Plumbing line lock where to find right inverted tee #2420662
12/18/17 10:58 PM
12/18/17 10:58 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
Putting line lock into my 69 Dart---plan is to put it in after the prop valve---I am looking for a 3 inverted way tee to tie front lines together and have it feed from line lock solenoid---so the fittings are 7/16 x24 with a 3/16 line----When searching all I can find is a 7/16 x24 inverted tees but they are for 1/4 brake line--does anyone know where to find one of the tees or any suggestions
Re: Plumbing line lock where to find right inverted tee [Re: Dart6pak] #2420665
12/18/17 11:01 PM
12/18/17 11:01 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Bushings?
Re: Plumbing line lock where to find right inverted tee [Re: Dave Hall] #2420684
12/18/17 11:40 PM
12/18/17 11:40 PM
speedway motors online catalogue may have something
Re: Plumbing line lock where to find right inverted tee [Re: Dart6pak] #2420693
12/18/17 11:50 PM
12/18/17 11:50 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Dorman Brake Tee Fittings 785-436
Is this it?
Dennis
