#2424303 - 12/27/17 08:30 AM 0-w40 oil question
AeroMonte Offline
Loc: S.E. Missouri
I read somewhere that I should not be using 0-W40 oil as recommended by Mopar in our Hellcat and Demon cars. Now I can't find the article back. Wouldn't this void the warranty if I don't? The article said there were several engine failures because of this oil and I really don't want to chance it if it is true. Looking for insight from those smarter than me.
#2424337 - 12/27/17 09:42 AM Re: 0-w40 oil question [Re: AeroMonte]
A39Coronet Offline
Loc: Usa
What does the manufacturer recommend? Anyone else doesn't matter, as they didn't design the engine and are likely going off of some sort of archaic information.
#2424371 - 12/27/17 11:01 AM Re: 0-w40 oil question [Re: AeroMonte]
AeroMonte Offline
Loc: S.E. Missouri
Manufacturer says 0-W40, but if there are issues I want to know
#2424382 - 12/27/17 11:24 AM Re: 0-w40 oil question [Re: AeroMonte]
A39Coronet Offline
Loc: Usa
If there were issues, Mopar/Dodge would be the first to know, and the first to let customers know. Engineers came up with the oil recommendations for a reason.
#2424411 - 12/27/17 12:22 PM Re: 0-w40 oil question [Re: A39Coronet]
sixpackgut Offline
Drag Week Mod Champion
Loc: Charleston
Better fuel milage. Thats it. The only reason OEM's require 0 weight oil. Blame it on the govt
#2424437 - 12/27/17 12:54 PM Re: 0-w40 oil question [Re: AeroMonte]
A39Coronet Offline
Loc: Usa
Oh I don't doubt that one bit...but I'm sure these engine was designed with those restrictions in mind.
#2424439 - 12/27/17 12:55 PM Re: 0-w40 oil question [Re: AeroMonte]
HotRodDave Offline
Loc: Kalispell Mt.
the much tighter tollerances in the modern engines is why they need 0 weight, the thicker it gets the more it is like glue with that tight and precise of a tollerance. MPG on a demon or even a hellcat is insignificant. If they thought it was going to destroy and engine with that 60K warranty and they could solve it by recomending 5 or 10 weight they would be all over it.
#2424567 - 12/27/17 04:41 PM Re: 0-w40 oil question [Re: AeroMonte]
EagleDuster Offline
Loc: Northern Colorado
I would be more concerned with voiding the warranty than blowing up my engine while it's still under said warranty... Dealers will try to find any stupid little reason to deny a warranty repair. I know there was a guy on YouTube with a Hellcat Charger, something broke in the supercharger system and his dealer refused to fix the car under warranty because he had an aftermarket cold-air intake. He finally did get it fixed for free but not after a whole bunch of legal BS getting second and third opinions and communicating directly with FCA on the issue which took a few months IIRC.
Khalid
1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
#2429631 - 01/05/18 06:32 PM Re: 0-w40 oil question [Re: EagleDuster]
mike s Offline
Loc: Mi,U.S.A.
I would not use any oil that was not factory fill. The oil was formulated specifically for the engines. Very different oil than reg syn.
Leave the gun.......take the Cannoli's....Mike
#2429666 - 01/05/18 07:55 PM Re: 0-w40 oil question [Re: sixpackgut]
Supercuda Offline
Loc: up yours
The ignorance in this statement is overwhelming and a prime example of why the OP should listen to the manufacturer and not some internet clown.
Do you even know what 0w40 means?
No, you do not.
Educate yourself
http://www.upmpg.com/tech_articles/motoroil_viscosity/
Don't be the exception.
#2429984 - 01/06/18 12:14 PM Re: 0-w40 oil question [Re: AeroMonte]
racerhog Offline
Loc: Monrovia, So-Cal, USA
Ouch.. Hot Rod Dave it the nail on the head...tolerances...
Bob(Cowboy)Hogan
Monrovia So-Cal
25,538 Registered Members
194,156 Topics
Window Mechanism Grease
by dart4forte
10/23/18 12:55 AM
W2 heads- How much lift is lost at the valve?
by viperblue72
10/23/18 12:53 AM
HOW MUCH are you going to throw at the LOTTO ....
by Doc Fiberglass
10/22/18 11:54 PM
1971 Challenger A78 question.
by challenger6pack
10/22/18 11:47 PM
