Page 2 of 69 < 1 2 3 4 68 69 >
#867759 - 12/01/10 02:27 PM Re: New Passon Performance 5 Speed update [Re: JamiePasson]
JohnRR Offline
Loc: U.S.S.A.
Jamie what are you going to use for a shifter?
That looks sweet, I'm in for one especially with a change in rear gears to 4:30's come spring time .
#867760 - 12/01/10 02:34 PM Re: New Passon Performance 5 Speed update [Re: JohnRR]
JamiePasson Offline
Loc: Sugarloaf, PA. USA
John,
Thanks! We made a custom 5 spd HURST shifter and made linkage to clear crossmember and floor. I don't have any pics with the shifter and linkage on. I will take pics at PRI and post them when we get back.
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
#867761 - 12/01/10 02:51 PM Re: New Passon Performance 5 Speed update [Re: DaytonaTurbo]
4speeds4me Offline
Loc: Sorrento, BC, Canada
Are the 3 different retainer OD's going to be available for this unit as well?
2 Demons...no, not my kids!
#867762 - 12/01/10 02:56 PM Re: New Passon Performance 5 Speed update [Re: 4speeds4me]
JamiePasson Offline
We are not using an integrated shifter. If you do that, you are just gonna have another tremec that doesn't fit. It isn't a stock shifter because it is 5 speeds. It is stock arrangement. The shifter and linkage will be part of the package when the transmission is purchased. We are making a 4.35" bearing retainer and a 4.80" bearing retainer. Sorry, no 5.125 OD size. Just not enough call for one. We have an adapter ring available for the 5.125" application though.
#867763 - 12/01/10 04:22 PM Re: New Passon Performance 5 Speed update [Re: JamiePasson]
jbc426 Offline
Loc: West Coast, USA
Hey look at that... Thanks jbc426. I'll get the hang of this computer thing yet! Forgive the bearing retainer bolts missing and sidecover bolts missing. Note the 5 bolt bearing retainer. That covers a tapered roller bearing with an O Ring seal. We went 5 bolt for increased bearing load capacity.
Wow! Beautiful work. I can hardly wait to "shake it on down into overdrive" with my 3.54's and cruise at 70mph to Hot August Nights or Mopars at the Strip in Las Vegas.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 3.73s
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3600 stall lock-up converter and 3.91's (closest thing to an automatic 5 speed going)
#867764 - 12/01/10 06:04 PM Re: New Passon Performance 5 Speed update [Re: jbc426]
Rhinodart Offline
Rhinotruck
Loc: Round Lake Beach, Illinoisy
Looks great, Jamie! I am in Florida right now but I probably won't make PRI this year, if I do I will look you up!
JB Rhinehart, Realist
2018 Carlisle All-Chrysler Nationals July 13-14
Hurst Nationals held in conjunction includes
1968 Dodge Dart and Barracuda Hemi Super Stock Reunion!
Expo Center across from the main gate, register online!
#867765 - 12/01/10 07:17 PM Re: New Passon Performance 5 Speed update [Re: JamiePasson]
fourgearsavoy Offline
Loc: Rittman Ohio
Once again an awesome product from Passon Performance
So are 1-4 in the side cover with fifth and reverse on the lower(reverse)selector shaft like a Nash/Richmond box?
Gus
64 Plymouth Savoy
Dana 60
#867766 - 12/01/10 07:24 PM Re: New Passon Performance 5 Speed update [Re: Jim_Lusk]
Alexdodge Offline
Loc: Eastern ohio
What, no 23 spline????
#867767 - 12/01/10 07:44 PM Re: New Passon Performance 5 Speed update [Re: Alexdodge]
Loc: Rittman Ohio
Why would you do that??? They built the 18 spline because the 23 spline wouldn't hold up to the power,weight,and traction.
Gus
64 Plymouth Savoy
Dana 60
#867768 - 12/01/10 07:56 PM Re: New Passon Performance 5 Speed update [Re: fourgearsavoy]
jcc Offline
No politics
Loc: Trumussia
Gus
But that was with 40? year old materials, I would think today that would be less of an issue, and Passon runs a business that caters to customer driven demands, so if there really is enough demand, why not a 23 spline in the future?
Seeking more civil pastures
#867769 - 12/01/10 08:05 PM Re: New Passon Performance 5 Speed update [Re: JamiePasson]
bp27 Offline
Loc: Vernon Ct.
I really can't answer anything about the CF clutches. In my opinion, they are 2nd or 3rd choice. I never liked them. Just my opinion though. To each his own.
#867770 - 12/01/10 08:13 PM Re: New Passon Performance 5 Speed update [Re: jcc]
Loc: Rittman Ohio
Gus
Did you ever compare the size of the teeth on a 23 spline to an 18 spline gear? The thickness at the root of the tooth is much larger and less prone to failure.The diameter of the drive pinion is also able to take more abuse as well.
Gus
64 Plymouth Savoy
Dana 60
#867771 - 12/01/10 08:25 PM Re: New Passon Performance 5 Speed update [Re: fourgearsavoy]
69Cuda340S Offline
Loc: MARYLAND
Finally a 5 speed option that doesn't require hacking up the car, and coming from a vendor with a great reputation too. I know they won't be cheap but if the price comes in reasonable the demand will be very high.
My Web Site: www.BillsGarage.info
#867772 - 12/01/10 08:31 PM Re: New Passon Performance 5 Speed update [Re: JamiePasson]
446acuda Offline
Loc: Charlotte, NC
So the front bearing will be a 307 or something similar?...or will they be tapered rollers? What rear bearing is in there?
#867773 - 12/01/10 08:32 PM Re: New Passon Performance 5 Speed update [Re: 69Cuda340S]
dart1962_440 Offline
Loc: Michigan
Any info available on the ratios for each gear?
#867774 - 12/01/10 09:17 PM Re: New Passon Performance 5 Speed update [Re: dart1962_440]
scatpacktom Offline
Loc: Phila Pa
I just want to know who is testing it
F.A.S.T T/A Challenger 340 six pack 4sp 11.48 at 123 on G60 15s F.A.S.T 71 Super Bee 440 six pack 4sp 11.49 at 122.99 on G70 14s Pure Stock 70 Duster 340 4 sp 13.15 at 105.76 on F70 14s
#867775 - 12/01/10 09:20 PM Re: New Passon Performance 5 Speed update [Re: scatpacktom]
4speeds4me Offline
Herb McCandless? I'd get in line for that job.
#867776 - 12/01/10 09:22 PM Re: New Passon Performance 5 Speed update [Re: JamiePasson]
AndyF Offline
Loc: Oregon
Looks great Jamie.
#867777 - 12/01/10 10:14 PM Re: New Passon Performance 5 Speed update [Re: AndyF]
68KillerBee Offline
Loc: Missouri
Very cool. It'll be a while before I can afford something like this, but it is awesome you came up with it. I'm sure it is well worth the wait.
Just curious on weight compared to an old one? I have the 23 spline in my car and could care less if I have to change to 18 spline. It just plain makes sense to use the 18 spline. I'm sure his investment costs are already high, so maybe if these sell well he will switch, but once again, why settle for second best.
Can't wait to Wonder if I'll bust my knuckles w/ my bench seat
Families rides: 68 Super Bee, 68 GTX 'vert, 73 Charger, (2) 2010 Challenger r/t's. All 3 pedal equipped. 70 AAR. 71 b'cuda
#867778 - 12/01/10 10:59 PM Re: New Passon Performance 5 Speed update [Re: 68KillerBee]
Jim_Lusk Offline
Loc: Fresno, CA
Very nice looking.
25,246 Registered Members
188,825 Topics
Accessory Belt Issue....... Help!
by StealthWedge67
Today at 12:13 AM
MOPAR/FORD OIL FILTER ADAPTER
by A/MP
Yesterday at 11:02 PM
A picture made by a friends son - trucks
by duster2
Yesterday at 10:17 PM
Driveway Dip Advice:
by Sunroofcuda
Yesterday at 10:05 PM
