6.4 cam into '12 5.7 hemi questions
#2424088
12/26/17 08:51 PM
12/26/17 08:51 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Asked in another members thread, but no replies... so figured start a new one.
What is the part # for the cam? Also can you use the mds style in a motor without mds? I'm not sure I got the correct part #s, but looks like the mds style was a lot cheaper is reason I ask. I have a 2012 5.7, the block I'm using was a 6sp car, so no mds, but could I still use the cam and would I need to use the mds style lifters(which I have already).
Also what valve springs could I use that won't break the bank. I paid 500 for the whole engine, don't want to spend that on springs. I saw some option from a google search, but figured a lot could be second hand info.
Engine will be swapped into my cuda, will be running megasquirt system, so tune and so on isn't an issue.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 6.4 cam into '12 5.7 hemi questions
[Re: Silver70]
#2424182
12/27/17 12:00 AM
12/27/17 12:00 AM
Silver70
Rust Belt, SW PA
That 5037379BC is 200 or so more than the mds cam, I'm cheap, so would go with the mds style, plus the cost of non mds lifters on top of that.
I thought the 6.4 springs wouldn't work on eagle heads. I thought I read that.
Also what pushrods?
[Re: Silver70]
#2424190
12/27/17 12:13 AM
12/27/17 12:13 AM
Posts: 12,415 Kalispell Mt.
HotRodDave
Kalispell Mt.
6.4 springs will drop on perfectly, push rods are the same between both motors
[Re: ric3xrt]
#2424195
12/27/17 12:28 AM
12/27/17 12:28 AM
Posts: 4,254 Canada
WO23Coronet
Canada
The automatic mds cam is part # 5038419AB Stick Non-MDS Cam part # is 5037379BC You can use the MDS cam in a non MDS Engine , but keep in mind that the lobes that have those (MDS)lifters are designed to take up the extra lash. I would use the MDS lifters with the MDS cam. But if it were me and putting this combo in a older application, I'd go with the 5037379BC cam should be worth 15-20hp over the MDS cam because of the more uniform lobes. As for valve springs use the 6.4s 5037382BC $13 apiece, $210 for 16 I thought it was just a slight variation in the opening ramp and the rest of the specs were the same? (MDS VS NON-MDS)
[Re: Silver70]
#2424431
12/27/17 03:50 PM
12/27/17 03:50 PM
HotRodDave
Kalispell Mt.
The difference is super tiny and I would be shocked if there was a 15-20 hp difference, maybe 5 hp I would be. If they were that different then chrysler would have had to have different HP ratings.
[Re: Silver70]
#2425301
12/29/17 12:33 PM
12/29/17 12:33 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
This what My experience with the two cams has been. My niece Taylor and her twin brother Tiylar , both have 1500s her truck is a 2014 RCSB 4x2, 44k, his is a 2009 4x2 RCSB 75k. We did the MDS cam swap in June on her truck, after an average of 3 pulls HP/TQ = 315/340 stock, no tune, no aftermarket anything, after the 392MDS cam was installed HP340@5500 TQ 375 @4400, after tuning was 355/380. His truck same dyno in September made 306/336. His buddie’s dad told him that the Non-MDS was the way to go, after install, 345 @5600, 390@ 4400, after tuning was 365/410, but his truck made 5-20 Hp more from 2000-5000 and 10 more from 5000-5800. I didn’t dyno my 2014 RCLB 4x2 truck before I did the cam swap, after the swap I had my truck on the dyno my non-tune number was less than hers #’s by 5ish, my after-tune numbers were better than hers by 5ish, same dyno but mine was in April
The 392-short block (with Eagle heads) that was in my truck made 400HP@4300 and 393 TQ @5300 with the MDS Cam, NON- MDS Wass 407HP, and 400TQ, but from 2500-4700 the Non-MDS made an average of 20 more Hp and 25 more TQ So yes, you are correct 5 Hp, best case is max 10 more peak HP but thru the RPM band the Non-MDs cam is a better choice for max effort, broader, smoother curves thru out the RPM band, is it worth the $ 175-200 difference only the end user can decide, but considering after market VVT cams are in the $600-800 range…. bang for the buck is still awesome. Now the 428 in my truck now with Eagle heads was making 452 with the Non-Mds cam, and made 440 with the MDS With Comp Cams # 201-424-17 my 428 is pulling 485 hp on the dyno paid $635 for this cam, $400+ what I spent on the Non-MDS for 30 more HP.
