differant size for converter nose for 5.7 to 6.1 crank #2424081
12/26/17 08:37 PM
12/26/17 08:37 PM
Walhalla, SC
BlueDart Offline OP
BlueDart  Offline OP
Walhalla, SC
has anybody ran into this we just rebuilt a 5.7 using a 6.1 crankshaft while installing engine found that the torque converter is to big to fit in the crank pilot its in a 2004 ram 1500 4x4 thanks for any help
Re: differant size for converter nose for 5.7 to 6.1 crank [Re: BlueDart] #2424100
12/26/17 09:24 PM
12/26/17 09:24 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Is it possible a bushing or a bearing is still in the crank? (If the motor was out of a standard car). I’ve never heard of there being any difference
Re: differant size for converter nose for 5.7 to 6.1 crank [Re: BlueDart] #2424123
12/26/17 10:10 PM
12/26/17 10:10 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
6.1s(and5.7s) that had a Nag transmission behind them,have a bushing pressed in there for the nose of the Nag converter. It's a PIA to get out but once it's out you'll be fine.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: differant size for converter nose for 5.7 to 6.1 crank [Re: ric3xrt] #2424139
12/26/17 10:41 PM
12/26/17 10:41 PM
Walhalla, SC
BlueDart Offline OP
BlueDart  Offline OP
Walhalla, SC
yes sir just figured that out split it with a die grinder collapsed with a punch came right out thanks for you reply
