Page 1 of 2 1 2 >
#2425105 - 12/28/17 07:49 PM 03 1500 9 1/4 rear end swap issue
Bull1tt Offline
Loc: Pgh, PA
My original Sure-grip 9 1/4 rear end blew up a while back, so I swapped the rear end from another 03 truck I had. Both trucks are two-wheel drive. Of course this one had a horrible pinion whine at 45-55 mph. I’ve run it for over a year, but it developed a vibration and the howl went away. I bought another rear from a 4wd ‘03, and the plug for the ABS tone ring is different. Luckily, the wires were cut, so I wired it to existing two wires. Colors were different, so I did the guess. Now my dash ‘Brake’ and ABS lights are on. Switched wires around to no help. Any ideas?
#2425148 - 12/28/17 08:41 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
savoy64 Offline
Loc: colorado
swap the sensor to the original one....
#2425197 - 12/28/17 10:09 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
Bull1tt Offline
Loc: Pgh, PA
Broke it removing the wires...
#2425201 - 12/28/17 10:17 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
Supercuda Offline
Buy another one
or
Put a piece of electrical tape over the offending light.
#2425436 - 12/29/17 02:45 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
Bull1tt Offline
Loc: Pgh, PA
Because the ABS light is on, no more cruise control...
I guess I’ll get another sensor
#2433148 - 01/11/18 09:33 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
Bull1tt Offline
Loc: Pgh, PA
I replaced the speed sensor with a new one for an ‘03. Replaced the plug with my original. The ABS and brake light are still on. Next step???
#2433167 - 01/11/18 10:18 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
stumpy Offline
Loc: Grand Prairie,Texas
Disconnect the battery and let it clear the codes. Does the rear axle assembly have abs sensors on it?
Edited by stumpy (01/11/18 10:21 PM)
#2433343 - 01/12/18 10:20 AM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
geo. Offline
Loc: n.c.
I don't know the answer to this,
but are all the tone rings the same?
Is it worth taking off the cover and counting the teeth?
#2434310 - 01/14/18 07:45 AM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
Bull1tt Offline
Loc: Pgh, PA
Disconnected the battery for a minute or so, ABS / brake lights are still on. Didn’t drive it yet, but did notice that when I turned cruise control on, the indicator lit up. Would not do that before. I’ll get it on a code reader and see what it says. The speed sensor that was in this rear end is a 2005 and up, so I guess this rear was changed out in the truck I got it from.
#2434312 - 01/14/18 07:51 AM Re: 03 1500 9 1/4 rear end swap issue [Re: geo.]
Bull1tt Offline
Loc: Pgh, PA
I don’t know that either, but they did change the speed sensor style in 05/06. That makes me wonder.
I had the cover off initially, to check condition, and I put $60 worth of Royal Purple gear oil in it. Cover stays on for now.
#2434443 - 01/14/18 12:08 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
stumpy Offline
You could always save the new fluid and reuse it.
#2434679 - 01/14/18 08:00 PM Re: 03 1500 9 1/4 rear end swap issue [Re: stumpy]
sportfury70 Offline
Loc: Cleveland Ohio
I believe you need to touch battery cables ends together for approx 15 seconds with headlights on to deplete any memory in computer. I've had to do this with my 07 minivan & also my 2011 ram 1500 to completely clear code.
Edited by sportfury70 (01/14/18 08:01 PM)
#2434782 - 01/14/18 10:21 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
135sohc Offline
Loc: SoMd, USA
Key dance to display codes doesnt cost anything.
#2434869 - 01/15/18 03:19 AM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
SNK-EYZ Offline
Loc: Lost in Space
When you connected the rear axle speed sensor wires back together how did you do it?
The correct way per Dodge is to solder them and used heat shrink tubing.
With the low voltage that the sensors use crimp connectors could be an issue.
Signature pic now hosted at Flickr!
#2435414 - 01/15/18 11:15 PM Re: 03 1500 9 1/4 rear end swap issue [Re: sportfury70]
Bull1tt Offline
Loc: Pgh, PA
I’ve never heard that before...
#2435416 - 01/15/18 11:16 PM Re: 03 1500 9 1/4 rear end swap issue [Re: SNK-EYZ]
Bull1tt Offline
Loc: Pgh, PA
Of course I used crimp style connectors...
#2435580 - 01/16/18 09:56 AM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
sportfury70 Offline
Loc: Cleveland Ohio
Ok. I hadn't either. What's it hurt to try it? Worked for me. Makes no difference to me. This is why I generally don't reply.
Edited by sportfury70 (01/16/18 09:58 AM)
#2437151 - 01/18/18 07:49 PM Re: 03 1500 9 1/4 rear end swap issue [Re: sportfury70]
Bull1tt Offline
Loc: Pgh, PA
Well, I only was saying I’ve never heard that before. Nothing more... and prob will try, can’t hurt!
#2438448 - 01/21/18 12:30 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
Bull1tt Offline
Loc: Pgh, PA
Still haven’t got a code reader on it yet, but I did take terminal off and touched them together for a while. That DID clear my check engine light, but ABS and Brake dash lights are still on.
#2438633 - 01/21/18 06:16 PM Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt]
Bull1tt Offline
Loc: Pgh, PA
Plugged in a code reader and it came up “NO CODES” on the OBD II scanner. So now I have no cruise control with these lights on the dash. (ABS / Brake) This rear end has no sensors for ABS, only wires go to speed sensor.
Now what?
Page 1 of 2 1 2 >
25,246 Registered Members
188,825 Topics
Accessory Belt Issue....... Help!
by StealthWedge67
Today at 12:13 AM
MOPAR/FORD OIL FILTER ADAPTER
by A/MP
Yesterday at 11:02 PM
A picture made by a friends son - trucks
by duster2
Yesterday at 10:17 PM
Driveway Dip Advice:
by Sunroofcuda
Yesterday at 10:05 PM
