Page 4 of 4 1 2 3 4
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: RylisPro] #2561787
10/10/18 07:34 AM
10/10/18 07:34 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey Everyone,
Just got word from Prefix yesterday that they have the following:
4 pcs - P5049330AC Drag Pak intakes
6 pcs – ARR-CAS-1010 (CASCAR Carbureted manifold)
3 pcs – ARR-7509-M (CASCAR Fuel injected manifold)
Pricing is on our "RylisPro" instagram page. If you want to order, please email us your address at RylisPro@gmail.com to get a shipping quote to drop ship the above parts from Prefix.
Unfortunately Jordan is not with Prefix anymore but we can help with ordering.
Thanks!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: hudsonhornet7x] #2567749
10/22/18 11:48 AM
10/22/18 11:48 AM
NE Ohio
Y
YeahItsAHemi Offline
Y
NE Ohio
New here but not to Hemi forums. I’ve got a 5.7 based 392 stroker in my ram 1500. Im building it for street/strip. It probably weighs about 5300 lbs, Racing will be with 2wd and slicks. I swapped to a built 46re and a CRT valvebody, running 4.56 gears. I’m working on doing a 5.7 eagle head swap with the 5.7 eagle truck intake. But these single plane intakes are interesting me, my question is how much torque do these lose over the plastic intakes? With a heavy truck I don’t want to lose much more torque. I’ll be running around 10.8 compression and an Inertia stroker cam. Any input on these arrow I takes for my build?
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: hudsonhornet7x] #2567906
10/22/18 05:15 PM
10/22/18 05:15 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
What cam are you running? What fuel?
The plastic one keeps the air a lot cooler also so it works better with pump gas and high compression. Unless I was running a real big cam I would keep the plastic one for the cooler air and longer TQ oriented runners.
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: hudsonhornet7x] #2567909
10/22/18 05:21 PM
10/22/18 05:21 PM
NE Ohio
Y
Y
NE Ohio
231/240 duration, .556/.560 lift. Nothing too crazy. Pump 93 gas. Right now I have the pre-eagle heads and truck intake and it really needs some pick me up. Hoping to get some more power from the eagle heads. I’m planning on utilizing the active runners in the newer truck intake with an rpm window switch. I want to get maximum power out of it N/A before I go with a turbo setup later
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: hudsonhornet7x] #2568391
10/23/18 03:27 PM
10/23/18 03:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the eagle top end will really pick that thing up
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: hudsonhornet7x] #2569380
10/25/18 02:35 PM
10/25/18 02:35 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Really great looking parts.
Nice to see somebody (anybody) working on this stuff, still.
Back when I had the opportunity, I collected the granddaddy, the 392 crate motor carbureted intake, which had quite a story behind it.
I've been letting alot of pieces go lately, but that one is not for sale.
Rich H.
Esse Quam Videri
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: hudsonhornet7x] #2569385
10/25/18 02:39 PM
10/25/18 02:39 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
So, the other day I came across this 2 piece LS manifold.
Though I am much less knowledgeable about aluminum casting than I wish I was....I couldn't help but wonder, wouldn't a 2 piece casting for GenIII offer some benefit. Could it be less expensive to produce...
https://www.hotrod.com/articles/quick-tech-holleys-new-two-piece-cathedral-port-intake/
Rich H.
Esse Quam Videri
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: hudsonhornet7x] #2569456
10/25/18 05:12 PM
10/25/18 05:12 PM
K
Kiddart Offline
Kiddart  Offline
K
you would think it would be but nobody will take the leap of faith to produce things that are cost effective for mopars. this is such a crazy hobby we all have
Thank you
Kiddart
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: Kiddart] #2657987
05/22/19 12:37 PM
05/22/19 12:37 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Just getting into this Gen 3 stuff, and bought the last EFI version of the Prefix manifold. Wow, yes, very expensive. My wallet just got it's ass handed to it.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: ChrgrCuda] #2657997
05/22/19 01:06 PM
05/22/19 01:06 PM
USA
hudsonhornet7x Offline OP
USA
Yes but when you spend $100 on good used rockers it evens out! Plus the heads are a killer deal for the air they flow.
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: hudsonhornet7x] #2657999
05/22/19 01:12 PM
05/22/19 01:12 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Very true. Potential on these G3's seem to be extreme when compare to my old SB and BB equipment.
Re: UPDATED WITH PICS ARROW SINGLE PLANE INTAKE [Re: ChrgrCuda] #2658362
05/23/19 11:53 AM
05/23/19 11:53 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Yes, they do. What started me was a $400 set of Eagle heads w/rockers and shafts. Nothing ventured, nothing gained, right? When they went 298 @ .600" in OE form, I became a G3 believer!
Page 4 of 4 1 2 3 4
