Cooling Fan Clutch #2427289
01/01/18 06:20 PM
01/01/18 06:20 PM
Central Texas
b_body_fan Offline OP
Central Texas
What is the difference between the "070" fan clutch and the later "112" clutch?
Re: Cooling Fan Clutch [Re: b_body_fan] #2427335
01/01/18 07:28 PM
01/01/18 07:28 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
It's the depth of the shaft to the clutch. I have both clutches but not going out in the garage today to check which is taller vs shorter only 15 degrees here today... Another difference is the 112 is not in Chinese form...
Re: Cooling Fan Clutch [Re: QuickBpBp] #2427467
01/01/18 11:33 PM
01/01/18 11:33 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
112 is taller, puts it a little deeper into the shroud than the 070, maybe by 1/2"?
