Re: Flow testing carburetors... * DATA ADDED *
[Re: BradH]
#2430075
01/06/18 06:17 PM
01/06/18 06:17 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The Super Flow carb testing fixture is pretty similar to what Brad used, only it comes with a 4 hole spacer. The spacer has a small hole in the center of it to locate it on the pin in the plate. Then you just rotate it around to test all 4 holes.
The hole in the plate is 1.750, but the holes in the supplied spacer are only 1.687, which is fine if you're testing carbs that don't have a 1.750 throttle bore.
I found a spacer with 1.750 bores to use on the big carbs, and drilled the hole to locate it on the pin.
I also made one to use with 4500 series carbs.
[Re: BradH]
#2430086
01/06/18 06:42 PM
01/06/18 06:42 PM
Posts: 1,454 oklahoma
forphorty
oklahoma
[Re: moparx]
#2430104
01/06/18 07:05 PM
01/06/18 07:05 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Ever considered flow a couple of TQ’s?
i really like those carbs, and that would be of interest to me as well. I just threw one on my bench and it said 820cfm
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: BradH]
#2430109
01/06/18 07:09 PM
01/06/18 07:09 PM
fast68plymouth
So. Burlington, Vt.
Ray, could you pull 20.4" with flowing all barrels?
[Re: fast68plymouth]
#2430115
01/06/18 07:14 PM
01/06/18 07:14 PM
sixpackgut
Charleston
Ray, could you pull 20.4" with flowing all barrels? IDK. Im sorry but I have no idea. I just threw my 1050 dominator that had the boosters changed to skirted boosters for e85 and it says it flows 1000. Well, i just tried a 600cfm performer and it says 670cfm. My method is probably not accurate but I would think comparable for me checking different carbs
[Re: BradH]
#2430165
01/06/18 08:45 PM
01/06/18 08:45 PM
fast68plymouth
So. Burlington, Vt.
I just threw one on my bench and it said 820cfm You don't know what the test pressure is? Edit: Okay, I looked at the site where you got your electronics from. The picture of the display box isn't all that clear. Is one of the options for the display 20.4"? If not, are you using one of the other depressions and converting the numbers to 20.4"?
[Re: moparx]
#2430607
01/07/18 05:32 PM
01/07/18 05:32 PM
sixpackgut
Charleston
Thanks. What model number & primary size? Thanks as well sixpac ! same question as rob. Guys, I really dont think the way Im doing this is accurate. Im just throwing it on the bench with it converting at 28". The TQ I have is 9379s. Pri 1.370 Edit: fast68 is schooling me on flowing carbs. My numbers are not accurate and he is making me depressed. lol
