Page 2 of 2 < 1 2
#2409642 - 11/27/17 12:44 PM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
36viper Offline
Loc: MN
4 Sale- 65Ply Valiant factory 273 V/8 dual exhaust. Body straight,a 9 1/2.
New seats, headliner,bumpers, seat belts & tires. $4999 or B.O. New seats, headliner, belts. Well maintained and ready to drive. 90,000 orig. miles. Call Jerry "TEACHER'S PET"
#:973-214-594three NJ
Edited by 36viper (12/14/17 06:29 PM)
Edit Reason: added mileage
#2411231 - 11/30/17 09:50 AM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
694406 Offline
Loc: St.Louis, MO
*SOLD*
1969 Dodge Dart Western Sport Special. Project car. 318, auto. This car has sat for many years and does not run. It's originally from Nevada so the body is very solid. There is some rust in the front floor pans as it sat with the window partially down. It's largely complete less the seats. Like all desert cars the the seats were beat.
This is a great project that does not need any body panels.
$3,500
oojhnoo@aol.com
(314) 703-1865
Edited by 694406 (12/09/17 06:05 PM)
www.Musclemagnet.com
1969 Cuda 383 Q5
1969 Cuda 340 4-spd Notch
1969 GTS Black on White 340 4-spd
#2411500 - 11/30/17 07:48 PM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
JohnfromCT Offline
Loc: Stratford, CT
1972 Dodge Dart. All original, VERY clean 2 owner Slant 6 Automatic
Perfect interior. More pictures available if interested. Asking $5500.00
Contact me 203-258-5713
#2413162 - 12/04/17 02:39 PM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
slantsixgoon Offline
Loc: Washington
PRICE DROPPED! Now asking $2k obo.
THIS IS A PROJECT! It was a complete running car, but has been disassembled.
Pictures here: http://www.slantsix.org/forum/viewtopic.php?f=16&t=61662
1974 Duster main body with a Demon taillight panel and a 1968 Dart front end. Yes, the Dart front end bolted up with no problems. The Demon taillght panel fits fine, but needs to be redone. I welded it on bad.
This is a 1974 Duster that was built with a 225/904 combination, factory AC, power steering, manual brakes, and manual windshield washer fluid squirter. Column shift. Remote driver's side mirror. The car came from a dry climate, was factory undercoated to prevent rust, and had the factory AC with no vent holes in the bottom of the cowl. This means this is one of the most rust-free A bodies I have ever seen. The floors have a VERY light surface rust, but they are rock solid and need no welding. The rest of the body is also rust free after I patched the driver's rear quarterpanel behind the rear tire. The trunk floor has been sandblasted and coated with POR-15.
The good:
Upgraded to large bolt pattern factory disc brakes (new master cylinder)
upgraded to large bolt pattern 8 1/4 rear axle with 3.2 gears and a sure-grip
Upgraded to "340 bars" in the front torsion bars
Upgraded to heavy duty factory six leaf rear leaf springs from a 1974 360 Duster
New KYB gas-a-just shocks on all corners
New driveshaft cut and balanced to work with the 904/ 8.25 combination
Reinforced lower control arms (with sway bar tabs)
Rebuilt front end (all new rubber, tie rod ends, and ball joints, needs an alignment) upgraded to C body tie rod sleeves
Newer weatherstripping on the doors
Fresh rebuilt 1978 slant six 904 with 0 miles
95% of an original black interior for a Duster. Missing one door panel and the rest needs some regluing of the vinyl, but the hard plastic parts are all there
Chrysler Sebring bucket seats with the corect seatbelt power unit (need reupholstery)
Hard to find 1968 Dart fender top turn signal indicators
Extra 1968 only round side running lights
Both rear quarters were smoothed out by Maaco and are ready for cleaning and painting (rest of the car needs sanding and prep work after the taillight panel is repaired)
Comes with extra 1967 Dart fenders that need repair (but comes with repair panels for those fenders)
Extra fuel tank, door panels, and steering column from a 68 Dart
Fairly new medium green carpet comes with
Original running good condition engine comes with (I am guessing it has right around 100,000 miles, runs great)
New Spectre brand fuel tank
I can throw in some Super Six pieces for extra (manifold, carb, I think I have a kickdown)
The bad:
Basically needs all new interior. The plastic parts are all there and in good shape, but every cloth, vinyl, or fabric piece needs tobe replaced. Dash is cracked
Dashgauges don't really work
Needs repaint and minor bodywork. Lots of rock chips and parking lot dings, but nothing huge.
AC needs recharge and conversion (but is complete)
Car is partially disassembled. We were starting to get it ready for bodywork and painting so engine and trans are pulled
The taillight panel needs to be removed and properly fitted. This is my fault. I did it when my welding skills were basically nonexistent and I welded it on wrong. The Demon taillights don't fit. The taillight panel needs to be removed from the car, have the taillight mounting brackets welded in off the car so the panel will fit the taillights, then have that whole assembly reinstalled back in the car.
The rear 1/4s were hammered when we got the car, but I welded in some patches and we paid Maaco to smooth the panels out. They aren't perfect, but fine or a driver.
The 68 Dart front end pieces need some massaging and finishing. The guy I bought the fenders from had rolled the wheel opening lip over to make room for some tires. I roled them back and got them about 80% smoothed out, but they need finishing.
You will need to bring some tires and wheels since we are keeping the ones that are on it now.
I haven't found a new place to post photos since Photobucket went bad, but I am happy to send photos via email.
Overall, this car is a fine candidate for an easy project. All the hard parts have been found, the mechanical stuff is done, and the worst of the bodywork is also done (other than the tail panel). This is a perfect project for someone who is not afraid of body work and is looking for a good and fairly easy winter project.
Car is in Tacoma, WA. You will need a trailer and a truck bed or van to haul everythign away. It will take a while to empty everything out of both my garage and my storage unit. I will work with you on shipping, but I am hoping for a fast local sale.
Price? Well, that depends. I easily have over $6k in this, but I know I will never make anywhere near that much back. I am asking $2k obo. $2k will get you everything I have for it (except the Super Six stuff). Engine, rebuilt trans, all the interior stuff, everything. I know there are things I haven't listed above since I have been squirrelling away parts for this car for about ten years.
Price can go up or down depending on what you want. Don't want the engine or trans? No problem. Price goes down. Want some factory aluminum rims? I can probably throw those in with the full price. We can haggle. Waive enough cash in front of me and you might get a set of cop rims with near mint non-cop dog dish caps and trim rings. You get the idea.
Clean title, factory build sheet included. Send me a PM. Let's make a deal! Want to sell this quick.
Edited by slantsixgoon (12/07/17 12:04 AM)
#2414139 - 12/06/17 09:44 AM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
arbogb06 Offline
Loc: Federalsburg, MD
New to the forum and a friends suggested I post this up here:
1969 Barracuda Pro Street Roller; Over $16k invested not counting labor. I have lost interest and just want to see it finished to the 9's as it deserves. SOLD. No idea how to upload pictures. For more pictures and information see links below:
Edited by arbogb06 (12/08/17 05:30 PM)
#2415343 - 12/08/17 03:23 PM Re: A Body - Cars For Sale - 4th Quarter [Re: arbogb06]
chrisnben Offline
Loc: Madison, Wisconsin
Helping a buddy sell his fleet of cars- (2) A-bodies here; 1967 Dart & 1973 Dart Sport
The '67 2-dr post/sedan is set up as a pro-tour and/or race car start. Has front tube ties with IFS coilovers and center frame ties; 8-3/4 rear w/leafs (buyer has option of gears 3.55 or 3.91); ('75) 440 & 727 complete cores; new red & white bench interior (not pictured); 16" alloy wheels. Good title. Needs quarter patches, but overall- pretty solid start! $4500.
The '73 would make an excellent race car. No title, body is super solid- floors, quarters, rockers all rust free. No suspension; nice trim and rear glass. $800. takes it and well worth it.
Pics here in a album. More info upon request- pM me here. Cars located in Waterloo, WI/ Madison area.
https://benjaminlick.smugmug.com/Bernies-cars
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
#2415838 - 12/09/17 04:11 PM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
Slap Shot Offline
Loc: Dover,Pa
1969 Plymouth Barracuda (fastback) drag car has vin plate and clear title I will be pulling the 426 Hemi setup out of it and selling with a 448 wedge engine and auto trans this is a fresh set up that ran 10.50s in a Plymouth Duster.  $15,000 with wedge setup 717 577-0270 York,Pa
#2416291 - 12/10/17 01:36 PM 69 GTS Dart [Re: Slap Shot]
Matt M Offline
Loc: Georgia
1969 GTS Dart
340/Auto
Numbers Engine/Not trans
Original CA Car No rust ever.
This car is very nice and tight
Recently sorted out nicely by a Mopar fanatic.
Car needs Nothing.
Tons or original paperwork including Window Sticker and BS
$35,000
Would consider trade for a 70 0r 71 RR or GTX
Car must be a nice original example, metal most important to me.
No projects.
Thanks for the ad
Matt
miller 3504 pir @gmail.com
813 482 7631
#2418852 - 12/14/17 11:54 PM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
727builder Offline
Loc: Tennessee
1968 Plymouth Valiant 2 door post, Was factory /6 3 on the tree. Just a rolling body now. Sell whole or will part out. Car is located in Chattanooga Tn.
The good... Fenders are solid and straight as is both doors. Also have 2 extra 2 door post doors with glass that can go with the car, Still has the straight shift pedals in it. Have about 4 complete 68 grills that goes with the car. Manual steering, Man brakes. Good hood and deck lid.
The bad... Rust in floor pans. But have a brand new complete floor pan that goes with it. Some rust in trunk. And a little in driver quater, Little more in pass side quarter. Both quarters could be patched. Frame rails are good.
Car is still worth fixing but like i said will part out. $1200 for all of it. Pretty sure I have the title for it. Will add pic tomorrow. Can call or text me for info or more pictures. 423-402-6752
#2419371 - 12/16/17 01:13 AM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
E-Ticket Online   content
Loc: Louisville, KY
Pretty clean and straight body except the lower rear section of the quarter panels have some light rust but overall nice solid body. Tail light panel needs some straightening. Floor pans, trunk pan, engine compartment are all really nice as are the frame rails. Rear inner wheel wells have been cut and removed.
No motor or transmission, no interior to speak of other than what you see in the pictures. Has small bolt pattern front disc brakes (missing calipers), 7-1/4 rear end. All that comes with the car are in the pictures shown. Does come with a pair of 1980's Dodge van bucket seats with the flat seat tracks. The back seat (bottom) is not shown but is also included. Car has a Georgia title.
$1750.00
Please PM me if interested.
Thanks for the ad space Moparts!
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
#2419751 - 12/17/17 05:42 AM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
Ellies Dart Offline
Loc: South Bend, Indiana
1973 dart 4-door ,318ci ,auto ,air ,all there runs & drives Great , >>Hit on both passenger doors<< no rust car inner fenders ,trunk & all floor pans , Super Clean car in&out..$1650 with ralleys a $1500 with black rims and caps. callme574-274-8214 6am-6pm eastern time Zone or elliesdart@comcast.net for more pic's smoke
#2423922 - 12/26/17 12:13 PM 1972 plymouth duster [Re: 694406]
Morris'Mopars Offline
Loc: Illinois
Helping my dad sell his street car. its a 1972 Plymouth Duster that is street legal and has a clear title. Runs 7.80's in the 1/8th mile. Built 360 .557 came .060 over 727 with 3000 stall and manual valve body and Dana 60 out back with 4.88 gears. I think he has another ring and pinion. Factory interior with black buckets and hurst aftermarket shifter and Autometer gauges. Body is very nice and presentable. Located in Illinois $14000 Firm
www.morrismopars.com
#2425441 - 12/29/17 02:54 PM Re: A Body - Cars For Sale - 4th Quarter [Re: moparts]
Limelight Offline
Loc: Jacksonville, FL
https://photos.app.goo.gl/aEzwsUAHQOhQCib72 [img]https://photos.app.goo.gl/aEzwsUAHQOhQCib72[/img]
1967 Dart GTS 383 4 speed. 3.23 sure grip. Recent engine rebuild...KB hypereutectic, mild cam, alum radiator, new clutch and trans seals. TTI headers, Pypes exhaust. Mostly new original style disc brake system, new fuel system. New SS leaf sorings. Real deal. New headliner, carpet, vinyl top. New windshield/ rear window gaskets, installed 68 windhsield trim clips. New front bumper. New polygraphite suspension kit. Decoded Certicard. Originally AZ car, very solid.
$21500 obo.
Thanks!
Shiloh
Sdudley777@gmail.com
904-732-0292
Edited by Limelight (12/30/17 12:06 PM)
Page 2 of 2 < 1 2
25,067 Registered Members
185,583 Topics
Best head porting shops
by jkwedge540
01/16/18 05:37 PM
1977 Chrysler New Yorker Brougham
by moparmike1
01/16/18 05:27 PM
70 Super Bee Western Wisconsin
by peabodyracing
01/16/18 05:11 PM
70 Challenger Convertible Frame Rivets and Bushings
by Viperredcharger
01/16/18 05:11 PM
