#2426549 - 12/31/17 03:13 PM Mopar Transmission Wanted - 1st Quarter
moparts Offline
#2426760 - 12/31/17 07:32 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
440mopar Offline
Loc: USA
1967 big block 727 trans. #2801541 with factory torque converter.
fourfortymopar at yahoo.com
#2426867 - 12/31/17 09:35 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Wanted; Big block 727 transmission with part of #3515848. I would also consider part #3410670 or #3515846. Prefer if in the Detroit area for pickup so as to avoid having to ship.
A new or good used Turbo Action or TCI ten inch torque converter for a 727 with a stall rating of 3300-3500 rpm.
Complete factory automatic kickdown linkage set-up for a 67-69 big block A-body.
gt340 @ yahoo.com
#2427989 - 01/02/18 06:47 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
5carguy Offline
Loc: Lee Co. Fla.
I'm looking for the 4 OEM bolts and washers that hold the 4 speed trans to the bellhousing.71 E body.
PM here
Thanks Moparts FOUND SOME Thanks
Edited by 5carguy (01/14/18 05:42 PM)
#2429635 - 01/05/18 06:45 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
cudaman1969 Offline
Loc: fredericksburg,va
1969 auto trans, last three digits are 093 for RR-Super Bee & RT and GTX. 383-440, Dec-Feb build date, others dates will be considered. If just the case, that will be fine, I have the guts.
I have an 091, could do a trade or sell.
PM here
Edited by cudaman1969 (01/05/18 06:46 PM)
#2430722 - 01/07/18 06:22 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
STEFF Offline
Loc: Smyrna, South Carolina
Reverse Pattern Manual Valve Body for 727 wanted.
PM or Email
Srrimay@gmail.com
#2431965 - 01/09/18 09:21 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
biff426 Offline
Loc: Delaware
Looking for a built small block 727 or Turbo 400 with small block ultra bell. Prefer something with a brake.
Pm me here or dwmotorsports1@gmail.com
#2433194 - 01/11/18 11:09 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
Tommy383 Offline
Loc: NC
Looking for a 727 to mate with my 512rb.
Wanting something I can drive on street. Estimated power in the 650-700 range.
Let me know what you have. Located in Nashville.
Possible trade with keisler tko600 kit for b body. ( plus cash on 727 end)
#2436615 - 01/17/18 08:16 PM Hurst Ram Rod Shifter Boot Wanted [Re: moparts]
blewbyu Offline
Loc: Florida
I need a shifter boot for a Ram Rod Shifter. It is different then the Vertigate so see picture. Anyone with one please contact. blewbyu2bad@aol.com
Edited by blewbyu (01/17/18 08:17 PM)
#2436647 - 01/17/18 09:20 PM Re: Hurst Ram Rod Shifter Boot Wanted [Re: moparts]
moparhotrods Offline
Loc: New Castle,DELAWARE
I'm looking for a 65 - 66 slant 6 cast iron bellhousing
the casting number on the bellhousing will be
2468 431
2468 433
if you have one of these I am interested in buying it please let me know what you have thank you
#2438896 - 01/22/18 07:26 AM Re: Hurst Ram Rod Shifter Boot Wanted [Re: moparts]
RAH Offline
Loc: sw chicago
wanted J 2801544 or PK 2801544 transmissions bob h 708 687 1187
RAH@wowway.com
#2439079 - 01/22/18 01:30 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
csmopar Offline
Loc: usa
Looking for a big block pushbutton 727. Must be a 1964 or a year that is compatible with 1964. Preferably located in the mid-west or at least be willing to ship on my dime. Transmission can be a core unit as i'll rebuild it regardless. Just needs to be complete.
pm me thru here.
Got a couple now, thanks Moparts
Edited by csmopar (02/16/18 10:16 AM)
#2439467 - 01/23/18 08:47 AM Re: Mopar Transmission Wanted - 1st Quarter [Re: csmopar]
Charger446 Offline
Loc: Northeast MA
Looking for a 4 speed shifter ball for a 1969 Dodge. Looking for a woodgrain type in used condition with the grains wearing off as I want to have it match the patina on my steering wheel.
Thanks!
#2441152 - 01/26/18 04:34 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
68LAR Offline
Loc: South Park, Pa.
Looking for a 7290, 30 spline slip yoke.
Contact me here on MOPARTS or "E" mail me at LMForgacs@gmail.com
#2443112 - 01/29/18 08:11 PM 727 Lower/Rear Clutch Drum - 4-Disc Wanted [Re: moparts]
vinnyd76 Offline
Loc: Macomb, MI
I'm looking for a low/rear clutch drum (direct drive) for a small block 727 trans. 4-disc clutch drum with input shaft. Please PM me if you have one available for sale.
Vinny
Edited by vinnyd76 (01/29/18 09:12 PM)
#2443661 - 01/30/18 06:11 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
mrrandyj Offline
Loc: CT
Wanted: 727 take out outer sprag rings. These would be removed to install a bolt in sprag, or a 16 roller Ultimate or Super sprag. If you have any sitting around please let me know. mrrandyj@aol.com
Thanks!
#2450241 - 02/11/18 04:47 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
DBCooper Offline
Loc: South Louisiana
WANTED I am looking for a light weight aluminum 727 rear drum and rollerized planetary gears
Thanks !!
#2452531 - 02/16/18 10:35 AM 1970 18 spline trans [Re: DBCooper]
ogopogo Offline
Loc: BC Canada
1970 18 spline hemi 4 speed trans wanted,ideally with a ST lewis VIN on it IE 0G123456
ogopogo69 'at" shaw.ca
#2454537 - 02/20/18 10:41 AM Re: Hurst Ram Rod Shifter Boot Wanted [Re: moparts]
70b1dart Offline
Loc: st.louis,mo.
iso a good transbrake 727 for big block with 8" convertor,a trans shield would be a plus,im me here or at hemiman4262003@yahoo.com
#2456370 - Yesterday at 08:07 PM Re: Hurst Ram Rod Shifter Boot Wanted [Re: moparts]
JRepucci Offline
Loc: Sacramento,California
Looking for 8 3/4 pumpkin 489 case, large yoke, 3.55 or 3.91 near Sacramento CA.
25,149 Registered Members
186,809 Topics
Adjustable shocks?
by 451Mopar
25 minutes 50 seconds ago
Smoking left bank
by Dave Hall
Today at 01:12 AM
440 install with spool mounts
by 340clone
Today at 12:53 AM
Lowering blocks on '73-'74 B-Bodies
by 340clone
Today at 12:40 AM
