72 Cuda dash pad removal
#2420161
12/18/17 01:51 AM
12/18/17 01:51 AM
Posts: 3,622 Millinocket, Maine
JonC
Millinocket, Maine
Do I have to Pull the whole dash to just remove the pad?
11B40
Re: 72 Cuda dash pad removal
[Re: JonC]
#2420169
12/18/17 01:59 AM
12/18/17 01:59 AM
Posts: 18,153 Mass
DAYCLONA
Mass
Do I have to Pull the whole dash to just remove the pad? No, but trust me, you will have wished you had pulled the entire dash, much easier than laying on your back under the dash looking for all the speed nuts
[Re: JonC]
#2420361
12/18/17 03:24 PM
12/18/17 03:24 PM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
It wasn't bad when I changed my dash pad,took 1/2 a day and taking your time to clean as you go.. hardest screws was the top ones by the defroster grille, but a 1/4 in extension and swivel worked wonders..glovebox,windshield pillar panels,ashtray and dash cluster gets removed..detailing and cleaning things on the way in takes the most time. Having the replacement dash also helps with the hardware locations..
[Re: BDW]
#2420660
12/18/17 10:55 PM
12/18/17 10:55 PM
JonC
Millinocket, Maine
I had it out maybe 25 years ago to have the pad redone but can't remember how I did it. I took the VIN tag off before I sent it out didn't know about the rivet situation. I acquired a set of rosette rivets and want to change them. Good to know I don't have to remove the whole dash, but how about the heater box?
11B40
[Re: DAYCLONA]
#2420886
12/19/17 12:20 PM
12/19/17 12:20 PM
Posts: 21,346 It's a dry heat
gtx6970
It's a dry heat
Do I have to Pull the whole dash to just remove the pad? No, but trust me, you will have wished you had pulled the entire dash, much easier than laying on your back under the dash looking for all the speed nuts Agreed, Ive done it both ways and trust me. Take the entire pad and frame out in one piece is MUCH easier
