Early 8.75 housing ID #2427491
01/02/18 12:18 AM
01/02/18 12:18 AM
Ks
P
pullandrag Offline OP
P
Ks
Guy called me said he was doing some cleaning and a had a B body 8.75 axle housing I could have no carrier, brakes or axles,I've know what the 64 and older look like have put brakes on one many years ago but if you had a 63 and 68 B body 8.75 bare housing laying side by side it's there a difference? I do know the width but never seen a early one blown apart thanks for any help
Re: Early 8.75 housing ID [Re: pullandrag] #2427591
01/02/18 03:52 AM
01/02/18 03:52 AM
Cab_Burge Online work
Cab_Burge  Online Work
The 1965 and later 8 3/4 inner axle seals are quite a bit different looking than the pre 1965 do, I think scope Look up both inner axle seal numbers and see if they show the same or two different part numbers to make sure scope I believe the early seals are push further back into the axle housings than the 1965 and later are and look different also work
Re: Early 8.75 housing ID [Re: pullandrag] #2427595
01/02/18 04:02 AM
01/02/18 04:02 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The housings are clearly different on the ends and the spacing on the bolt holes to attach the brakes. 64 and older are all 5 evenly spaced bolt holes.
65 and newer have the top two holes further apart across the top. I can get a picture tomorrow
1962 and older full size cars and trucks have Allen head drain plugs flush on bottom of center of housing to pass side of the weld.
1964 and older has even star pattern on the bolt spacing
Re: Early 8.75 housing ID [Re: NANKET] #2427816
01/02/18 04:30 PM
01/02/18 04:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Actually, the housing ends changed in '62 for most models. Even though the '62-'64 retained the tapered axle, the housing end bolt pattern was changed and retained when they went to the flange axle in '65. As stated earlier, the big difference is the depth of the housing bore...the '65-later is deeper (about 2 1/4") and the seal is deeper to accommodate the axle bearing retainer.
In the pic below the pre-'62 is on the left.
