'02 1500 electrical issue kicking my can #2421003
12/19/17 04:25 PM
12/19/17 04:25 PM
Fulton County, PA
CMcAllister Online content OP
Mr. Helpful
CMcAllister  Online Content OP
Mr. Helpful
Fulton County, PA
Early '02 (9-01), 4.7, 2WD. No turn signals. Turn signal switch ON either way, dash indicators and audible click flash rapidly like a bulb is out. No current to any of the sockets, front or rear. Fuses good, bulbs good.
Any wiring diagrams or information I look up on-line do not match this truck. Not even close. I could figure this out if I had decent information. Anything common that causes this? Good source for correct diagrams?
Re: '02 1500 electrical issue kicking my can [Re: CMcAllister] #2421027
12/19/17 05:06 PM
12/19/17 05:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Normally it's a bad turn signal switch.
Re: '02 1500 electrical issue kicking my can [Re: stumpy] #2421489
12/20/17 04:42 PM
12/20/17 04:42 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
X2 on switch try working the switch rapidly back and forth sometimes this cleans off the contacts in the switch. you'll still need a switch.
Re: '02 1500 electrical issue kicking my can [Re: CMcAllister] #2422341
12/22/17 04:02 PM
12/22/17 04:02 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
FYI...Corrosion issues on the circuit board inside the Integrated Power Module. Took it apart, patched the issues. everything resolved. Seems to be common once I started checking around.
