Re: 0-w40 oil question
[Re: A39Coronet]
#2424411
12/27/17 03:22 PM
12/27/17 03:22 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
If there were issues, Mopar/Dodge would be the first to know, and the first to let customers know. Engineers came up with the oil recommendations for a reason. Better fuel milage. Thats it. The only reason OEM's require 0 weight oil. Blame it on the govt
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: AeroMonte]
#2424567
12/27/17 07:41 PM
12/27/17 07:41 PM
Posts: 24 Northern Colorado
EagleDuster
Northern Colorado
I would be more concerned with voiding the warranty than blowing up my engine while it's still under said warranty... Dealers will try to find any stupid little reason to deny a warranty repair. I know there was a guy on YouTube with a Hellcat Charger, something broke in the supercharger system and his dealer refused to fix the car under warranty because he had an aftermarket cold-air intake. He finally did get it fixed for free but not after a whole bunch of legal BS getting second and third opinions and communicating directly with FCA on the issue which took a few months IIRC.
Khalid 1970 Plymouth Duster, 1993 Jeep Cherokee 4x4
[Re: EagleDuster]
#2429631
01/05/18 09:32 PM
01/05/18 09:32 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
I would not use any oil that was not factory fill. The oil was formulated specifically for the engines. Very different oil than reg syn.
Leave the gun.......take the Cannoli's....Mike
[Re: sixpackgut]
#2429666
01/05/18 10:55 PM
01/05/18 10:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If there were issues, Mopar/Dodge would be the first to know, and the first to let customers know. Engineers came up with the oil recommendations for a reason. Better fuel milage. Thats it. The only reason OEM's require 0 weight oil. Blame it on the govt The ignorance in this statement is overwhelming and a prime example of why the OP should listen to the manufacturer and not some internet clown. Do you even know what 0w40 means? No, you do not. Educate yourself http://www.upmpg.com/tech_articles/motoroil_viscosity/
