Re: 76 Volare, yes a volare.
[Re: modelmakerinc]
#2477187
04/04/18 01:12 AM
04/04/18 01:12 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
This is a very impressive thread. Your fab skills are awesome. I look forward to seeing it done.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: modelmakerinc]
#2488392
04/26/18 06:21 PM
04/26/18 06:21 PM
Posts: 2,343 west palm beach, florida
modelmakerinc
Finally blocked the top two more times and worked on the transitions from the stock hood to the scoop panels and sprayed last hi build.
Flipped it over and scraped,wire wheeled, sanded, and cleaned the bottom. I put a light coat of paintable undercoat for some texture, color and a med wet coat of clear.
My shop phone is black to show the contrast to my argent/gunmetal gray. I am quite happy with the look and am getting excited to get the car in color.
[Re: modelmakerinc]
#2488543
04/27/18 01:39 AM
04/27/18 01:39 AM
Posts: 16,128 Mesa, Arizona
dart4forte
Mesa, Arizona
Glad to see you kept the transverse torsion bars. Overall, impressive build
Abe Lincoln
[Re: modelmakerinc]
#2489237
04/28/18 09:59 PM
04/28/18 09:59 PM
modelmakerinc
Been thinking about the hood and it needs an engine callout, but I already drilled my fenders for 383 badges so....
I made my own fender badges to use the holes because I don't want to weld and bodywork the fenders any more.
Really just an excuse to do something different, I cut out a new name plate and added the angled return for strength and support.
[Re: modelmakerinc]
#2514684
06/28/18 11:06 PM
06/28/18 11:06 PM
modelmakerinc
Update, I took a week off to get the car blocked for the final time, built my make shift spray booth and got color on the car. I still need to shoot the two tone on the hood and fender tops but that will be probably Sunday.
Here are a couple pics of it so far.
[Re: modelmakerinc]
#2514690
06/28/18 11:16 PM
06/28/18 11:16 PM
modelmakerinc
Some color shots. This is Nason, Ful-Thane SS. Sprayed with a Devilbiss finish line with a 1.5 fluid tip, around 18psi I did get a couple runs on edges and a couple of sags or hangars. I won't post those pics though.
[Re: modelmakerinc]
#2514756
06/29/18 01:58 AM
06/29/18 01:58 AM
moparpollack
Lil Herman
Lil Herman
85086
Some color shots. This is Nason, Ful-Thane SS. Sprayed with a Devilbiss finish line with a 1.5 fluid tip, around 18psi I did get a couple runs on edges and a couple of sags or hangars. I won't post those pics though. Those runs are paint flow meters! Looking good!
[Re: modelmakerinc]
#2515476
06/30/18 07:27 PM
06/30/18 07:27 PM
modelmakerinc
Thanks Guys.
I was able to get the two-tone done today.
I am really happy with the results and the color is exactly what I was going for, it will have good contrast to black accent pieces.
