Future of Gen III
#2428082
01/03/18 12:38 AM
01/03/18 12:38 AM
Posts: 4,254 Canada
WO23Coronet
Canada
Re: Future of Gen III
[Re: RylisPro]
#2428142
01/03/18 02:52 AM
01/03/18 02:52 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
They should make it an aluminum block as standard. Less weight would help with fuel efficiency Exactly How about making a challenger 7-10% smaller. The damn things are huge
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: WO23Coronet]
#2428174
01/03/18 05:52 AM
01/03/18 05:52 AM
Posts: 24 Northern Colorado
EagleDuster
Northern Colorado
YES. I hope they keep the 2-valve layout or they really won't be able to get away with calling it a Hemi anymore, purists still whine the Gen 3 isn't a "true" hemi (yeah whatever) If they ever get around to it, the next Challenger is supposed to be on a smaller platform shared with the Alfa Giulia. Maybe they're waiting for this new smaller Hemi to get developed so they can use that, Hmmmmmm They should make an aluminum-block version in a throwback 5.2L, would give new meaning to "smoking Mustangs with a 318" heehee
Khalid 1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
[Re: WO23Coronet]
#2428193
01/03/18 10:14 AM
01/03/18 10:14 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Dual over head cam similar to the LT5 but cross flow valve head, like the modern Hemi, 4.7/5.2ish 2020/2022 4.0-4.25 bore spacing. Would be a logical next step. The power Tech 4.7 was going to grow to a Dual Cam, 5.2 before DC started to have money issues.
[Re: WO23Coronet]
#2432479
01/10/18 10:13 PM
01/10/18 10:13 PM
Posts: 12,415 Kalispell Mt.
HotRodDave
Kalispell Mt.
they make less HP (385HP) than a smaller 5.7 hemi (395 hp) with all of its "pushrod fuss" I don't get the ferd fuss I guess and they have the same junk cam phasers that start dying around 125,000 that the 5.4 pile o junks had in a nightmare package to work on so I'll pass a 6.2 in more than one ways.
[Re: WO23Coronet]
#2432548
01/11/18 12:04 AM
01/11/18 12:04 AM
EagleDuster
Northern Colorado
5500 RPM redline in the Ford 6.2L and it's SOHC? What's the point? That's the same as a 5.7 Hemi with those 'antiquated' pushrods...
[Re: EagleDuster]
#2432845
01/11/18 03:53 PM
01/11/18 03:53 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
5500 RPM redline in the Ford 6.2L and it's SOHC? What's the point? That's the same as a 5.7 Hemi with those 'antiquated' pushrods... How about you take off your socks and count up the number of moving parts in a SOHC vs a pushrod V8 valve train. Then ponder the inertial mass involved in each and recall that a lighter valve train can be opened and closed quicker allowing more area under the curve. Then think about that pushrod pinch in the LA intake track and it's complete lack in a SOHC design. Want to keep playing?
[Re: WO23Coronet]
#2432851
01/11/18 04:11 PM
01/11/18 04:11 PM
HotRodDave
Kalispell Mt.
how bout the 400ft of timing chains that inevitably stretch over time and are expensive and complicated to replace (think 4.7 dodge, 5.4 ferds, 427SOHC ferds, 5.7 tundras...) there is a whole plethora of engines plauged by that insanely long chain requirement. And as a bonus the extra valves and everything still don't help the head flow anymore than an apache/hellcat/BGE head.
[Re: WO23Coronet]
#2433095
01/11/18 10:51 PM
01/11/18 10:51 PM
Supercuda
About to go away
About to go away
up yours
400ft of timing chain, get real. If it's all that complicated and intimidating then retire.
[Re: WO23Coronet]
#2433141
01/12/18 12:14 AM
01/12/18 12:14 AM
HotRodDave
Kalispell Mt.
I do em for a living and see the look in peoples eyes when you tell em how much its gonna cost to fix that garbage without even having high miles on em. They cost twice as much and don't last near as long with no benefit, especially in a truck engine. Sorry but its just a cool novelty that ain't worth the cost in a production type engine.
[Re: dogdays]
#2433240
01/12/18 06:27 AM
01/12/18 06:27 AM
EagleDuster
Northern Colorado
I knew that my comments would not go un-carped upon. Did I use the word "antiquated" anywhere?
I don't give a poop about cam phaser problems, I am not buying a ford pickup. Obviously if one wanted to build a hotrod version of the engine the redline would be higher. So what? So pushrods work to 11,000rpm. So what?
You guys fire off comments without doing the research. That's your right, but it doesn't make you more knowledgeable.
The original question was which direction would a new version of the Hemi go. My suggestion was that it might go in the direction of the 6.2, as the rocker arm arrangement of that engine very closely resembled the rocker arm arrangement of a Hemi or, for that matter a Toyota 20R.
The reason I was familiar with this is my recent trip in a new pickup that had the 6.2, which was quite impressive to my 318-powered self. And I figured out that the engine was OHC from inside the cab, from the sounds it was or wasn't making.
End of rebuttal.
R. Sorry I wasn't actually trying to argue with you though I guess it did sound that way, my comment wasn't aimed at anyone in particular and I do get your point. I'm simply saying if Ford went through all the development to make a SOHC truck engine why does it only rev to 5500 RPM? And have basically the same output as an engine half a liter smaller in displacement (5.7 Hemi)? It's like the modular engines, with all the advanced technology they had they should have been on another level vs. GM and Chrysler but were basically mediocre throughout their entire run. They had all the problems of modern engine technology with no real advantages over the competition. I don't think the 6.2 is a "bad" engine I'm just disappointed it can't do more (and yes I know Ford has the special high-output version as an option on the Raptor). Pushrod arrangement does create a lot of extra heat at high RPMs and has more friction but it keeps big-displacement engines more compact and lighter. I just feel like with pushrod engines like the Hemi and LS being as good as they are, any future V8 from Chrysler or GM that does have OHC better take full advantage of it and really raise the bar. Or at least just Chrysler lol
[Re: HotRodDave]
#2433241
01/12/18 06:33 AM
01/12/18 06:33 AM
EagleDuster
Northern Colorado
I do em for a living and see the look in peoples eyes when you tell em how much its gonna cost to fix that garbage without even having high miles on em. They cost twice as much and don't last near as long with no benefit, especially in a truck engine. Sorry but its just a cool novelty that ain't worth the cost in a production type engine. That's how I see it, using technology so on paper you're keeping up with the industry but in practical use there is no real benefit. And apparently a few fatal drawbacks.
