#2422697 - 12/23/17 01:06 PM Help - 70 Charger taillight finish trim panel clips ??
ACME_Garage Offline
Loc: South
I'm having a hard time finding the (17) clips that hold on my taillight finish trim panel for my 1970 Charger.
Any information would be greatly appreciated.
I've checked most of the online Mopar Specialty parts stores and so far - no luck.
I may be calling it (searching for) the wrong thing.
Thanks Again
Mike Nelson
Denison, Tx
Edited by sunroof_charger (12/23/17 01:07 PM)
EK2 Sunroof Charger R/T
58 Corvette (LS1)
#2422762 - 12/23/17 05:01 PM Re: Help - 70 Charger taillight finish trim panel clips ?? [Re: ACME_Garage]
chargervert Offline
Loc: RI Deep in the rust belt
I would try Charger Specialties. I made the ones on my car. I used flat stock about 3/8 inch by 1/8 inch. I drilled holes in the stock,put screws in them,and tacked the heads. I ground off as much as possible. I cut the flat stock about 1 1/2 inches long. Because the flat stock is thicker than the factory clips,they do not have to be a spring loaded clip like the factory clips. I just slid them into the finish panel and pressed down on the tabs to keep them in place during the installation.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
#2422817 - 12/23/17 06:31 PM Re: Help - 70 Charger taillight finish trim panel clips ?? [Re: ACME_Garage]
70gtx440dana Offline
Loc: Lansing, MI
R/T Specialties has them:
link
Edited by 70gtx440dana (12/23/17 06:38 PM)
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
#2424090 - 12/26/17 05:54 PM Re: Help - 70 Charger taillight finish trim panel clips ?? [Re: 70gtx440dana]
ACME_Garage Offline
Loc: South
Thanks for the info.
Got them ordered !
Merry Christmas ~
Mike
58 Corvette (LS1)
#2425435 - 12/29/17 02:41 PM Re: Help - 70 Charger taillight finish trim panel clips ?? [Re: ACME_Garage]
3_RTs Offline
Loc: Missouri
I see that you have ordered them. For future reference, Mega Parts also sells them.
25,540 Registered Members
194,168 Topics
Ok Doctor Fiber. {Eric} Pasco County
by 340SIX
10/23/18 03:11 PM
1970 Charger Full Build
by Nick Stevanovski
10/23/18 02:45 PM
Latest and greatest on Small Block Trick Flow heads
by B3422W5
10/23/18 02:39 PM
2006 dodge magnum rear hatch wiring diagram
by HotRodDave
10/23/18 01:52 PM
