Help - 70 Charger taillight finish trim panel clips ?? #2422697
12/23/17 04:06 PM
12/23/17 04:06 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
I'm having a hard time finding the (17) clips that hold on my taillight finish trim panel for my 1970 Charger.
Any information would be greatly appreciated.
I've checked most of the online Mopar Specialty parts stores and so far - no luck.
I may be calling it (searching for) the wrong thing.
Thanks Again
Mike Nelson
Denison, Tx
Re: Help - 70 Charger taillight finish trim panel clips ?? [Re: Texican] #2422762
12/23/17 08:01 PM
12/23/17 08:01 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
I would try Charger Specialties. I made the ones on my car. I used flat stock about 3/8 inch by 1/8 inch. I drilled holes in the stock,put screws in them,and tacked the heads. I ground off as much as possible. I cut the flat stock about 1 1/2 inches long. Because the flat stock is thicker than the factory clips,they do not have to be a spring loaded clip like the factory clips. I just slid them into the finish panel and pressed down on the tabs to keep them in place during the installation.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Help - 70 Charger taillight finish trim panel clips ?? [Re: Texican] #2422817
12/23/17 09:31 PM
12/23/17 09:31 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
R/T Specialties has them:
link
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Help - 70 Charger taillight finish trim panel clips ?? [Re: 70gtx440dana] #2424090
12/26/17 08:54 PM
12/26/17 08:54 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Thanks for the info.
Got them ordered !
Merry Christmas ~
Mike
Re: Help - 70 Charger taillight finish trim panel clips ?? [Re: Texican] #2425435
12/29/17 05:41 PM
12/29/17 05:41 PM
Missouri
3
3_RTs Offline
3_RTs  Offline
Missouri
I see that you have ordered them. For future reference, Mega Parts also sells them.
