Anyone have a BB Isky Red Zone lifter not in the motor?
#2425458
12/29/17 06:49 PM
12/29/17 06:49 PM
Posts: 14,478 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm looking for some pics of BB Isky Red Zone lifters with the EZ roll option..... Specifically the oil feed holes for the bushings.
Re: Anyone have a BB Isky Red Zone lifter not in the motor?
[Re: fast68plymouth]
#2425757
12/30/17 01:15 PM
12/30/17 01:15 PM
fast68plymouth
So. Burlington, Vt.
Thanks for the pics.
For some reason I thought they had pressure fed oiling to the axles, but apparently it's just splash oiling.
#2425771
12/30/17 01:39 PM
12/30/17 01:39 PM
fast68plymouth
So. Burlington, Vt.
I have a customer who I recently got some Red Zones for.
Apparently hey have changed the body design. They no longer have an oil band, but rather two relief cuts, one on the front, one on the rear...... Which do not intersect the oil gallery...... And he says there are no oil holes in the relief cuts(and even if there were, since the reliefs aren't connected to the gallery, I don't know how much good they would do). The only oil holes are located directly above the axles.
Sean, if you could post or send a pic of some with the pressure feed holes, that would be great.
The ones my customer has look like this:
#2425806
12/30/17 02:22 PM
12/30/17 02:22 PM
fast68plymouth
So. Burlington, Vt.
Okay great..... Thanks.
Do those only have that feed hole from the band, or is there also a hole above the axle?
#2425814
12/30/17 02:31 PM
12/30/17 02:31 PM
Posts: 4,003 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Do those only have that feed hole from the band, or is there also a hole above the axle? ONLY in the band, NOT perpendicular above the wheel.
#2425819
12/30/17 02:43 PM
12/30/17 02:43 PM
fast68plymouth
So. Burlington, Vt.
It's really early in the discovery process at this point, but my customer has had an issue with his cam/lifter situation. It may end up being like the "chicken and the egg"..... As to which was the cause of the problem.......but I was pretty surprised to learn his lifters didn't have any way to pressure feed the bushings.
#2425826
12/30/17 02:50 PM
12/30/17 02:50 PM
HardcoreB
Shelby Twp. Mi
It's really early in the discovery process at this point, but my customer has had an issue with his cam/lifter situation. It may end up being like the "chicken and the egg"..... As to which was the cause of the problem.......but I was pretty surprised to learn his lifters didn't have any way to pressure feed the bushings. But they DO...the hole above the axle is hydraulically feed via the wall clearance between the body and the bore. If it makes the builder feel any more confident you could groove a channel on the bore connecting the two feed holes.
[Re: HardcoreB]
#2425834
12/30/17 02:56 PM
12/30/17 02:56 PM
HardcoreB
Shelby Twp. Mi
It's really early in the discovery process at this point, but my customer has had an issue with his cam/lifter situation. It may end up being like the "chicken and the egg"..... As to which was the cause of the problem.......but I was pretty surprised to learn his lifters didn't have any way to pressure feed the bushings. But they DO...the hole above the axle is hydraulically feed via the wall clearance between the body and the bore. If it makes the builder feel any more confident you could groove a channel on the bore connecting the two feed holes. Doug is having luck using the lifter in the same way, with no groove AND the orifice actually drops below the feeding bore while on base circle. I would feel better with a small groove personally. and if you had to bush the block a longer bushing fully enclosing the lifter feed area would help too maintain constant feed pressure. IMO!!! lol
#2425843
12/30/17 03:06 PM
12/30/17 03:06 PM
fast68plymouth
So. Burlington, Vt.
On my customers motor, the oil hole above the axle is only in the bore for about the last .125 of lift. It's pretty far removed from the "source" of the oil, and rotated 90deg from it.
The hole is exposed to the crankcase most of the time.
This really doesn't seem to be a very effective way of oiling the bushing....... And maybe they don't need much oil. But we have a problem with this motor, and it's going to require a little more investigation to see if we can get to the cause of the problem.
#2425851
12/30/17 03:16 PM
12/30/17 03:16 PM
HardcoreB
Shelby Twp. Mi
On my customers motor, the oil hole above the axle is only in the bore for about the last .125 of lift. .....
This really doesn't seem to be a very effective way of oiling the bushing....... And maybe they don't need much oil. YES THEY DO I feel strongly that is the problem...you wont see an engine clamshell bearing live under these compromised feed conditions and they are subject to much less 'localized' loading.
#2425859
12/30/17 03:26 PM
12/30/17 03:26 PM
fast68plymouth
So. Burlington, Vt.
That's my position as well, but the Isky literature has claims about how "oil restrictor" friendly the bushings are, and the super hard material, etc....... So I'm leaving the door open for another explanation.
I feel the bushings in this motor failed because of a lack of adequate lubrication. That's what I'm going with unless I hear a good argument to the contrary.
The cam will go back to Comp, the lifters back to Isky...... See what that they come up with.
This is far from any type of "extreme" application either....... .430 lobe lift, 1.5 rockers, 600lbs open pressure.
#2425887
12/30/17 04:06 PM
12/30/17 04:06 PM
fast68plymouth
So. Burlington, Vt.
Well........these didn't last long at all. All 16 are toast in about 200 street miles...... With no WOT blasts yet.
Obviously, the bodies like the ones we're dealing with aren't a retrofitted BBC body, as the lack of oil band i think would block/severely restrict the oil flow in a BBC block.
I don't know why they dont all get the oiling like the ones in the pic of your actual BBC set. That really seems like the best solution to me.
A final decision won't be made until after we hear what Isky has to say, but at this point I'd say it's very unlikely bushed lifters with this oiling set-up will end up back in the motor.
