Page 2 of 2 < 1 2
#2421652 - 12/20/17 08:03 PM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: gremlinsteve]
STEFF Offline
Loc: Smyrna, South Carolina
Originally Posted By gremlinsteve
Can you tell us why there not good steff
I used to have notes from a discussion I had with Harland Sharp about them and can't find them. But, I remember getting off the phone with them feeling they weren't too confident about them. But my opinion, I'm not a fan of the aluminum rocker body with the considerable amount of offset the rockers have from roller to pushrod. They are spring limited to what they can handle because of it. T & D's use a steel body. After running my T & D's this year, they've been flawless. Consistent lash. Plenty of oil to the springs, cups and rollers. They Can handle a double valve spring without issue.
#2421918 - 12/21/17 02:14 PM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: STEFF]
MattW Offline
Loc: Ontario Canada
Steff.
R U ever going to market your belt drive?
Matt
#2421961 - 12/21/17 03:38 PM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: moparmitch]
Medlock51 Offline
Loc: Wisconsin
Roller tipped rockers aren't really a necessity... lots of good discussion about them over on www.speedtalk.com .
I have a set of T&D's for my small block but I think I'm going to stick with my iron rockers for 2018... simple and effective. Maybe if I stick with that small block deal after next year I'll use the T&D's.
I'm not overly worried about the juice lifters on the Gen 3's, either. No experience with these new engines right now but my plan B for 2018 is building a simple 5.7 for a back-up and see how it works. I need to be at 650 HP or better and it will be on a dirt track deal.... we'll see.
#2422004 - 12/21/17 05:35 PM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: MattW]
STEFF Offline
Originally Posted By MattW
Steff.
Matt
Yes. I lost sight of it and am making it a prioriority to get it out there. Thats, if there's interest.
Edited by STEFF (12/21/17 05:35 PM)
#2422020 - 12/21/17 06:22 PM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: STEFF]
MattW Offline
Loc: Ontario Canada
Steff.
Matt
I am!
#2422316 - 12/22/17 11:35 AM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: moparmitch]
Jerry Offline
Loc: Warren, MI
I still have all the programs here for that steff
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
#2422331 - 12/22/17 12:38 PM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: STEFF]
ric3xrt Offline
Loc: Trumbauersville PA
Steff.
Matt
I'm interested
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2422340 - 12/22/17 12:59 PM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: Jerry]
ric3xrt Offline
Not to hijack the thread any , but have you thought about main caps for the G3 Hemi ?
#2423070 - 12/24/17 10:32 AM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: Medlock51]
CHAPPER Offline
Loc: Belpre,Ohio
[quote=Medlock51]Roller tipped rockers aren't really a necessity... lots of good discussion about them over on www.speedtalk.com .
I'm not overly worried about the juice lifters on the Gen 3's, either. No experience with these new engines right now but my plan B for 2018 is building a simple 5.7 for a back-up and see how it works. I need to be at 650 HP or better and it will be on a dirt track deal.... we'll see. [/qu
Good to hear somebody else is going to use a Gen 3 in the dirt world. Plenty of power.
If you like drag racing, support your local track.
#2423092 - 12/24/17 11:22 AM Re: G3 Aftermarket Timing Set and Such: Wishful thinking? [Re: moparmitch]
Jerry Offline
Loc: Warren, MI
yes we are testing main caps and girdle kit now. should be out in the spring.
www.sdconcepts.com
www.bcrproducts.com
Page 2 of 2 < 1 2
25,382 Registered Members
190,868 Topics
The case of the missing playground set !
by bigdad
07/18/18 08:24 AM
Borgeson Earns High Praise From Customers
by Rustymuscle
07/18/18 07:29 AM
Cincinnati speed shops
by 70rrclone
07/18/18 06:47 AM
1969 Plymouth Road Runner
by tomsjack
07/18/18 05:02 AM
