Re: 1970 Dude brake and steering upgrade
[Re: 79beep]
#2421546
12/20/17 07:15 PM
12/20/17 07:15 PM
Posts: 2,683 Des Moines IA
Soopernaut
Des Moines IA
CPP makes a power steering kit. Some have had issues with not getting power to the steering when standing still. That kind of defeats the purpose of power steering since that is when you need it the most. With a good front end you really don't need it when rolling.
Power brakes were an option in 1970 and there are at least 2 companies that make a disc brake swap kit. People have also added boosters from other vehicles.
A frame splice with a 72-93 truck might be easier than a whole frame swap. The frames are nearly the same height and width under the cab so that is where the splice is easiest. The rear portion of a newer frame has a higher kick up over the rear axle so either you need to lift the whole body, cut the bed floor or modify the frame.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: 79beep]
#2421780
12/21/17 10:40 AM
12/21/17 10:40 AM
Soopernaut
Des Moines IA
The wheelbase is 3 inches longer on the newer frame.
[Re: 79beep]
#2422243
12/22/17 10:45 AM
12/22/17 10:45 AM
Soopernaut
Des Moines IA
http://gerstsuspensions.com/products/gts-ifs/There is no way that costs less than a frame swap. I probably have less than that in my whole truck including the purchase. I still have a lot to do but the frame/suspension/body mounting portion is complete.
[Re: 79beep]
#2422491
12/22/17 11:17 PM
12/22/17 11:17 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I also will not have that much money in my current whole project truck.
To be fair, that suspension kit only does the front end, and then you have to add up the expenses of rebuilding everything else on the 61-71 truck. The cost of the front end does not give you everything new on the whole truck, it just gives you new stuff on the front suspension.
I'm pretty sure a guy can rebuild the front brakes and front suspension on a 73-93 1/2 ton pickup a lot cheaper then $2795 then the "kit" does not come with a steering box ($200 for a manual or $400 for power steering), or suspension springs ($400 for new coil over shocks, or free spacers, but no springs at the base price). Most anyone even a little frugal should be able to buy the 73-93 frame, rebuild the front and rear brakes, rebuild the front and the rear suspension, replace all the body mounts, and still have money left over to put towards other things he wants to upgrade for the same money the kit costs.
When you buy that kit, you will still have to remove the front springs and the standard trans mounting brackets, you still have to make a trans crossmember, and install the front suspension. You still have to deal with the master cylinder, brake lines and the gas tank mounting & associated fuel lines.
In the short term, I guarantee installing that front suspension kit will not be the final money spent to make a 61-71 truck a nice driver. To assume adding a front suspension kit will make something old new again is incorrect thinking. The front suspension is only part of the deal, and though it is in line with most other currently available front suspension kits on the market, $3 grand is a pretty big bite to start with. It may have an advantage over other kits because it is specifically made for the Dodge trucks. I believe for my money, I will pick up a newer Dodge truck frame or clip and use OEM factory stuff. Gene
[Re: 79beep]
#2423792
12/26/17 12:20 AM
12/26/17 12:20 AM
poorboy
Freeport IL USA
Your kit does not sand blast or paint the truck frame. It does not replace the body mounts. The steering and brakes (on the kit) are extra cost items, and are modified MMII parts, not truck parts, and they have to come from the kit supplier.
I don't know if you have actually ever done any of the stuff you speak of, but I have. The rolling down the street money spent and the time invested may well be nearly equal, but the rolling truck has much more done then just the front clip laying on the shop floor.
If a guy has to pay someone to assemble the truck, the clip is probably a good deal. If I'm doing my work on my truck, the time I invest is paid for by the reward of being able to drive something I have built. My time working on my project does indeed not cost me anything, in fact, it probably has saved me a ton of money in health expenses and lawyer fees over the years. Gene
[Re: 79beep]
#2424335
12/27/17 12:39 PM
12/27/17 12:39 PM
Posts: 84 Wisconsin USA
themoparmanjc
Wisconsin USA
Frame swaps are a pain because you are putting something on it that wasn’t designed for it. Another thing to take into account is that some of these newer vehicles have crush zones integrated into the frame so they bend in a predictable manner. They are used in conjunction with safety restraint systems. Since you won’t be using air bags, be careful on what you use from new stuff. When you build stuff like this l, think about how it is going to perform in a collision event. I would just weld a front stub on from an 80s dodge as mentioned above. Just make sure you do a ton of measuring beforehand. And good, safe frame rail sectioning methods are a must! Being an I-CAR certified collision tech, I always cringe when I see guys wanting to do stuff like this. I’m not questioning your intelligence or abilities, it’s just scary how much stuff is on the road that was hacked together. Frame and suspension are a huge safety concern.
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
