Re: Indy Modman Dimensions
[Re: WO23Coronet]
#2426884
01/01/18 01:10 AM
01/01/18 01:10 AM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
Does anyone have the dimensions of the opening of the Indy Modman? Looking to see if it’ll work for a project. I think they all have the same opening (BB, SB, Hemi etc) so a measurement from anyone should work. Width, Length and Depth If you can wait until tomorrow, I can give you the top plate dimensions (length and width). I don't really want to tear the top plate off the intake right now.
[Re: Streetwize]
#2426887
01/01/18 01:15 AM
01/01/18 01:15 AM
Uncle Barry
I'll give it another bump because I'm curious if anyone ever made any power with one, it always just looked like a shoebox lid with runners and carb mounts to me. It works great for what I have. My car isn't a race car. It squeaked into the 10s with a modman. 528 hemi with 2 eddy 750s on it. Pump swill and full TTI exhaust. I wish someone would do a comparison between the modman and eddy intake myself...
[Re: WO23Coronet]
#2426945
01/01/18 04:05 AM
01/01/18 04:05 AM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
Will look tomorrow if you need still . I know on my 440 between a M1 and BG825 with 1"spacer and modman with twin 600s it was a wash HP wise . BUT . Car slowed in the 60 and lost et , same MPH . Could not get a good AFR , ran lots of jet/rod etc still showed lean . Even tried 4 hole spacers to improve signal . No help . Added a full length filler to reduce plenum volume , inconclusive . Felt great on the street . May get a chance to try it on my 505 this year . I feel this will work better plus leaving on a 2 step at higher rpm PS , measured plenum volume was approximately 5 litres Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: WO23Coronet]
#2427703
01/02/18 01:40 PM
01/02/18 01:40 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
Thx, I’m considering it for a boosted application I was sure there are measurements on the Indy or Mancini site but the MM is not far off my BDS intake.The MM is 4.5" tall I think and has longer runners than my BDS by 1/2".My carb plate is 14" x 6" o/c of the carb studs and is what the MM has I think.lmk if I can help.
