Paint question #2418913
12/15/17 11:11 AM
12/15/17 11:11 AM
Eastern Ontario
shaker340 Offline OP
Eastern Ontario
I aquired a shakerhood from a 2015 RT. Its in plum crazy and I want to paint in Hemi Orange, would I be best to lightly sand the whole hood then sealer primer?
Mike
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: Paint question [Re: shaker340] #2418964
12/15/17 01:27 PM
12/15/17 01:27 PM
God's Country Maryland
GODSCOUNTRY340 Offline
First wash the hood with Dawn dishwashing soap and warm water, wet sand with 360 or 400 grit, seal and paint your top coat.
Re: Paint question [Re: shaker340] #2418973
12/15/17 01:47 PM
12/15/17 01:47 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you weren't doing a color change you could clean, scuff with 400 and shoot, but in your case I would do the sealer primer then scuff with 400 again.
Re: Paint question [Re: shaker340] #2419045
12/15/17 03:21 PM
12/15/17 03:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mike
Wipe down the hood with lacquer thinner to remove wax/silicone/etc, then block sand 220,320, then finish off at 400, if your trying to match the paint of your existing car, follow the paint mfg recommendation for the proper value shade of primer/sealer, in primer I would finish block up to 600 grit before applying a BC/CC
