Indy Modman Dimensions #2425873
12/30/17 03:53 PM
12/30/17 03:53 PM
Canada
WO23Coronet Offline OP
Canada
Does anyone have the dimensions of the opening of the Indy Modman? Looking to see if it’ll work for a project. I think they all have the same opening (BB, SB, Hemi etc) so a measurement from anyone should work. Width, Length and Depth
Re: Indy Modman Dimensions [Re: WO23Coronet] #2426728
12/31/17 10:09 PM
12/31/17 10:09 PM
Canada
Canada
Bump
Re: Indy Modman Dimensions [Re: WO23Coronet] #2426868
01/01/18 12:36 AM
01/01/18 12:36 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I'll give it another bump because I'm curious if anyone ever made any power with one, it always just looked like a shoebox lid with runners and carb mounts to me.
WIZE
In Car:
Re: Indy Modman Dimensions [Re: WO23Coronet] #2426874
01/01/18 12:55 AM
01/01/18 12:55 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I have one on my car. But I have to tell ya, sorry. No way in hell am I going up to the garage until it gets above 0° lol
Re: Indy Modman Dimensions [Re: WO23Coronet] #2426884
01/01/18 01:10 AM
01/01/18 01:10 AM
U
Uncle Barry Offline
Uncle Barry  Offline
U
If you can wait until tomorrow, I can give you the top plate dimensions (length and width). I don't really want to tear the top plate off the intake right now.
Re: Indy Modman Dimensions [Re: Streetwize] #2426887
01/01/18 01:15 AM
01/01/18 01:15 AM
U
Uncle Barry Offline
Uncle Barry  Offline
U
It works great for what I have. My car isn't a race car. It squeaked into the 10s with a modman. 528 hemi with 2 eddy 750s on it. Pump swill and full TTI exhaust. I wish someone would do a comparison between the modman and eddy intake myself...
Re: Indy Modman Dimensions [Re: Uncle Barry] #2426890
01/01/18 01:32 AM
01/01/18 01:32 AM
Canada
Canada
That’ll be much appreciated lol. It’s -22F here right now so I understand. The top plate dimensions would be good (length and width), also a rough depth of the plenum would be great as well if you could (just off the outside would be good for the depth)
Re: Indy Modman Dimensions [Re: WO23Coronet] #2426891
01/01/18 01:36 AM
01/01/18 01:36 AM
U
Uncle Barry Offline
Uncle Barry  Offline
U
thumbs ok. I'll do my best on the depth. I'll go up in the morning and measure it up for ya.
Re: Indy Modman Dimensions [Re: WO23Coronet] #2426945
01/01/18 04:05 AM
01/01/18 04:05 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Will look tomorrow if you need still .
I know on my 440 between a M1 and BG825 with 1"spacer and modman with twin 600s it was a wash HP wise .
BUT . Car slowed in the 60 and lost et , same MPH .
Could not get a good AFR , ran lots of jet/rod etc still showed lean . Even tried 4 hole spacers to improve signal . No help .
Added a full length filler to reduce plenum volume , inconclusive .
Felt great on the street .
May get a chance to try it on my 505 this year . I feel this will work better plus leaving on a 2 step at higher rpm
PS , measured plenum volume was approximately 5 litres
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Indy Modman Dimensions [Re: WO23Coronet] #2427028
01/01/18 01:29 PM
01/01/18 01:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Brent Wheeler runs one in N/SS. Car runs 10.0 index with 2 Edelbrocks.
Doug
Re: Indy Modman Dimensions [Re: WO23Coronet] #2427639
01/02/18 11:16 AM
01/02/18 11:16 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I have on on my street car with 2 - 600 Carter AFB's - compared to the factory cross ram - I lost the bottom end but gained top end over 5500 - overall I think its a turd of an intake - no runner length, lots of volume - very poor fuel distribution. It would make a great boosted intake! I can measure it up tonight - but if you have other choices go that direction.
Re: Indy Modman Dimensions [Re: DoubleD] #2427677
01/02/18 12:23 PM
01/02/18 12:23 PM
Canada
Canada
Thx, I’m considering it for a boosted application
Re: Indy Modman Dimensions [Re: WO23Coronet] #2427697
01/02/18 01:11 PM
01/02/18 01:11 PM
U
Uncle Barry Offline
Uncle Barry  Offline
U
I sent you a pm. thumbs
Re: Indy Modman Dimensions [Re: WO23Coronet] #2427703
01/02/18 01:40 PM
01/02/18 01:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I was sure there are measurements on the Indy or Mancini site but the MM is not far off my BDS intake.The MM is 4.5" tall I think and has longer runners than my BDS by 1/2".My carb plate is 14" x 6" o/c of the carb studs and is what the MM has I think.lmk if I can help.
Re: Indy Modman Dimensions [Re: WO23Coronet] #2428340
01/03/18 03:46 PM
01/03/18 03:46 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
Modman RB
over all height from work bench to carb pad= 5 and 3/8
from the floor of the plenum to the top rail ( below the lid )= 2 and 7/8
plenum width (inside to inside)= 4 and 1/2
plenum length (inside to inside)= 14 and 1/8
The intake will perform. You just have to be willing to put in the time testing and trying a few things to find what works for your combination. It works out of the box but it can be much better with some time.
As has been pointed out, I run it in NSS and can run under the A (10.00) index with it. Its on a plain jane 49x build with MW port SR heads and an Indy S2 flat tappet cam with 12.5 to 1 comp in a 3600lb car in NMCA NSS trim.
