Page 1 of 4 1 2 3 4 >
#2426548 - 12/31/17 03:12 PM Mopar Transmission For Sale - 1st Quarter
moparts Offline
#2426674 - 12/31/17 05:50 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
19hunter68 Offline
Loc: South Carolina
I am looking for a 1-2 gear shift fork for a np445d.
Will take the whole cover.
I have a np435 complete. It would be easier to just change the fork.
#2426776 - 12/31/17 07:42 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
Goat330 Offline
Loc: Randolph, Ohio--N.E. Ohio
65 big block 727 torqueflite SOLD
Edited by Goat330 (02/17/18 07:56 PM)
#2426778 - 12/31/17 07:43 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
Goat330 Offline
I have several slant 6 904s from early 70s darts laying around $20 each.Also have a couple of small block 727s for cores $30 each.Local pick-up only,Bill at wmemore@aol.com or PM,Thanks for the ads Moparts!
#2426780 - 12/31/17 07:44 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
Goat330 Offline
Big block pushbutton T-flite with 62-64 trunnion type output shaft. have the parts to put together or a bare case, $50. Local pick-up only,Bill at330-947-3362 or wmemore@aol.com Thanks for the free ads Moparts!
#2426937 - 01/01/18 12:36 AM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
mosweethemi Offline
Loc: VA.
Hello I have a 1969 383-440 big block Dart or a Barracuda 727 Automatic Transmission for sale . Part number is (2892091) needs rebuilt .$1000.00 O.B.O get with me at mosweethemi@yahoo.con 540-337-4310, on here also Thanks for the add Moparts
Edited by mosweethemi (01/01/18 12:37 AM)
Edit Reason: no change
#2426949 - 01/01/18 01:26 AM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
64dodge572 Offline
Loc: Ohio
BREWER’S PERFORMANCE, INC, Chrysler 4-speed transmission and parts specialists.
THE MOST COMPREHENSIVE, UP-TO-DATE WEBSITE FOR ALL YOUR 4-SPEED RELATED NEEDS:
www.brewersperformance.com
NEW: Hurst licensed pistol grip shifter, fits 2009-up Dodge Challenger 6 speed, including the new Hellcat. Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. Shifter can be modified for shorter throw, by cutting off the bottom mounting screw/hole. $249.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG-CHALL-6
NEW: Cast iron bearing retainer for 1968-72 18 spline transmissions with 308 front bearing, 4.805" outside diameter, 4.16" bolt circle, replaces cast #C97621/2801892 original retainers, and Mopar Performance P4529697. Gasket and seal included.
http://www.brewersperformance.com/proddetail.asp?prod=BR-621C
NEW: Pistol grip shifter, fits new Dodge Challenger/Charger automatics (and all LX platform cars). Fits the factory shifter mechanism, carbon fiber composite grips installed, OE woodgrain grips available as well. $149.95 + shipping
http://www.brewersperformance.com/proddetail.asp?prod=PG112
VISIT OUR NEW RESTORATION PARTS SECTION, SAME GREAT SERVICE AS OUR 4-SPEED PARTS:
http://brewersperformance.com/store.asp
WE BUY 4-SPEED TRANMISSIONS & PARTS
NEW LOWER PRICE--Rebuilt OE factory Hurst shifter mechanisms from $149.95
NEW PARTS—We now stock all service parts for Hurst Shifters, see our website:
http://brewersperformance.com/products.asp?cat=132
We are the manufactures of the following parts:
Reproduction 1968-69 Console shift handles for A & B body cars from $241.57
1970 Column/reverse interlock linkage kits for B-body big block and E-body big/small block cars $279.95
Correct 1970 B-body console boot with rectangular opening for pistol grip shifter $89.95
New Big Block bellhousings, heat treated aluminum $329.95, steel dust covers $99.95
67-76 A-body and 66-74 B & E body ballstud frame brackets $39.95 ea
Torque shafts (Z-bars) for all popular A B & E body cars $89.95 ea
A-body big block clutch linkage kits, Hydraulic slave kits also.
Clutch pedal to torque shaft rods A, B & E bodies $59.95
Clutch pedal over center spings $49.95
Clutch pedal over center spring retention pins $19.95
Small block 10.5” bellhousing starter seal $39.95
Big block 10.5” & 11.0” starter shims/seals $12.95
Clutch pedal support firewall stud brackets for 66-74 B & E bodies $19.95 ea
Shifter linkage rod sets for A B & E body cars $124.95-$149.95 set
Transmission linkage operating levers for A B & E bodies $54.95-$59.95 set
Billet steel bearing retainers for 18 spline 4-speeds $129.95
Billet aluminum shifter mounting plates for A, B & E bodies, with all hardware $59.95
Clutch fork pivot brackets $19.95-$29.95
Synchronizer strut keys for 68-9 4-speeds $10.95 ea
Hurst shifter mechanisms to retain your stock Inland shift lever $299.95
Transmission side cover wiring clips, retains backup light wiring $8.95 pair
Conversion torque shaft kits for 10.5” small block bellhousings into 1963-66 A-body cars
We also stock:
New Hurst shifter mechanisms from $219.95
Bearing and seal kits from $99.95
Synchro rings $49.95 set/4
Restored factory Hurst shifter levers from $249.95
New pistol grips from $219.95, lenses, grips & bezels available
Shifter boots from $59.95
Shifter boot bezels from $29.95
Reverse indicator lamps $89.95, wiring harnesses from $29.95
Woodgrain shifter ball $39.95
Rebuilt transmissions from $1099.95
Polyurethane transmission mounts from $69.95
Speedometer cables from $39.95, speedometer pinion gears from $19.95
Torque shaft service kits from $59.95
New flywheels from $199.95, cast crank applications available
Bellhousings for all applications
Centerforce and McLeod clutch packages from $332.07
From one part to complete 4-speed conversion packages, we stock it all! Same day shipping on orders received by 2PM.
We accept Visa/MasterCard/Discover.
BREWER’S PERFORMANCE, INC.
10510 State Route 571
Laura, Ohio 45337
Phone:937-947-4416 or 937-698-4259 9am-5pm Monday-Friday
Fax:937-947-4419 24-7
#2427027 - 01/01/18 10:26 AM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
biff426 Offline
Loc: Delaware
For Sale
11 inch converter 66-up spline I don't know what brand it is it came in a car I bought. This converter flashed 2600 in a basically stock 440. Numbers on the converter 22856 12208 T37 19S this functioned perfect I changed the drivetrain in the car $150 plus shipping
TCI 141100 2400 stall for 65-back spline 727 trans. This was installed in a trans but never run the project sat for a few years then disassembled.
$200 plus shipping
dwmotorsports1@gmail.com or pm me here
#2427045 - 01/01/18 10:52 AM 70 440 SIX PACK 727 TRANSMISSION [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
*************SOLD***********
1970 440 SIX PACK AUTOMATIC TRANSMISSION CASE NOT COMPLETE PART # PK3410672 $1,500
***WE CAN SHIP***
E-MAIL:GDMUSCLECARPARTS@YAHOO.COM
SHOP # 904-272-1803
ORANGE PARK,FL.
Edited by gdmusclecar (01/05/18 05:08 PM)
#2427050 - 01/01/18 10:59 AM 70 340 SIX PACK 727 TRANSMISSION T/A CHALLENGER ,AAR CUDA [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
70 340 SIX PACK 727 AUTOMATIC TRANSMISSION PART #3410769,THE TAILHOUSING WAS CHANGED AT ONE TIME AND HAS A 72 DATE.CONDITION IS GOOD. $1,500
***WE CAN SHIP***
SHOP # 904-272-1803
ORANGE PARK,FL.
Edited by gdmusclecar (01/01/18 11:00 AM)
#2427051 - 01/01/18 11:00 AM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
RoadRunner Offline
Loc: East Aurora (Buffalo) NY
Lakewood Safety Housing 15335 for big block engine and A-833 transmission. I bought this for a project that went in a different direction. I installed it onto the motor and aligned it then realized it requires a 143 tooth flywheel. I don't know if these have age issues for racing, but it is over two years old. Has the original rings and hardware. I did not purchase the starter relocation kit which is required for 130 tooth flywheel.
$550 plus shipping (55lbs is shipping weight so probably not cheap to ship, do not have original box). New one at Summit are $742.
Located near Buffalo NY. PM me here if interested.
Edited by RoadRunner (01/01/18 11:01 AM)
68 Road Runner (383/4speed, post car w/decor pkg)
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
#2427333 - 01/01/18 04:26 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
mrrandyj Offline
Loc: CT
727, 518 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 727, 518, 46RH, and 46RE transmission. The rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. The piston is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a new seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 618, 46RH, and 46RE transmissions. I also have a kit that fits the early 62-66 727’s. The price for either rear kit is $75.00.
MADE IN THE USA!!!
There is a $8.00 shipping charge per order. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
#2427336 - 01/01/18 04:28 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE DUAL RING FRONT BILLET SERVO KIT
Dual ring billet front servo kits for 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. The front servo is responsible for applying the front band during the 1-2 shift. This servo is based off of the highly desired 71 and earlier Chrysler “small pin” servo that is ideal for use in performance transmissions, only this one is much better. The piston and cover are CNC machined out of solid 6061 billet aluminum and the shaft is CNC machined from prehardened 4140 steel. There are 2 return springs custom made out of stainless steel that will help eliminate the 2-3 shift overlap that these transmissions are known for. There is a custom made metal gapless sealing ring that seals the cover to the case, and also a o-ring in the cover that seals it to the shaft. The o-ring and the gapless ring work together to eliminate internal leakage and allows more oil get to 3rd gear where it is needed most. The piston has 4 total sealing rings, doubling the sealing capacity of the original Chrysler servos. This is a ready to install kit, all the sealing rings and springs are included. The price for this kit is $125.00 plus $8.00 for shipping.
100% MADE IN THE USA
If you have any questions or to place an order my email address is mrrandyj@aol.com
#2427337 - 01/01/18 04:30 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
904 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 1967 and newer 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE Dodge Plymouth Chrysler Jeep or AMC transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1 piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the piston, a heavy duty return spring that will help eliminate the 1-2 shift overlap, a new seal, and a .075” extra thick stainless steel retainer that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This is a complete ready to install kit, no extra parts are needed and it is 100% Made in the USA. The price for this kit is $75.00. There is also a $8.00 per order shipping charge.
#2427338 - 01/01/18 04:32 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
BILLET DUAL RING ACCUMULATORS
These will fit just about any torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RE, and 48RE, almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These are a great upgrade for all the 727s and 904s and are also perfect for replacing the plastic accumulator that Chrysler switched to in the late 80s. The plastic accumulators are known for cracking and causing problems in performance transmissions. I have done these 2 different ways: First is an exact stock replacement, this one will accept all the stock springs whether they go between the case and the piston or the piston and the valve body. These are perfect for the turbo diesel guys that have tighter aftermarket torque converters, or for the person doing a stock type rebuild on a gas transmission. Second is with a built in blocker rod that will stop the accumulator from moving in the bore and firm up shifts. No need to cut down round stock and make a blocker rod anymore, I did it for you. Comes with all 4 sealing rings. The price on these are $45.00 each. There is also a $8.00 shipping and handling charge per order.
These are 100% Made in the USA. If you have any questions or want to place an order email mrrandyj@aol.com Thanks for looking!!!
#2427341 - 01/01/18 04:35 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
727-48RE FRONT BAND STRUTS AND BILLET BAND ANCHORS
Heavy duty, double thick, billet steel front band strut and billet front band anchor for a Dodge, Plymouth, Chrysler, or AMC 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. This fits from the 1962 727 transmission, all the way up through the 2007 ½ Cummins Turbo Diesel 48RE, and everything in between. The OEM Chrysler front band struts are prone to bending, and the OEM band anchors are known for breaking in high performance and heavy duty applications. The band strut is CNC machined from 1/4” thick steel, which is twice as thick as the factory strut and it is black oxide coated for corrosion protection. The band anchor is also CNC machined from billet steel. Both are made in the USA. The price is $25.00 each, and includes shipping anywhere in the USA.
Email mrrandyj@aol.com
#2427342 - 01/01/18 04:36 PM Re: Mopar Transmission For Sale - 1st Quarter [Re: mrrandyj]
mrrandyj Offline
Loc: CT
47RH 47RE and 48RE Billet Rear Servo Kit
High performance, low/reverse billet rear servo kit for a 1994-2007 47RH, 47RE, and 48RE Dodge Cummins Turbo Diesel and SRT10 Ram truck automatic transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the aftermarket shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1-piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the billet aluminum piston, a heavy duty stainless steel return spring that will eliminate the manual 1-2 shift overlap, a new seal, and a extra thick CNC machined billet steel retainer that will not bend around the retaining ring and pop out of the case like the factory retainers do. This is a complete ready to install kit, no extra parts are needed. The price for this kit is $90.00 plus $8.00 for shipping.
#2427617 - 01/02/18 05:52 AM Re: Mopar Transmission For Sale - 1st Quarter [Re: moparts]
Pale_Roader Offline
Loc: the frozen wastes...
McLeod steel LIGHTWEIGHT flywheel. 130 tooth 10.5" 6-bolt, SFI, neutral balance. 22lbs (actual weight). Brand new in box. Comes with ARP bolt kit. $375 US.
Part's in BC Canada. Will ship, on your dime.
PM me here for more.
#2427626 - 01/02/18 07:16 AM Re: Mopar Transmission For Sale - 1st Quarter [Re: Pale_Roader]
rickseeman Offline
Loc: Little Rock, Arkansas
I got this aluminum hemi 4 speed case years ago for a project that has since been sold. It must be aftermarket because it doesn't have any casting marks or numbers on it. The hole is around 3.542" and the bolt circle is around 4-3/16". Looks to be in good condition. $250. Rick 501-519-7425
2011 Drag Pak Challenger
#2427828 - 01/02/18 01:50 PM Re: Speedometer drive gear housing, clamp and bolt [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
SOLD!
I have for sale a decent speedometer gear housing, clamp and attaching bolt. It’s clean and the speedo cable connect threads are excellent. There is no speedo gear though. I would like to get $10 for everything plus the shipping.
Edison, NJ
rider1454 at aol.com
Edited by PHYSIXX (01/02/18 02:31 PM)
25,150 Registered Members
186,820 Topics
FiTech w/timing control on LA 360 - What distributor?
by GoodysGotaCuda
15 minutes 50 seconds ago
Are we at this level for a 3.91 cone sure grip?
by NTOLERANCE
24 minutes 19 seconds ago
SS Mag 1967 Coronet R/T 440 Road Test - Anyone Have Pt 3?
by GTX MATT
31 minutes 56 seconds ago
Setting timing?
by dodge turbo
50 minutes 29 seconds ago
