Question about restoring 69 Dart GT grill & trunk panel #2427072
01/01/18 02:25 PM
01/01/18 02:25 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I am restoring both the grill and trunk finish panel on my 69 Dart GT. I am in the process of repainting the black areas on both pieces. I am using satin black paint. My question is, do you think it would be advisable to spray a coat of satin clear over the black? I was originally thinking maybe I should but then thought maybe the clear might discolor and not look right.
Re: Question about restoring 69 Dart GT grill & trunk panel [Re: 440mopar] #2427444
01/01/18 10:44 PM
01/01/18 10:44 PM
N.E. OHIO
P
polara426 Offline
polara426  Offline
P
N.E. OHIO
I did a 69 GTS grill and tail panel just used sem trim paint came out nice.
Re: Question about restoring 69 Dart GT grill & trunk panel [Re: polara426] #2427470
01/01/18 11:37 PM
01/01/18 11:37 PM
New York
rarefish Offline
rarefish  Offline
New York
I'm also interested in finding the correct paint for the the same parts on my GTS.
I just checked SEM web site and I see they have more than one paint listed as "Trim Paint"
Which one did you use to get the correct finish? Thanks...
Re: Question about restoring 69 Dart GT grill & trunk panel [Re: rarefish] #2428033
01/02/18 10:59 PM
01/02/18 10:59 PM
BlueRacer69 Offline
BlueRacer69  Offline
Here is the paint you need: SEM 15013 Landau Black. Comes in spray cans. Get it on E-bay, $17.73 ea. This is as close to factory as you'll maybe ever get.
Re: Question about restoring 69 Dart GT grill & trunk panel [Re: BlueRacer69] #2428114
01/03/18 01:56 AM
01/03/18 01:56 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Does anyone else have any thoughts on my original question about applying a coat of clear?
Re: Question about restoring 69 Dart GT grill & trunk panel [Re: 440mopar] #2428239
01/03/18 12:40 PM
01/03/18 12:40 PM
New York
rarefish Offline
rarefish  Offline
New York
I personally would not apply a clear coat to the grille or trunk panel. I'm thinking that doing so would give it a custom look instead of a factory look.
Re: Question about restoring 69 Dart GT grill & trunk panel [Re: 440mopar] #2428304
01/03/18 02:47 PM
01/03/18 02:47 PM
BlueRacer69 Offline
BlueRacer69  Offline
I agree with rarefish and say No.
