#2423053 - 12/24/17 09:49 AM RAM TECHS HELP 08 CRUISE INTERMITTENT
crabman173 Offline
Loc: Big Lick , North Carolina
My 08 Ram 1500 has been experiencing trouble with cruise control--it will work fine then switch will not turn it on --then later it does --after few miles it turns off
OK I had truck in dealer for inspection ask them to trouble shoot--They came back it is the switch so I buy one install it myself and guess what? It is not the switch
What to do here gang --any ideas??? Thanks for the help
I have always had a fascination with fast cars at the expense of more normal character development
#2423274 - 12/24/17 05:43 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
kenworth_goose Offline
Loc: ky.
TIPM
#2423386 - 12/24/17 10:20 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
crabman173 Offline
Ugh what??
Thanks for helping
#2423805 - 12/25/17 10:12 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
Loc: ky.
total integrated power module, or otherwise known as the fuse box under the hood by the battery.
#2423858 - 12/26/17 08:47 AM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
crabman173 Offline
Ok so I have read up on all the issues with TIPm so what do I do? hard reset? Replace the entire TIPM for cruise issue? that sounds scarey more info please Thanks
#2424180 - 12/26/17 09:00 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
SALEM1912 Offline
Loc: Southeast Pa.
Possible clock spring? Does the lite in dash stay on?
Edited by SALEM1912 (12/26/17 09:12 PM)
#2424191 - 12/26/17 09:22 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
Loc: ky.
I'd buy the tipm from a dealer near you, you can install it yourself. After it's hooked back up you turn the key on for 12 seconds, turn it back off, start the truck as normal. Remember you have to push the fuse in for the airbag module. What I do is go through and push all of the fuses and relays in to make sure and all should be good. Are you having any other issues?
#2424192 - 12/26/17 09:25 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
Loc: ky.
My truck kicked the cruise off when the "service 4wd" light would come on.
#2424249 - 12/26/17 11:38 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
stumpy Offline
Loc: Grand Prairie,Texas
Does the speedo quit when the cruise does? The reason is a speed sensor will cause the cruise to quit also.
#2424297 - 12/27/17 07:56 AM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
crabman173 Offline
No other issues--at times cruise light works will come on--set cruise--all good then green cruise light goes out --no cruise
wait push on off button--nothing--then in a minute it starts working again
all other items work fine
dealer said switch so I replaced it --no diff
wiggled and pushed all fuses--nothing
Horn and all other items on steering work so guessing clock spring ok?
It is just the cruise--works sometimes them not --will not stay on and work more than a few minutes
Thanks for ideas--it is driving me crazy
No codes shown at the moment
#2424612 - 12/27/17 06:08 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
mopars4ever Offline
Loc: md
Does it work better if you hold the pedal up? Maybe the switch located there?
#2424995 - 12/28/17 03:23 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
crabman173 Offline
will try that thanks
#2425002 - 12/28/17 03:59 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
stumpy Offline
Check the brake light switch.
#2425750 - 12/30/17 10:02 AM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: stumpy]
bboogieart Offline
Loc: Lost and Spaced
When this happened in our mini van, I was told it was the clock spring and that it also affected anti lock brakes.
I have driven most of my life with out either of those functions, so I just blocked the lite on the dash.
Several years later & still no issues.
I have mechanical Aptitude.
I can screw up anything.
#2427360 - 01/01/18 05:01 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: SALEM1912]
crabman173 Offline
dash light might come on for a while--then goes out--it is hit or miss if it will stay on or not but only stays on a while then pops out/off
Tried brake light switch --Nope--replaced switch in steering wheel --Not that either
Horn and all other stuff on steering wheel works so could it still be clock spring?
What about the TIPM? Do I just need a hard reset--like attach the battery cables together for an hour or so to reset--does that work will it help/ can it hurt anything? Wiggled all the fuses etc no change
#2427388 - 01/01/18 05:54 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
Loc: ky.
TIPM replacement. Hood it up, push the airbag module fuse in the rest of the way so you don't get an airbag light, turn the ign key to the on position for 12 seconds, turn back to off, turn back on and start the vehicle.
#2427517 - 01/01/18 09:53 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
stumpy Offline
Yes on the clockspring question. Everything but cruise could work and it still be bad. It has a number of different circuits in it.
#2427533 - 01/01/18 10:16 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: stumpy]
SALEM1912 Offline
Loc: Southeast Pa.
Car sitting still turn CC on (dash lite on) turn steering wheel back and forth lite turn or hard watch for dash lite to cancel if it does Clock spring is bad. Clock spring get the most wear in the 11/12/1 o'clock position. Also it tilt wheel move that up and down wiring to clock spring may have a split.
#2427554 - 01/01/18 10:59 PM Re: RAM TECHS HELP 08 CRUISE INTERMITTENT [Re: crabman173]
stumpy Offline
I don't think the cruise will come on unless the vehicle is moving above 25mph.
25,487 Registered Members
193,030 Topics
Summer Road Trip Part 2
by dart4forte
09/21/18 11:51 PM
rustler engine diapers. Two thumbs up the price and timeline
by WHITEDART
09/21/18 10:43 PM
440 source 5050 pistons
by Wicked49670dart
09/21/18 10:41 PM
Radiator cap
by cdstl
09/21/18 10:11 PM
