Page 4 of 9 < 1 2 3 4 5 6 7 8 9 >
#2433023 - 01/11/18 06:08 PM BB Mopar cams for sale [Re: Rocket]
ou812 Offline
Loc: SoCal
Used BBM Comp solid roller cam 23-707-9 $230.00 shipped.
New BBM Comp custom hyd. FT cam: 241@ .050, .546 lift with a 112LCA $150.00 shipped.
New BBM Comp custom hyd. FT cam: 236-246@ .050, .519-.511 lift with a 114LCA $150.00 shipped.
New BBM Comp custom solid FT cam: 247-255@ .050, .549-.571 lift with a 108LCA $175.00 shipped.
Brian
mxnaked@yahoo.com
Brian Hafliger
#2433642 - 01/12/18 07:48 PM Re: BB Mopar cams for sale [Re: moparts]
DavidDean Offline
Loc: Lubbock,TX
A engine Herbert roller lifters
$150 + shipping
PM me for pics or more
#2433680 - 01/12/18 09:12 PM Re: BB Mopar cams for sale [Re: moparts]
DavidDean Offline
Loc: Lubbock,TX
M/T Race tubes to fit 14 x 32 tire #9558 $100.00 pair + shipping PM me for more info & pics
#2434016 - 01/13/18 03:39 PM Re: BB Mopar cams for sale [Re: DavidDean]
joez Offline
Loc: PA
BB mopar 528” low deck rotating assy. 4.505” bore, 4.15” stroke MP crank with B mains and mopar rod journals p5249337. 6.500 Grp rods with 1.031 pin 35 runs. 1 set used diamond pistons 1.360 pin height, 12 new diamond pistons, .043/.043/3/16, coated skirts, vert gas ports. Two sets used venolia rods with hemi pin and 12 used venolia pistons all fit b1mc or b1 heads. Joe – nitrojoez@yahoo.com – 570-436-5544 $1,500 obo plus freight. Located in North east PA
#2434019 - 01/13/18 03:42 PM Re: BB Mopar cams for sale [Re: joez]
joez Offline
Loc: PA
15x10 weld pro stars. 4.5" bolt pattern. 3.5" back spacing. Drilled for screws.
Joe – nitrojoez@yahoo.com – 570-436-5544 $200 obo plus freight. Located in North east pa.
#2434020 - 01/13/18 03:43 PM Re: BB Mopar cams for sale [Re: joez]
joez Offline
Loc: PA
B1 MC valves stealth titanium 2.400 intake and ss 1.780 exhaust 7 of each
#2434021 - 01/13/18 03:44 PM Re: BB Mopar cams for sale [Re: joez]
joez Offline
Loc: PA
Straightline Performance used roller cam. 3 bolt for big block.
Intake: lobe lift 0.481, ratio 1.7, valve lift 0.818, adv dur 313, dur @050 280, lobe cl 109. Exhaust: lobe lift 0.475, ratio 1.7, valve lift 0.808, adv dur 328, dur @050 294, lobe cl 117, LSA 113.
Joe – nitrojoez@yahoo.com – 570-436-5544 $100 obo plus freight
Edited by joez (01/13/18 04:04 PM)
#2434042 - 01/13/18 04:41 PM Turbo Action Converters [Re: moparts]
WadeMetzinger Offline
Loc: Tulsa, Ok
[IMG]https://photos.app.goo.gl/XzEt5km1VyDZa20p1[/URL]
Turbo Action 9" converter - 5,200 stall
In good working condition, just have several on the shelf. Only has 50 passes on it since it was sent to PTC to be freshened.
Stall number above from an NHRA Stocker 1969 Road Runner in I/SA class, 3,750lbs with 383 running 11.50s.
$400 shipped (call or text me 918-809-0987)
Edited by WadeMetzinger (01/19/18 02:28 PM)
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.70@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
#2434090 - 01/13/18 05:49 PM Mopar Performance 0.620” lift Small Block Solid Lifter Cam [Re: WadeMetzinger]
Rocket Offline
Loc: CT
I have a new Mopar Performance 0.620" lift flat tappet camshaft part # P4349266. It shows some very light pitting on two or three of the lobes around peak lift only which might buff out with emery paper. See the last picture for the light pitting. Bearing journals and the rest of the lobe areas are fine and smooth. Pictures show some dark spots which is discoloring from the original coating on the cam. Should be fine to run.
$110 shipped in the lower 48 states.
Contact procketrichard@hotmail.com for more information and pictures.
Edited by Rocket (01/14/18 11:59 AM)
#2434093 - 01/13/18 05:51 PM Cam Dynamics Solid Flat Tappet Camshaft for Small Block [Re: Rocket]
Rocket Offline
Loc: CT
For sale is a small block Cam Dynamics mechanical flat tappet camshaft from my 360 ci bracket motor. The specs are 0.585 lift with 310 degrees advertised duration and 275 degrees duration at 0.050 lift on both Intake and exhaust. This was used for 50 runs and ran a best of 10.48 in my W2 headed 360 ci Dart. The cam comes with the matching solid lifters matched to each cam lobe. Always run with Kendall 20W50 racing oil. Cam and lifters are in good shape. I have the cam card available for the full specifications.
Price is $150 shipped to lower 48 states.
#2434122 - 01/13/18 06:52 PM Re: Hurst Auto-Stick shifter, reverse valve body, 727/904 [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
SOLD!
I have for sale a complete Hurst Auto-Stick shifter setup that came from a 68 Dart with a reverse valve body 727 trans, P/N 3160014. This shifter and parts will also fit the 904 trans application. This setup includes the shifter mechanism, 5’ cable, neutral safety switch (comes with the shifter kit but isn’t needed and never installed for the 904/727), the plastic cover, P/N 1300055, and all the brackets, levers, nuts and bolts to do the installation. The original ball is included since a “T” handle with line lock button is attached to the shifter lever. Also included are the installation instructions for the shifter, the neutral safety switch and the cover.
https://www.summitracing.com/parts/huu-3160014
https://www.summitracing.com/parts/huu-1300055
I would like to get $150 plus shipping for everything.
Edison, NJ
rider1454at aol.com
Edited by PHYSIXX (01/22/18 07:25 PM)
#2434297 - 01/14/18 04:38 AM B1 originals [Re: PHYSIXX]
Joes66dart Offline
Loc: Middletown, Ohio
Sold sold sold. Ihave a set of b1 originals ported by koffels. I do not have flow sheets. The have k motion springs, titanium retainers. Comes with two sets of 1.7 rockers, B1 valve covers and b1 4500 intake. One exhaust valve needs replaced. Othe4 than that they are ready to go. Asking $3500 plus shipping. Heads located in Trenton ohio 45067. Easy way to contact is text @ 513-465-0699 or email me at 3joespettus@gmail.com. Sold sold sold
Joe
Edited by Joes66dart (01/21/18 08:57 PM)
#2434433 - 01/14/18 12:02 PM Small Block Hydraulic Tappet Camshaft - NHRA Stock Class [Re: Joes66dart]
Rocket Offline
Loc: CT
For sale is a used small block Cam Dynamics hydraulic flat tappet camshaft from an NHRA Stock class drag racing car. The Cam Dynamics part number is 10944 and the grind number is 206-2A. The specs are 0.455 lift intake and exhaust with 303 degrees advertised duration and 265 degrees duration at 0.050 lift on both Intake and exhaust. This was used for 1 season and has been wrapped in an oil soaked rag since. It is in very nice used shape. I have the cam card available for degreeing in the camshaft.
Price is $115 shipped to lower 48 states.
#2434435 - 01/14/18 12:04 PM 408 Stroker Rotating Assembly – New [Re: Rocket]
Rocket Offline
Loc: CT
I have a forged 408 stroker rotating assembly with all new parts to convert a 360 ci small block to a 408 ci stroker motor. Parts consist of a Molnar forged 4.00” crankshaft part # 360-4000FF6F, Eagle H-beam connecting rods part # CRS6123C3D, Mahle pistons and file fit rings part # SBM460030F05 and half groove Federal mogul main bearings for a Viper. Same journals as a 360 so you will have an extra journal's worth. One thing I am missing are the connecting rod bearings. I have not opened the crankshaft box and that is why there are no pictures of the crank in this post. I ordered the crankshaft directly from Molnar in the fall of 2017. The assembly is not balanced.
Price is $1,900 plus actual shipping cost.
#2434478 - 01/14/18 01:25 PM msd summit and vdo [Re: Joes66dart]
68DART360 Offline
Loc: Easton, PA
ALL PARTS BRAND NEW:
MSD black 6al ignition box with revlimiter PN 64253 $250
Summit racing equipment RACE harmonic balancer for 273-360 internal balance PN sum-b64277 $250 shipped
VDO Extreme 9000 rpm white face playback tach $250 shipped
VDO Eliminator 8 LED mega light shift light $50 shipped
PM me here I prefer money orders for payment but can do paypal also
Thanks, Jim
#2435098 - 01/15/18 02:43 PM Re: msd summit and vdo [Re: 68DART360]
SCDaytona Offline
Loc: New Milford, CT
2" Solid Aluminum carb Spacer $25-Sold
Jones mechanical Tachometer $50- SOLD
Mark Williams 9" Pinion Support #57601- $50
Ed Hamburger Distributor thrust support - never used. $10- SOLD
Racepak V300SD Datalink lite with the following: Ultra dash, oil pressure, oil temp, vacuum, water temp., fuel pressure,dual O2's, both rear shocks, 8 magnet collar, roll bar mount, all sensors and cables for the above. I have the full documnetation as well as the dongle for install. $4500.
Call 860-354-6701 or PM. Shipping not included
[img:center]IMG_0732 by Joseph Olejniczak[/url], on Flickr[/img] [img:center]IMG_0733 by Joseph Olejniczak, on Flickr[/img] [img:right]IMG_0737 by Joseph Olejniczak, on Flickr[/img]
Edited by SCDaytona (02/10/18 07:19 AM)
#2435130 - 01/15/18 03:49 PM CSR carbon fiber trans shield 727 REDUCED [Re: moparts]
Vincenzo Offline
Loc: Calcutta, Ohio
Excellent condition. Missing 1 bolt and 1 aluminum insert. Out of date for NHRA. Mancini wants $452.00. I'm asking $275.00 plus the ride. Please feel free to ask any questions. Thanks
Edited by Vincenzo (01/21/18 09:08 AM)
If you're not livin on the edge, you're taking up too much space.
#2435260 - 01/15/18 07:30 PM Re: CSR carbon fiber trans shield 727 [Re: moparts]
500ciDuster Offline
Loc: McGregor,Iowa 52157
Mopar Performance Roller Rockers&Shafts w/1.6 Ratio (Used).............$300
Ross Flat Top Forged Pistons for 340 +.030 (Used Very Little)..........$300
Sealed Power H116CP Pistons for 360 +.030 (NEW In Box).................$300
Everything Is Plus Shipping,P.M me or Email mcshanemitch@gmail.com
#2435756 - 01/16/18 02:17 PM Simpson Bandit Helmet size L worn 3 times [Re: moparts]
Swingin70 Online   content
Loc: ca
Received as a gift I decided to sick with my open face. Nearly brand new size Large Snell 2015 rated. Retail for $449.00
Asking $300.00
PayPal accepted.
Edited by Swingin70 (02/08/18 11:38 AM)
#2435914 - 01/16/18 06:27 PM Hoosier Slicks [Re: moparts]
cb1289 Offline
Loc: NJ
2 fresh 30x9-15 bias ply drag slicks, DO-7 compound. Purchased September 2017, tested once at the track. Exactly 5 quarter mile passes. Excellent condition. Have proof of purchase. Presently being stored in heated indoor area.
$300 plus shipping or local pickup in Dumont, N.J. 07628
PM me here on Moparts. Thanks.
Edited by cb1289 (01/16/18 06:30 PM)
62 Dodge Dart Wagon 65 Plymouth Satellite
25,149 Registered Members
186,752 Topics
Radiator opinions
by BlueRacer69
02/22/18 04:20 PM
Strange overheating problem....
by 67vertman
02/22/18 03:54 PM
64 Dodge 330 Mpls/St Paul craigslist
by peabodyracing
02/22/18 03:06 PM
Anybody have a good how to source on rebuilding 833 4speed
by BigHemiVegas
02/22/18 02:42 PM
