Re: EDDY 750 COMPETITION SERIES CARB PROBLEM
[Re: frank]
#2427098
01/01/18 02:45 PM
01/01/18 02:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My thoughts...
Second thought is that your electric fuel pump doesn't pump with the key in run position but the engine not running. If it did you would not have this issue. But if you properly installed the pump then it wouldn't run then anyway. So, you need a pushbutton "prime" circuit. So you can fill the bowl in the morning.
[Re: frank]
#2427117
01/01/18 03:01 PM
01/01/18 03:01 PM
Supercuda
About to go away
About to go away
up yours
An edelbrock should, note I said should, have a silicon accelerator pump cup not a leather one. So it cannot "dry out" unless someone put one in it.
[Re: frank]
#2427147
01/01/18 03:39 PM
01/01/18 03:39 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
If you put key to run for say 15 seconds and then turn it to start it should start if the problem is fuel evaporating out of the AFB which it sounds like it is.
Sheldon
[Re: frank]
#2427155
01/01/18 03:46 PM
01/01/18 03:46 PM
Posts: 1,383 Az
69hemibeep
Az
I had the same problem until I connected the choke yesterday. Might be 60 out but the engine is still 40 from the overnight temps
1969 Hemi Roadrunner 2nd owner
[Re: Dcuda69]
#2428098
01/03/18 01:23 AM
01/03/18 01:23 AM
RapidRobert
Gotta figure out why the carb is empty after sitting overnight. I would take it off & set it on your bench & pull the top & fill the bowl & see where it goes
[Re: RapidRobert]
#2428126
01/03/18 02:26 AM
01/03/18 02:26 AM
Posts: 4,941 WI
Dcuda69
WI
Gotta figure out why the carb is empty after sitting overnight. I would take it off & set it on your bench & pull the top & fill the bowl & see where it goes This^^^ would be a great start! Fuel pumps,chokes,etc ain't gonna help. If there's no fuel in the carb it's gonna be a hard start! If a carb can't hold fuel overnight...there's an issue!
[Re: frank]
#2428133
01/03/18 02:41 AM
01/03/18 02:41 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
What sort of intake and insulation did the 440 without the problem have compared to this 383 that does?
I had a 383 with a Holley street dominater. Had everything from Oem avs, to the eddy 750 you have, to a 3310 on it. I had trouble with no fuel after a week sitting. No problems overnight, but I played around with gaskets and spacers, trying to stop boiling enough to prevent the need of gas down the throat after a week. Stock flat hood so I couldn’t just throw a huge spacer on and be done.
With a gasket or two, it started great, but you could tell the carb was hot as it took a split second to light off. The biggest spacer I found that still fit was about 3/8 of an inch of old school cardboard paper type stuff. Started as good or better than efi. Still didn’t cure the dry bowls after a week. Didn’t matter enough to me to put on an electric pump before I sold the car.
I want my fair share
[Re: frank]
#2428143
01/03/18 02:53 AM
01/03/18 02:53 AM
Posts: 2,138 tucson az
frank
tucson az
Have an Eddy 750 Competition Series on a 383/auto driver car. Engine is mostly stock; nothing radical at all. Has a starting problem. Car simply wont start after sitting all night. I could crank starter all day and will not start. A shot of ether and it starts. Once it starts for first time all is well. Fuel system is in tank electric and works fine. 7 PSI to carb. Had this carb on 440 car for years and no problems at all. Choke is not hooked up and temp is about 60 degrees. Timing and spark good. Not too smart on these Eddy (AFB) type carbs. Your thoughts. UPDATE: Took the top off the carb today and replaced the accelerator pump. Additionally adjusted the floats (both were off by a lot; close to a half inch on level and drop). The old accelerator pump diaphragm was almost gone. This would explain the poor pump shot. Car fired right up and run good. I appreciate all the input. Car is fixed. Thanks
