Small block cam retainer ? #2420574
12/18/17 08:24 PM
12/18/17 08:24 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Why is the one on the left different than the stock one on the right?Left is new Mopar Perf.Thanks for any replies.
Re: Small block cam retainer ? [Re: 5carguy] #2420589
12/18/17 08:43 PM
12/18/17 08:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The open passage from the left hole (in pic) directs additional oil to the timing chain.
Re: Small block cam retainer ? [Re: 5carguy] #2420594
12/18/17 08:52 PM
12/18/17 08:52 PM
I would think with the front of the horizontle galleries being plugged with mini freeze plugs that the change is only a different MFR process cuz there ain't no oil coming out of there that could dribble down but I will defer to John on this.
Re: Small block cam retainer ? [Re: 5carguy] #2420623
12/18/17 09:42 PM
12/18/17 09:42 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Don't use the one on the left without the little plug in the galley. You will be down 20 psi oil pressure. I have seen this twice in engines I have freshened that someone else built.
Re: Small block cam retainer ? [Re: qwkmopardan] #2420663
12/18/17 10:59 PM
12/18/17 10:59 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
John Kunkel I believe is correct, there should be zero pressure at that opening, the oil is just partially draining the lifter valley.
11B40
Re: Small block cam retainer ? [Re: 5carguy] #2420704
12/19/17 12:10 AM
12/19/17 12:10 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I had to hunt for oil pressure problems on a motor and they used the plate on the left. It had very poor oil pressure. Don’t use it unless you plug the galley with drive in plug. Stock plates used a bolt with a small hole in it to oil the chain through the lifter valley.
Re: Small block cam retainer ? [Re: fastmark] #2420759
12/19/17 01:45 AM
12/19/17 01:45 AM
I would always use the mini cup plugs in the (2) horizontle galleries & I drill a 3/8 hole in the pass retainer plate & drill/tap the front of that sides' horizontle gallery for a blue aluminum pipe plug with a .015" hole in it on that side instead of the mini cup plug for a constant mini squirt past the plate onto the chain. But people have said that there is enough slosh in that area that the chain ain't hurtin for oil.
Re: Small block cam retainer ? [Re: 5carguy] #2420908
12/19/17 01:30 PM
12/19/17 01:30 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Some small blocks just had the bolt with the hole in it for oiling. Others just had the drip tab. I put both on my last build.
Re: Small block cam retainer ? [Re: mopars4ever] #2420925
12/19/17 02:01 PM
12/19/17 02:01 PM
Yes & it is an 1/8" hole that you can easily drill in a regular bolt (& use the drip tray if you have one). EDIT & this is the top pass bolt, the other top one is a blind hole, the two bottom ones go into the valley (if there would be enough splash back there to warrant drilling the bottom ones (couldn't hurt/easy to do).
