B-Body Stock steering coupler questions #2425057
12/28/17 09:04 PM
12/28/17 09:04 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
The stock b body power steering couple allows for some fore-and-aft (in and out) play when the car goes over bumps etc...
If I'm reading this right, the Borgeson website lists a u-joint coupler to use when replacing the stock power steering gearbox with a borgeson box.
Does the u-joint replace the stock coupler?
How does the u-joint coupler allow for fore-and-aft play
I can see how it works when the shaft angle is not straight
in alignment with the steering gear. Does it also allow for
fore-and-aft???
Steering gear gurus's please chime in!!
Thanks for the ad
Re: B-Body Stock steering coupler questions [Re: OLD318] #2425124
12/28/17 11:08 PM
12/28/17 11:08 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I would use this instead of the Borgeson U-joint.
http://bergmanautocraft.com/proddetail.php?prod=5-0010
Re: B-Body Stock steering coupler questions [Re: OLD318] #2425199
12/29/17 01:16 AM
12/29/17 01:16 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I would also buy this as I hate the stock metal clip
http://bergmanautocraft.com/proddetail.php?prod=5-0009
Re: B-Body Stock steering coupler questions [Re: dangina] #2456431
02/24/18 12:31 AM
02/24/18 12:31 AM
O
OLD318 Offline OP
OLD318  Offline OP
O
bump...does anyone have any experience using the borgeson u-joint in lieu of the bergman steering coupler?
Re: B-Body Stock steering coupler questions [Re: OLD318] #2478483
04/06/18 08:21 PM
04/06/18 08:21 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
I posted this question on the Borgeson website under mopar products... as you might have guessed I got the same nothing for an answer that I got here.... oh well.... thanks for the ad
Re: B-Body Stock steering coupler questions [Re: OLD318] #2479197
04/08/18 01:24 AM
04/08/18 01:24 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
It will trash either the breakaway pin in the column (67-up) or the upper bearing at the top of the column as the car flexes. Which it WILL.
The pot coupling was there for a reason. Lose it at your peril.
Rick
Re: B-Body Stock steering coupler questions [Re: OLD318] #2480201
04/09/18 10:11 PM
04/09/18 10:11 PM
nj
MoJoe Offline
MoJoe  Offline
nj
dangina have you used this coupling? Is the spring clip needed with this set up as well?
Re: B-Body Stock steering coupler questions [Re: Rick_Ehrenberg] #2481173
04/11/18 04:56 PM
04/11/18 04:56 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Rick,
I didn't say I was going to use the Borgeson u-joint, I was asking if it is acceptable to use it given the stock steering couplers design which allows for "in/out" play.
Why does Borgeson advertise and sell this on their website as a mopar "solution" if it doesn't work?
Also, for example How is a 2003 Ford F-150 able to use a u-joint
and not a pot coupler?
Re: B-Body Stock steering coupler questions [Re: OLD318] #2481257
04/11/18 08:41 PM
04/11/18 08:41 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Typically newer cars have a slip yoke style steering column. My experience has been that it is primarily that way so that it can be assembled easier in the plant.
That said, I have a borgeson ujoint.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: B-Body Stock steering coupler questions [Re: GoodysGotaCuda] #2481808
04/12/18 08:08 PM
04/12/18 08:08 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
What are you running it on? A-body, B-Body, E-body...?
have you had any issues going over speed bumps etc?
