Harbor Freight Engine Cherry Picker / Lifting an Engine
#2421945
12/21/17 06:17 PM
12/21/17 06:17 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
So, maybe it's just me or maybe the Harbor Freight instructions just suck, but I'm trying to put hydraulic fluid into my 2 ton Harbor Freight Cherry Picker so that I can lift my engine and fix my motor mounts or add shims. The instructions mention to remove an oil fill cap and to pour oil into the cylinder until it overflows; however, nowhere else in the entire instruction manual does it mention which hole is the oil fill hole. So, naturally I look at the cylinder and say, "Hey there is this rubber fitting and this hole is at the highest point of the cylinder, maybe that's it." So, I yank the rubber fitting, which was a pain in the butt since it's tapered, and grab my bottle of hydraulic fluid and dribble it inside. Not knowing if it's doing anything or even filling, I say to myself, "Let's test to see if it's actually doing anything." I grab the rubber fitting to put it on and due to the taper it doesn't want to go back in the hole.
So, I'm just guessing here, but I did something wrong, right?
Any tips or advice? Is there another way to adjust my motor mounts without using a cherry picker?
Re: Harbor Freight Engine Cherry Picker / Lifting an Engine
[Re: MuuMuu101]
#2421951
12/21/17 06:27 PM
12/21/17 06:27 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I've done it for many years by putting the floor jack under the oil sump. With a piece of plywood or 6x6 between the pan and jack pad to spread out the weight better.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2421952
12/21/17 06:28 PM
12/21/17 06:28 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I've done it for many years by putting the floor jack under the oil sump. With a piece of plywood or 6x6 between the pan and jack pad to spread out the weight better. That's actually not a bad idea. Thanks!
[Re: MuuMuu101]
#2421954
12/21/17 06:29 PM
12/21/17 06:29 PM
amxautox
As far as putting the rubber plug back in, put some vasoline on the plug, it should go in easier.
Tom
author unknown
[Re: Jim_Lusk]
#2422168
12/22/17 01:44 AM
12/22/17 01:44 AM
amxautox
...and don't punch a hole in the rubber with the allen wrench...
Might have to use a small screwdriver to push the lip into the hole, working it around the hole a little at a time. Do it easy like, with care.
Tom
author unknown
[Re: amxautox]
#2422197
12/22/17 03:31 AM
12/22/17 03:31 AM
RapidRobert
Might have to use a small screwdriver to push the lip into the hole, working it around the hole a little at a time. Do it easy like, with care. agreed
[Re: MuuMuu101]
#2422258
12/22/17 11:48 AM
12/22/17 11:48 AM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
I had a toy back in late 70s or early 80s that used rubber rivits to hold panels and parts together. The "riviter" was a tool that grabbed the head and stretched the body of the rubber rivit so it would squeeze through the holes. I think you need that tool.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#2422268
12/22/17 12:31 PM
12/22/17 12:31 PM
Posts: 914 Unfortunately back in New York
Nukechargerboy
I had a toy back in late 70s or early 80s that used rubber rivits to hold panels and parts together. The "riviter" was a tool that grabbed the head and stretched the body of the rubber rivit so it would squeeze through the holes. I think you need that tool. Rivitron! I had that too!
