from your water heater - how old is it? Switching to city water may be higher pressure and now it's flushing the junk out to your faucets
I have scale problems with my old water heater doing the same thing, planning on replacing it soon
#2428859 - 01/04/18 10:30 AM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
Stanton Offline
HA, HA, HA, HA, HA, HA !!!!
Maybe YOUR city water isn't that bad !! Ours is 18 GPG on the hardness scale - which is "right up there". A nearby city is even worse. Any harder and you probably couldn't legally call it water.
OP ... right now you see it on your faucets but its also in your kettles, dish washer, HW tank, etc.. And it will also leave a scale on your shower walls. If you Google "water hardness" for your city you will likely be able to see what the hardness is. This would be necessary to set up a water softener anyway.
As far as removing the visible calcium from faucets, etc, there is a product called CLR that you can wipe or soak the faucets in. Its pretty fast-acting.
#2428939 - 01/04/18 01:03 PM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
herkamer Offline
Loc: Lakewood, Colorado
I went with the Apec reverse osmosis system to get away from bottled drinking water. Took the water from about 160PPM total dissolved solids to 4. I did buy the whole house system for my place, but haven't got it installed yet. As well as it works on drinking water I would imagine the whole house system should work really well.
http://www.freedrinkingwater.com/whole-house-water-filters.htm/
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
#2428969 - 01/04/18 02:04 PM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
wingman Offline
Loc: St. Charles, MO
St. Louis city water is usually between 130 and 180 grains depending on the season. That's high. A filter will not really solve your issue--you will need a softener for that.
#2431489 - 01/09/18 04:38 AM Re: Home filtration for lime build up on faucets? [Re: Charger727]
StrokerPost Offline
Loc: Missouri
Its definately the city water, not BECAUSE its city, just our city water is not that good. Ran a softener for 15 or 20 years when on the well and when the water heater went bad it had nothing in it at all, it was light as a feather after draining it. After the softener quit we switched to city water thinking it would be better, but after only 4 years the new water heater was so limed up and leaking it would hardly give any hot water at all, and when i took that one out it weighed a ton, it was full of lime. Anyway, the new one is not a year old and we've decided to buck up and fix the softener before that new heater is junk too. Thanks all for your thoughts.
#2431559 - 01/09/18 09:55 AM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
srt Offline
Loc: Standing By
You can check your water reports, many municipalities post it on line.
With your recent change the new water and it's associated chlorine can be disintegrating years of scale from inside your plumbing.
Over the years I've been involved in several waer system expansion projects. After construction and attaching to homes the superchlorinated water (tablets or injection in mainline) would be allowed to run through fire hydrants to flush. The flush was to disinfect the new construction. Did the water company fill and flush your home system? If so that could start the process, or, even over time the chlorine will start the descaling of your lines and it will peak and slowly get better and better. To help it alons it's wise to flush your water heater once a week or so and also open all faucets and the lowest hosebib at least once a week. Early morning is best as the chlorinated water has been working on the scale all night.
#2432267 - 01/10/18 01:09 PM Re: Home filtration for lime build up on faucets? [Re: StrokerPost]
MoparKansas Offline
Loc: KS
We moved 3 months ago to a place that has 19 Grain hardness. Bought a new dishwasher and in the 3 months the stainless inside had turned almost completely white. I installed a new softener last week and the hard water spots on the sink and in that dishwasher have almost disappeared. Many of the bathroom and toilet fixtures in the house are almost completely shot and the house is only 15 years old.
This is the place we bought ours from and it looks like they sell the head only if it would work on your tank. https://www.discountwatersofteners.com/g...esaApMMEALw_wcB
I think it would be worth the investment to get a softener again just to save the wear and tear on your appliances and fixtures. Good luck!
25,073 Registered Members
185,627 Topics
67 GTX production numbers
by 440mopar
01/18/18 11:51 PM
Want aluminum wheels, 2006 Mega.. 17, 18, 20 ????
by sunroofgtx
01/18/18 10:58 PM
Ugly finish to the day....
by Satilite73
01/18/18 10:47 PM
Longtime Ohio CPD Dealer Albert Weekley passed away.
by 300by500
01/18/18 10:14 PM
