Re: 67 jeep Gladiator rear drum removal
[Re: dvw]
#2421349
12/20/17 09:22 AM
12/20/17 09:22 AM
Posts: 1,093 It's beer:30 somewhere
adventurer
Never worked on one of these Jeeps, but have worked on a few tampered axle set ups. It has been my experience that cutting off the studs won't help you get the drum off as a matter of fact it would make it impossible to get the drum off if you cut the studs off. You use the studs to bolt the puller too and push against the axle because the drum assembly is stuck on the taper. You are probably going to have to bite the bullet and buy the puller or maybe you can find someone with the puller that you can borrow it from. Maybe check with your local auto parts store to see if they have one in their loan a tool program.
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
