1970 318 mating to 1963 727 #2419611
12/16/17 09:27 PM
12/16/17 09:27 PM
MoPar Offline OP
MoPar  Offline OP
Checking to see if the bolt pattern is the same to mate them together, the 4 common trans to block bolts line up, the bolt that is near the aligning dowel on the drivers side does not line up to the trans threaded hole, the same bolt on the other side behind the oil filter does line up, any ideas ?
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419617
12/16/17 09:56 PM
12/16/17 09:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Will the flex plates and converters swap?
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419626
12/16/17 10:20 PM
12/16/17 10:20 PM
MoPar Offline OP
MoPar  Offline OP
I will try to add a picture, the left hole is the aligning dowel and the middle hole and the right hole should line up.
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419665
12/17/17 12:03 AM
12/17/17 12:03 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The LA style motors will bolt up to the earlier trans and flex plate / converter.
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419675
12/17/17 12:28 AM
12/17/17 12:28 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
How about the converter register size, Different?
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419676
12/17/17 12:30 AM
12/17/17 12:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
They will bolt up as said.IIRC one bolt wont line up.I think the register is different but works.Did it morethan once.Rocky
Chrysler Firepower
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419755
12/17/17 09:35 AM
12/17/17 09:35 AM
MoPar Offline OP
MoPar  Offline OP
Would it be necessary to drill and tap the trans to utilize the block hole that doesn't line up ?
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419758
12/17/17 09:49 AM
12/17/17 09:49 AM
MoPar Offline OP
MoPar  Offline OP
Here is what I should have put in the original post, have a 63 Fury with original drivetrain, the 318 poly was bad so I'm putting in a 70 318 and using the original 727 cable shift trans, the flex plate and torque converter are the originals to the 63. The flex plate, crank, and torque converter all bolted together fine, the block to trans bolted up fine except the bolt below the aligning dowel on the drivers side. As far as the torque converter register to crank goes I don't know as it seemed to go together ok.
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419795
12/17/17 12:30 PM
12/17/17 12:30 PM
I think the register hole in the crank & the TC nub were enlarged in ~68 or so & you can use the later crank/early trans (like you are doing) but not the other way around & the gap may or not be OK as is but I think people have done it & there was an article in a van magazine where in addition they cut some slits in the flexplate so it would flex & not wear out the pump bushing (iirc, not sure, I have it somewhere). Doug Dutra of the old /6 club of America used to machine a spacer to take up that space & later wildcat auto was selling em (not sure if it is needed & or the /6 one is the same as the V8 one) but it must be desireable otherwise it would not have been fabbed by several individuals. I have one if you need dimentions.
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419912
12/17/17 04:53 PM
12/17/17 04:53 PM
You need to measure both the crank hole I.D. and the O.D. of the converter hub, very little clearances(.008 to maybe .015) are needed, no slop allowed tsk scope If it has a lot of clearance you can have a bushing made to slip on the converter hub to get it back to factory specs. up scope
The crank hub aligns and holds the converter and centers it so it won't wipe out the front pump bushing and seal work It needs to be correct, not loose thumbs
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419963
12/17/17 07:19 PM
12/17/17 07:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All 727 converter pilot hubs are the same 1.81" diameter. The Poly motor trans case has one hole that won't match the LA engine, drill/tap.
The '63 727 input shaft spline is different than the '67 and later, must use '62-'66 converter or change input shaft.
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2419995
12/17/17 08:31 PM
12/17/17 08:31 PM
MoPar Offline OP
MoPar  Offline OP
Thanks everyone for the input, I like the last answer the best as that would mean I don't have the pull the LA 318 I just put in yesterday !
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2420017
12/17/17 09:03 PM
12/17/17 09:03 PM
A727Tflite Offline
A727Tflite  Offline
OP reused the original converter.
Re: 1970 318 mating to 1963 727 [Re: John_Kunkel] #2420043
12/17/17 10:21 PM
12/17/17 10:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Thanks John for stopping the internet tales whistling
bow bow
Re: 1970 318 mating to 1963 727 [Re: TJP] #2420058
12/17/17 10:47 PM
12/17/17 10:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
bow bow
Not a tale, a simple mistake, the pilot diameter issue applies to the 904 style transmissions, only.
Don't be the exception.
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2420218
12/18/17 08:09 AM
12/18/17 08:09 AM
MoPar Offline OP
MoPar  Offline OP
Thanks again everyone for all of the experience and knowledge !!
Re: 1970 318 mating to 1963 727 [Re: MoPar] #2420419
12/18/17 05:11 PM
12/18/17 05:11 PM
dogdays Offline
dogdays  Offline
I didn't read the intermediate posts between OP and here, so beware!
The bellhousing has one hole that doesn't line up, the lowest one on the driver's side. Many leave the bolt out. Because this bolt is the lowest , below the centerline of transmission and crank, it is important to have some clamping force at that point. I found that I was able to drill a new hole and tap it but I could have also used a bolt and nut. It doesn't have to be a huge bolt. It could be one size smaller than the others and still do its job.
R.
Re: 1970 318 mating to 1963 727 [Re: Supercuda] #2420458
12/18/17 05:50 PM
12/18/17 05:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
bow bow
Gosh, maybe that's what I was trying to convey. rolleyes
Re: 1970 318 mating to 1963 727 [Re: John_Kunkel] #2420461
12/18/17 05:54 PM
12/18/17 05:54 PM
dogdays Offline
dogdays  Offline
Thank you, John Kunkel, for being a touchstone, a rock upon whose knowledge we can base our decisions.
Merry Christmas and a Happy and Healthy New Year!
R.
Re: 1970 318 mating to 1963 727 [Re: John_Kunkel] #2420465
12/18/17 05:57 PM
12/18/17 05:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
bow bow
I was not talking to you. If your comprehension equaled your arrogance you'd be the genius you think you are.
