Re: aftermarket distributor id
[Re: poorboy]
#2428392
01/03/18 05:52 PM
01/03/18 05:52 PM
Posts: 1,820 South Bend
John Brown
South Bend
Had a MSD / Autotronics circle track setup used that style pick-up. Might start looking there.
[Re: moparx]
#2428694
01/04/18 02:48 AM
01/04/18 02:48 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
they are all over ebay....blue..black red cap...your choice
https://www.ebay.com/itm/Small-Block-Mopar-Chrysler-Plymouth-Dodge-318-V8-Pro-Billet-Distributor/201864361103?epid=703356360&hash=item2f000db48f:g:83MAAOSwXYtY1DTy&vxp=mtr
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: poorboy]
#2430489
01/07/18 02:04 PM
01/07/18 02:04 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
It looks like something designed to replace a Lean Burn, or a computer controlled timing advance dist. Also looks like a modified GM dist pickup module with a Ford cap design. Looks pretty....Where would you ever get a replacement pickup/module? It would be wall art at my place. Gene I'm no expert, but I think poorboy is right. It "looks" like a timing "lockout" distributor similar to a lean burn system where the timing advance is computer controlled. I "think" some guys running blowers/turbos and/or EFI might use this type of distributor. It basically just allows you to set the initial timing and all the advance is controlled by something else (like in the lean burn system)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
