On a /6 with an upside down mounted fuel pump, if the pump is going bad to where after 10 minutes or so after shut down, the filter is empty, can it siphon the gas out of the carb also? I'm having drivability problems, and noticed the filter would be empty after just a few minutes after shut down. The problem is off idle, the engine just bogs up till about 3/4 throttle, like the accelerator pump isn't working. It has done this before, and after a rebuild. It's a 75 a body with all of the pollution garbage.
