Re: 1970 318 mating to 1963 727
[Re: MoPar]
#2419626
12/16/17 10:20 PM
12/16/17 10:20 PM
MoPar
I will try to add a picture, the left hole is the aligning dowel and the middle hole and the right hole should line up.
[Re: MoPar]
#2419676
12/17/17 12:30 AM
12/17/17 12:30 AM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
They will bolt up as said.IIRC one bolt wont line up.I think the register is different but works.Did it morethan once.Rocky
Chrysler Firepower
[Re: MoPar]
#2419795
12/17/17 12:30 PM
12/17/17 12:30 PM
RapidRobert
I think the register hole in the crank & the TC nub were enlarged in ~68 or so & you can use the later crank/early trans (like you are doing) but not the other way around & the gap may or not be OK as is but I think people have done it & there was an article in a van magazine where in addition they cut some slits in the flexplate so it would flex & not wear out the pump bushing (iirc, not sure, I have it somewhere). Doug Dutra of the old /6 club of America used to machine a spacer to take up that space & later wildcat auto was selling em (not sure if it is needed & or the /6 one is the same as the V8 one) but it must be desireable otherwise it would not have been fabbed by several individuals. I have one if you need dimentions.
[Re: MoPar]
#2419963
12/17/17 07:19 PM
12/17/17 07:19 PM
Posts: 25,728 Rio Linda, CA
John_Kunkel
Rio Linda, CA
All 727 converter pilot hubs are the same 1.81" diameter. The Poly motor trans case has one hole that won't match the LA engine, drill/tap.
The '63 727 input shaft spline is different than the '67 and later, must use '62-'66 converter or change input shaft.
[Re: TJP]
#2420058
12/17/17 10:47 PM
12/17/17 10:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The '63 727 input shaft spline is different than the '67 and later, must use '62-'66 converter or change input shaft. Thanks John for stopping the internet tales Not a tale, a simple mistake, the pilot diameter issue applies to the 904 style transmissions, only.
[Re: MoPar]
#2420419
12/18/17 05:11 PM
12/18/17 05:11 PM
dogdays
I didn't read the intermediate posts between OP and here, so beware!
The bellhousing has one hole that doesn't line up, the lowest one on the driver's side. Many leave the bolt out. Because this bolt is the lowest , below the centerline of transmission and crank, it is important to have some clamping force at that point. I found that I was able to drill a new hole and tap it but I could have also used a bolt and nut. It doesn't have to be a huge bolt. It could be one size smaller than the others and still do its job.
R.
[Re: Supercuda]
#2420458
12/18/17 05:50 PM
12/18/17 05:50 PM
John_Kunkel
Rio Linda, CA
The '63 727 input shaft spline is different than the '67 and later, must use '62-'66 converter or change input shaft. Thanks John for stopping the internet tales Not a tale, a simple mistake, the pilot diameter issue applies to the 904 style transmissions, only. Gosh, maybe that's what I was trying to convey.
[Re: John_Kunkel]
#2420465
12/18/17 05:57 PM
12/18/17 05:57 PM
Supercuda
About to go away
About to go away
up yours
The '63 727 input shaft spline is different than the '67 and later, must use '62-'66 converter or change input shaft. Thanks John for stopping the internet tales Not a tale, a simple mistake, the pilot diameter issue applies to the 904 style transmissions, only. Gosh, maybe that's what I was trying to convey. I was not talking to you. If your comprehension equaled your arrogance you'd be the genius you think you are.
[Re: Supercuda]
#2420492
12/18/17 06:33 PM
12/18/17 06:33 PM
RapidRobert
When I posted I (erroneously) had thought the 727's had a similar register/nub dimention change in the mid 60's that the 904's did. My bad.
[Re: Supercuda]
#2420496
12/18/17 06:35 PM
12/18/17 06:35 PM
John_Kunkel
Rio Linda, CA
Pot........meet kettle.
