#2424081 - 12/26/17 05:37 PM differant size for converter nose for 5.7 to 6.1 crank
BlueDart Offline
Loc: Walhalla, SC
has anybody ran into this we just rebuilt a 5.7 using a 6.1 crankshaft while installing engine found that the torque converter is to big to fit in the crank pilot its in a 2004 ram 1500 4x4 thanks for any help
#2424100 - 12/26/17 06:24 PM Re: differant size for converter nose for 5.7 to 6.1 crank [Re: BlueDart]
WO23Coronet Offline
Loc: Canada
Is it possible a bushing or a bearing is still in the crank? (If the motor was out of a standard car). I’ve never heard of there being any difference
#2424123 - 12/26/17 07:10 PM Re: differant size for converter nose for 5.7 to 6.1 crank [Re: BlueDart]
ric3xrt Offline
Loc: Trumbauersville PA
6.1s(and5.7s) that had a Nag transmission behind them,have a bushing pressed in there for the nose of the Nag converter. It's a PIA to get out but once it's out you'll be fine.
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2424139 - 12/26/17 07:41 PM Re: differant size for converter nose for 5.7 to 6.1 crank [Re: ric3xrt]
BlueDart Offline
Loc: Walhalla, SC
yes sir just figured that out split it with a die grinder collapsed with a punch came right out thanks for you reply
25,246 Registered Members
188,825 Topics
Accessory Belt Issue....... Help!
by StealthWedge67
Today at 12:13 AM
MOPAR/FORD OIL FILTER ADAPTER
by A/MP
Yesterday at 11:02 PM
A picture made by a friends son - trucks
by duster2
Yesterday at 10:17 PM
Driveway Dip Advice:
by Sunroofcuda
Yesterday at 10:05 PM
