#2426551 - 12/31/17 03:14 PM Trade/Swap/Free/ & Brand X - 1st Quarter
moparts Offline
#2426587 - 12/31/17 03:52 PM Rare and mint Twin Turbo AWD Stealth. [Re: moparts]
RUNCHARGER Offline
Loc: Chilliwack B.C. Canada
1994 Stealth R/T, Twin Turbo AWD, 300 miles on rebuilt engine, mint paint and body, mint interior. Never modified, never rusted or smashed. $10,000US cash or may trade for interesting Mopar project (Local B.C. registered cars only). PM me here for more info. Thanks for the ad. First year for 320HP and 6 speed.
Sheldon
#2428872 - 01/04/18 10:57 AM Re: Rare and mint Twin Turbo AWD Stealth. [Re: moparts]
BlakDak71 Offline
Loc: Michigan
1998 Dodge Dakota, regular cab, short box 2wd, 6.4 Hemi with Mopar 392 Crate kit, Viper T56 6 speed, newer paint, auto meter gauges, 9.25 rear end, trade for decent 340/360 A body or 68-70 B Body, email for pictures and more info greg.snider@gmail.com
#2429821 - 01/06/18 07:23 AM Re: Trade/Swap/Free/ & Brand X - 1st Quarter [Re: moparts]
Dadodgekid Offline
Loc: Palm City, FL
BBC Holley tunnel ram with holley 660’s center squirters. Large rectangle ports, Running on car. Comes with linkage and bird catcher! $700obo plus shipping from fl. Thanks moparts!
#2430412 - 01/07/18 08:18 AM Re: Trade/Swap/Free/ & Brand X - 1st Quarter [Re: moparts]
NTOLERANCE Offline
Loc: Madison Wi
Aftermarket replacement for 383/440 68-71 or so year range. Used unit been on a shelf a long time. Lower miles maybe 10,000. Choke pull off seems to work. Throttle shaft bushings not worn. Needs a kit Likely. $70
Will trade for
Small block hyd lifter set
9635-sa carter 625 carb
Electric fuel pump to feed 500 hp
Cash can be exchanged either way in a swap
This post has been edited from its original form
Reason: Way too friggen drunk.
I was Mopar when Mopar wasnt cool and life was just a bet on a race between the lights.
#2430415 - 01/07/18 08:28 AM Re: Trade/Swap/Free/ & Brand X - 1st Quarter [Re: NTOLERANCE]
NTOLERANCE Offline
Loc: Madison Wi
92-96 Corvette C4 OEM air intake manifold & injectors LT 5.7L # 10108630
Used part removed from a running engine some time ago for an upgraded Intake. Unit has been sitting on a shelf for some time. Pretty complete unit. See pics - I'm not an expert on these engines. I have more pics.
$150 or trade for
Small block hyd lifters - prefer rhoads
Carter 9635-sa 625 comp carb
340/360 rpm Intake
Cash can be added either way depending on trade
#2432237 - 01/10/18 12:37 PM Re: Trade/Swap/Free/ & Brand X - 1st Quarter [Re: moparts]
Mopar1970440 Offline
Loc: usa
FREE
8 1/4 Rear End from an 1986 D150. No brake parts but rear was working fine, I just did a rear-end swap only reason I took it out of the truck.
8 3/4 rearend housing and and axles from a A100 van. No gears or brake parts.
These are both FREE
Located in Central Texas 76802
#2432585 - 01/10/18 09:55 PM Re: Trade/Swap/Free/ & Brand X - 1st Quarter [Re: Mopar1970440]
NTOLERANCE Offline
Loc: Madison Wi
Chevy HHR fan.
New never used only mocked up. I have some simple brackets that will get this to bolt to and early b body 22" radiator on the top two bolts.
Lower bolts need some fab work to mount to the radiator or used those radiator zip ties
Will trade for a 22" fan shroud of some sort for my 65 coronet
I went with a clutch fan. Currently have a 5 blade fan would like a 7.
#2436103 - 01/16/18 10:41 PM Re: Trade/Swap/Free/ & Brand X - 1st Quarter [Re: moparts]
wannadrag Offline
Loc: WI
1941 Plymouth Coupe Gasser, Speedway front axle set up.8.8 Ford 373 geared posi rear, Mild 355 chevy engine, Rebuilt TH 350 trans with 3200 stall converter. New tires, wheels, fuel tank, hard lines. $15,500 or trade for a 68-70 B body or 68-72 A body Email wannadrag2010@hotmail.com
Edited by wannadrag (Yesterday at 10:26 AM)
25,078 Registered Members
185,679 Topics
Seller says worth 50k restored. Better grab it quick
by 67DeLuxe
01/21/18 01:22 AM
My son's ride in a hemi Dart
by Jim_Lusk
01/21/18 12:44 AM
Correct alternator 3438172 for a 71 GTX/RR.
by cdp
01/20/18 11:46 PM
Panhard bar
by sixpackgut
01/20/18 09:40 PM
