Re: 03 1500 9 1/4 rear end swap issue
[Re: V10nacuda]
#2440797
01/26/18 12:20 AM
01/26/18 12:20 AM
Posts: 1,606 Pgh, PA
Bull1tt
Pgh, PA
Is it possible one of the front sensors went bad in the time you were trying to repair the rear? Pulled truck in garage in morning, and out at end of day. Lights on once swap was done. Going to look at the fuses, relay, and brake light switch this weekend.
[Re: Bull1tt]
#2440849
01/26/18 02:57 AM
01/26/18 02:57 AM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Still haven’t got a code reader on it yet, but I did take terminal off and touched them together for a while. That DID clear my check engine light, but ABS and Brake dash lights are still on. Well I'm going or try that on my Ram Van (engine light on) Make sure you've blead the brakes good, I replaced two lines and the ABS lights stayed on till the third time I bled them. I guess that little bit of air was messing it up.
[Re: Bull1tt]
#2441595
01/27/18 05:01 PM
01/27/18 05:01 PM
Bull1tt
Pgh, PA
[Re: Bull1tt]
#2441763
01/27/18 10:46 PM
01/27/18 10:46 PM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
There should be a stored code on the ABS module, not the PCM. If it shows up immediately at key on I would look at the wiring you had to modify for the sensor in the rearend or the sensor itself. If it doesn't show up until you start driving it may have to do with the tone ring that is in the diff carrier.
