Re: 6.4 SRT cam into 5.7 eagle information
[Re: HotRodDave]
#2418896
12/15/17 09:44 AM
12/15/17 09:44 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Sure beats the $1000 plus you will spend on an aftermarket cam after you buy the incredibly over priced cam, the over priced phaser limiter, a tuner to keep the CEL off... With mods like he has the gains should be even more drastic. This truck barely seems noticably less TQ at low RPM power with a fat jump as the RPM goes up, no tuner or anything. It is still happy even loafing down the road @70mph under 2000rpm. Total agreement, My low end was noticeable when I had a load in the bed and I think that was because my truck has 3.55s in it. with the Higher ratio's I don't think it'll be as noticeable. and if you get a tune ....that will wake it up a LOT. I loved the cam swap and if I ever put a 5.7 back in the truck it will have the SRT cam in it. I tell any one who will listen if you have a VVT 5.7 put the 392 cam in it, you will not regret it.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: HotRodDave]
#2420814
12/19/17 03:45 AM
12/19/17 03:45 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Sure beats the $1000 plus you will spend on an aftermarket cam after you buy the incredibly over priced cam, the over priced phaser limiter, a tuner to keep the CEL off... With mods like he has the gains should be even more drastic. This truck barely seems noticably less TQ at low RPM power with a fat jump as the RPM goes up, no tuner or anything. It is still happy even loafing down the road @70mph under 2000rpm. Dave,Is this installed at factory specs using n OEM timing set? IE: no advancing of the cam timing for the smaller displacement engine? RT
[Re: HotRodDave]
#2421337
12/20/17 08:14 AM
12/20/17 08:14 AM
ric3xrt
Trumbauersville PA
When I did mine, I bought a new Phaser,chain lower sprocket, and tensioners, and gasket kit.......afterwards I found out I didn't need all those extras ..it is as simple as pull cam out replace cam, with the new chain I just lined up the marks, put it all back together , truck took 3 starts to idle, and honestly I was a sh!tIng bricks really thought I'd F'd up the whole thing, but on that 3rd start it idled , and WOOOOOOOOW WHOOOO the fun begain
[Re: HotRodDave]
#2424221
12/27/17 01:35 AM
12/27/17 01:35 AM
Posts: 24 Northern Colorado
EagleDuster
Northern Colorado
Hi guys, this is my first post... I've been on ForABodiesOnly.com for years but just recently got a 2014 5.7 Hemi to swap into my '70 Duster at some point and I'm looking for all the info I can find. Lots to read through in these threads, I actually found this one earlier when I was looking at replacement cams. The engine I got had a cam lobe/lifter failure so it needs a new cam and lifters; initially I thought I'd have to pay out the @$$ for a Comp piece and the phaser-limiter but now I'm just gonna get a 6.4L SRT cam for a non-MDS car. New springs and pushrods too.
One question regarding tuning for the bigger cam, if I get the MP PCM and Harness kit with the unlocked PCM would I be able to tune it myself? Regardless I'm guessing having a custom tune from a modern Hemi specialist would get the best results?
Khalid 1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
[Re: EagleDuster]
#2424428
12/27/17 03:47 PM
12/27/17 03:47 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
push rods are the same, no sense in changing them, the 5.7 springs you have will work, the 6.4 springs may be better, they use the same IH seat diameters and retainers so they drop right in. I did my swap without any tuning or the expensive 6.4 springs and its fine, a definte improvement with no other changes so if you can not change your tune you should still be in good shape. I used a MDS cam because I had already bought it for my 1/2 ton and its great, I doubt youd see 5 hp difference as the changes for MDS are super tiny, I have run MDS on a non MDS cam and it is fine that way also.
[Re: HotRodDave]
#2424562
12/27/17 07:34 PM
12/27/17 07:34 PM
EagleDuster
Northern Colorado
Thanks Dave good to know... I'm leaning towards upgrading the springs because this engine will be hooked to a manual transmission and I want to be able to redline this baby and speed-shift without worrying about breaking a spring and dropping a valve. I also mentioned pushrods because the one that was on the failed lifter got bent, guess I can just replace that one and call it good, no use in replacing all of them as a "preventative" measure? This 5.7 has 135k miles on it btw...
[Re: HotRodDave]
#2426017
12/30/17 08:18 PM
12/30/17 08:18 PM
Posts: 888 Wooster, Ohio
kpzbee
Wooster, Ohio
Thanks for posting this swap. I read about this before when I was doing research for my 5.7 swap I'm now doing into my Javelin. After seeing this again and doing some more looking, I bought the non MDS cam with PSI springs and Manley retainers for it. For a street car that gets driven a lot I figured this is the best bang for the buck over a custom cam.
"It's funny how one project eventually leads (or forces) you into another one. It's really just one endless project designed to induce insanity and bankruptcy."
