Page 11 of 12 < 1 2 9 10 11 12 >
#2166160 - 10/01/16 08:34 PM Re: 420cid build with a new Ritter Aluminum Block [Re: ksj]
GY3 Offline
Loc: Wichita
Awesome! We did the Friday night test and tune and went to the swap meet up there last weekend. You guys have an AWESOME track to play at!
#2166331 - 10/02/16 08:03 AM Re: 420cid build with a new Ritter Aluminum Block [Re: MoparBilly]
moparx Offline
Dreaming of implants
Loc: north of coder
Originally Posted By MoparBilly
Moparx,
I borrowed the photos from Bob Brehm's facebook page. Bob is the best amateur automotive event photographer in the mid-west!
Bob was a school friend of Doug, KSJ's brother, and he told me at Drag Week that KSJ's only redeeming quality was that he introduced Bob to 69 lawndart!
I have to agree KSJ has an innate knack of introducing cool people to other cool people!! While he is definitely not in that club, he serves as a kind of Social honey bee.
well, regardless if you borrowed those pics, i'm glad you did billy. i have tried a couple of different ways to attach dog dish caps to different wheels with varying results always using the original "snap on" method of retention. my old, cloudy mind never gave it a thought to use a retention screw method, and i just looked at a cap laying around and concluded a nice flat head or button head 8 or 10-32 stainless screw would work perfect for what needs to be done and not be easily observed. so in the end, all you guys helped my old mind with a good kick start. up and i am very appreciative of all you guys ! thanks again billy for getting this ball rolling and allowing me to obtain the info i was seeking ! bow
beer
#2180146 - 10/22/16 01:08 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
69 lawndart Offline
Loc: Kansas, Topeka
Last update, Went back to the track this evening the car went 10.285 @ 134.83 MPH and 10.224 @ 135.35 MPH, still on the conservative side leaving RPM and shifting. Motor seams happy, clean oil and good pressure.
#2180148 - 10/22/16 01:24 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
ksj Offline
Loc: Topeka Kansas
Good to hear.
#2180260 - 10/22/16 10:22 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
J_BODY Offline
Loc: aZLiViN
"last update"??? hoping that just poor wording, I prefer "latest update" smile that ride is just sooo cool!
#2180611 - 10/22/16 10:17 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
1967dartgt Offline
Loc: Hilltown Pa
Good to see some more laps on this.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
#2356012 - 08/18/17 11:01 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
69 lawndart Offline
Loc: Kansas, Topeka
Latest up date, I pulled the motor out of the car it has about4300 miles on it with no problems. Right now it is sitting on a Dyno and we have made 11 pulls, the numbers are not that great but we will keep working on it. the oil pressure is great and it is giving us no sign of problems.
#2356020 - 08/18/17 11:11 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
pittsburghracer Offline
Slowride
Loc: PA.
Great news
1970 Duster
Edelbrock headed 408
6.143@110.89 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
6.001@113.27mph
9.42@138.27
Untitled by John Cadamore, on Flickr
#2356022 - 08/18/17 11:17 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
fast68plymouth Offline
Loc: So. Burlington, Vt.
Sounds like you're headed in the right direction.
Keep us posted drive
68 Plymouth Satellite, 383, stock 906's, 3550lbs, 11.18 @ 123, 1.51 60'
WD- Comp Cams / Indy Cylinder Heads
#2356068 - 08/18/17 12:59 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
scottb Offline
Loc: New Smyrna Beach FL
There is a block on racing junk right now 4100.00 new with some machine work done
#2356069 - 08/18/17 12:59 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
scottb Offline
#2356071 - 08/18/17 01:03 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
Al_Alguire Offline
Loc: Las Vegas
That is not in the owners possession apparently still at Ritters....
#2427357 - 01/01/18 04:56 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
Dadodgekid Offline
Loc: Palm City, FL
Hows it going with this project lawndart??
#2428374 - 01/03/18 02:05 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
69 lawndart Offline
Loc: Kansas, Topeka
I pulled it last Friday to look it over. It looks Ok, its not great and it not bad, on three of the rod bearing the coating looks like it flaked off on the top of the bearing. The main bearings look good, cam bearing are showing some wear but that's expected with the spring pressures and RPM I am running. Piston skirts looked good nothing to be worried about.
Edited by 69 lawndart (01/03/18 03:48 PM)
#2428399 - 01/03/18 03:02 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
Did you find any power with what you tried on the dyno?
Is it up to your expectations, or will you be looking for more when it goes back together?
#2428424 - 01/03/18 03:55 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
69 lawndart Offline
Loc: Kansas, Topeka
Yes I found a little more power on the dyno but not ready to put a hood scoop on the car. I have mixed feeling on my expectations on one hand it ran as good with this new aluminum Ritter block as it did with the R3 block before the come a part. But on the other hand I don't think the motor is running up to its potential. Yes I will be changing things when it goes back together.
#2428536 - 01/03/18 07:29 PM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
Jason B Offline
Loc: Mopar
Great post man glad to see someone out here making it work... great job
1968 Cuda 440" Edelbrock Victor Head Small Block.
#2428600 - 01/03/18 08:41 PM Re: 420cid build with a new Ritter Aluminum Block [Re: Jason B]
69 lawndart Offline
Loc: Kansas, Topeka
Thank you sir
#2429785 - 01/06/18 01:06 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
ccdave Offline
The Ultimate
Loc: Mopar Country, Mi
What a nice build!
#2429852 - 01/06/18 09:05 AM Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart]
340Cuda Offline
Loc: Tulsa, Oklahoma
Mike,
Have you made a decision on HR Drag Week 2018 yet?
It would be good to see you back.
Thanks for sharing what you learn with us.
Bill
25,535 Registered Members
194,069 Topics
1986 D150 Ram truck electrical problem
by Kevlisa
5 minutes 24 seconds ago
pushrods
by DusterKid
Today at 08:12 PM
Big block Crate motor recommendations ?
by TJP
Today at 08:02 PM
Anybody ever get their Autozone order denied?
by JerseyJoe
Today at 07:44 PM
