Page 17 of 81 1 2 15 16 17 18 19 80 81
Re: 5 speed pricing info [Re: mprhound] #868059
04/20/11 01:11 AM
04/20/11 01:11 AM
Texas
mprhound Offline
mprhound  Offline
Texas
Jamie, any update on a time frame for release?
a bump maybe for a response
Re: 5 speed pricing info [Re: JamiePasson] #868060
04/26/11 05:39 PM
04/26/11 05:39 PM
Alberta, Canada
572hemi Offline
572hemi  Offline
Alberta, Canada
Need to get on the waiting list:
I just heard about this trans on the cruise to MATS, and went thru all the posts today, I want to thank you for all your efforts so far. I have a Keisler A41 4 spd OD auto in my 67 GTX, the 572 pump gas hemi (635 HP & 665 ft lb T )is too much for it and need a OD manual trans option, I too had looked at the Mcleod trans but not any more, also had looked at the RS option but not interested. I can keep this trans going for enough time if I don't lean on the engine a lot,but would hope one is available later this summer before I head back to AZ for the winter. I also have sent in a e-mail to your website so I hope you can find the time to get back to me soon
1967 GTX 572 HEMI 735 HP, 717 FT Lb T, , A-855 5 Speed, Dana 60 4:30 Gears, 30" Rear Tires
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868061
04/27/11 06:40 PM
04/27/11 06:40 PM
MA
Mass_Mopar Offline
Mass_Mopar  Offline
MA
Sorry if I missed it, but when's can we expect to get our hands on a copy? Is there a hydraulic clutch kit available? My '70 Charger is an original 383/4-speed car (23 spline) and I'd love to get rid of the Z-bar and upgrade to an 18 spline 5 speed!
Re: New Passon Performance 5 Speed update [Re: Mass_Mopar] #868062
05/06/11 11:52 AM
05/06/11 11:52 AM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
Hello Gang,
Here is an update to our 5 speed progress.
We currently have several units out there in a bodies being torture tested. We have made a design change to the shifter fork arrangement and also to the 5th gear synchronizer design. So far the design change has proved to be a change for the better so we are now testing for durability with our proprietary enhanced key spring design . We are also awaiting from the foundry a revised tailhousing pattern for E Body tails as well as B Body tails. More information to follow as things develop. Thank you for your patience. No product will be released until I am 100 percent satisfied.
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868063
05/06/11 02:06 PM
05/06/11 02:06 PM
Central ND
440custom Offline
440custom  Offline
Central ND
I really applaud Jamie's straight forward nature and I for one will no doubt be buying one of these bad boys in the future. I did buy an aluminum overdrive 4 spd from him and it's a work of art. Thanks Jamie!
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868064
05/06/11 10:22 PM
05/06/11 10:22 PM
WV.
Challenger_Nut Offline
WV.
Hello Gang,
Thank You! I would much rather wait and have something that is sorted out and trouble free!
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868065
05/07/11 09:59 AM
05/07/11 09:59 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Need to order a twin disc clutch this week, understand that new trans will be 18 spline. Unfortunatly don't have any 18 spline 4-speed boxes if 5-speed is excessively delayed.
What to do? Don't wish to order two different $1200 clutch setups.
Re: New Passon Performance 5 Speed update [Re: gdonovan] #868066
05/08/11 05:51 PM
05/08/11 05:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
why would you need to buy another clutch setup when you can just buy another disc , assuming the pressure plate is still good ?
Re: New Passon Performance 5 Speed update [Re: JohnRR] #868067
05/08/11 09:02 PM
05/08/11 09:02 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Discs, not disc.
Re: New Passon Performance 5 Speed update [Re: gdonovan] #868068
05/09/11 10:32 AM
05/09/11 10:32 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: New Passon Performance 5 Speed update [Re: 64dodge572] #868069
05/09/11 04:52 PM
05/09/11 04:52 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Twin disc package $1200???
http://brewersperformance.com/proddetail.asp?prod=MC64408
Depends on what your buying.
Re: New Passon Performance 5 Speed update [Re: gdonovan] #868070
05/09/11 08:54 PM
05/09/11 08:54 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
my dual disc was $1200.00 also.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: New Passon Performance 5 Speed update [Re: gdonovan] #868071
05/10/11 09:58 AM
05/10/11 09:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Discs, not disc.
are 2 discs $1200 ???
Re: New Passon Performance 5 Speed update [Re: JohnRR] #868072
05/10/11 05:19 PM
05/10/11 05:19 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Discs, not disc.
What is your point?
I'm expected to buy a clutch, drive my car about and then purchase replacement discs for said $1200 clutch setup after the 18 spline transmission is finally released.
I don't like wasting money, throwing away two expensive discs is not my idea of a good time.
Re: New Passon Performance 5 Speed update [Re: gdonovan] #868073
05/10/11 06:50 PM
05/10/11 06:50 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Nobody is forcing you to buy this transmission. Get over it, you're ruining the thread
Re: New Passon Performance 5 Speed update [Re: 68KillerBee] #868074
05/10/11 09:10 PM
05/10/11 09:10 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Asking for an ETA in regards to a product announced several months ago isn't unreasonable.
Get over it? I even offered to drive my car to PA and test on my dime and pay full retail to boot.
Re: New Passon Performance 5 Speed update [Re: gdonovan] #868075
05/11/11 01:28 AM
05/11/11 01:28 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Just find out the cost of the discs you need.
I want my fair share
Re: New Passon Performance 5 Speed update [Re: gdonovan] #868076
05/11/11 11:27 AM
05/11/11 11:27 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Guys, lets try to keep it civil. I understand your concerns. This is the way that I look at it, I am assuming that you have a Mcleod Twin Disc clutch. If you do, I will rehub your discs from 23 spline to 18 spline for you. As for a timeframe. We are working as fast as we can. As I stated before, I am not comfortable releasing anything until we are 100% happy with performance.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #868077
05/11/11 06:05 PM
05/11/11 06:05 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Thanks for your time on the phone today!
Re: New Passon Performance 5 Speed update [Re: gdonovan] #868078
06/10/11 01:50 PM
06/10/11 01:50 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
How are the modifications coming along, Jamie? I have the car up in the air with the exhaust off. This would be a perfect time for me to upgrade the transmission.
