Steel slot 15" wheels? #2424376
12/27/17 02:13 PM
12/27/17 02:13 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
I have this 39 Dodge truck project I'm working on, and I think I would like to put the old school 15" chrome steel slots on it (like the rear wheel in this picture). I've been looking through the Summit wish book and a few other sources but have not found any. I suspect they are just not popular these days.
I have a pair that are a little rough, with rust pits near the joint of the wheel center and the rim. I would like to find a set of 2 or 4 that are in better shape then the ones I have that won't break the bank.
Do any of you guys know where a source for the chrome slots might be? Thanks, Gene
Re: Steel slot 15" wheels? [Re: poorboy] #2424398
12/27/17 02:58 PM
12/27/17 02:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Steel slot 15" wheels? [Re: poorboy] #2424424
12/27/17 03:41 PM
12/27/17 03:41 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Facts are stubborn things.
Re: Steel slot 15" wheels? [Re: poorboy] #2424434
12/27/17 03:53 PM
12/27/17 03:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Haunt the swap meets.
Re: Steel slot 15" wheels? [Re: poorboy] #2424444
12/27/17 03:59 PM
12/27/17 03:59 PM
Wisconsin USA
themoparmanjc Offline
Wisconsin USA
Had a factory set that came on an 84 d150 marksman. I believe they were optional on trucks and vans up until 85. Best bet would be to keep checking junkyards or truck forums. They’re aren’t many around anymore. Wish I would’ve kept the ones I had on the marksman before it went to scrap.
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
Re: Steel slot 15" wheels? [Re: poorboy] #2424489
12/27/17 04:53 PM
12/27/17 04:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check Craigslist. I found a pair in the DFW area for $75.
Re: Steel slot 15" wheels? [Re: poorboy] #2424556
12/27/17 07:15 PM
12/27/17 07:15 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
That is kind of what I expected I was going to hear. I probably should mention that I need the 5 on 4 1/2" bolt pattern, and probably a 15" x 6", 7" or maybe up to an 8" wide wheel, backspacing isn't much of an issue. I really don't want the dual pattern wheels if I can avoid it. I'll look on Craig's list. Thanks guys. Gene
Re: Steel slot 15" wheels? [Re: Supercuda] #2425832
12/30/17 02:55 PM
12/30/17 02:55 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By Supercuda
Swing and a miss.
Not at all what we are looking for.
We are talking about the chrome steel wheel designed to look like a five slot aluminum wheel.
You knew that right?
I haven't looked too hard but I can't find them new.
Except for the ones linked above and they are crazy expensive for what they are.
Although, given the current economy I guess they are in line with other similar products.
I have mechanical Aptitude.
I can screw up anything.
Re: Steel slot 15" wheels? [Re: poorboy] #2425882
12/30/17 04:00 PM
12/30/17 04:00 PM
Freeport IL USA
poorboy Offline OP
poorboy  Offline OP
Freeport IL USA
Duster2 may have me hooked up! That was much faster then I thought it was going to take. Gene
