Stage 6 heads #2418410
12/14/17 12:18 PM
12/14/17 12:18 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Found a guy with some mopar engine stuff for sale. He has a set of virgin Stage 6 heads (Not sure what CC or port size) I don't know anything about these heads. How do they perform OOTB, or do they need alot of work? Do they require a special intake, rockers arms and headers? How do they perform to the new Trick Flows.
Re: Stage 6 heads [Re: DusterKid] #2418416
12/14/17 12:25 PM
12/14/17 12:25 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Run away. They need a TON of work to be useable and far from cost effective compared to pretty much any other head available nowadays.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Stage 6 heads [Re: DusterKid] #2418430
12/14/17 12:50 PM
12/14/17 12:50 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Assuming they are not Chapman stage 6's......
Every set I've had in the shop(and there have been quite a few) have needed a bunch of time and $$$ invested.
Nowadays, I would put them at the bottom of the "bang for the buck" list.
Re: Stage 6 heads [Re: DusterKid] #2418440
12/14/17 01:15 PM
12/14/17 01:15 PM
Keymar, MD
Keymar, MD
Thanks guys for the info. I'll know to pass on the heads when I go to check out all the stuff.
Re: Stage 6 heads [Re: DusterKid] #2418480
12/14/17 02:25 PM
12/14/17 02:25 PM
Frackster Offline
Frackster  Offline
When they are fixed they are a raised port head and will make good power.
Re: Stage 6 heads [Re: fast68plymouth] #2418484
12/14/17 02:30 PM
12/14/17 02:30 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Dwayne are the chapman stg 6 easy to identify?
Thanks again, Don
Re: Stage 6 heads [Re: DusterKid] #2418502
12/14/17 03:14 PM
12/14/17 03:14 PM
So. Burlington, Vt.
So. Burlington, Vt.
Basically........Rocker stands milled flat, spring pads not cut really deep into casting, very nicely cnc ported, 11/32 guides, intake guide boss completely removed from bowl, shortish/wideish exhaust port opening.
Re: Stage 6 heads [Re: DusterKid] #2418571
12/14/17 05:49 PM
12/14/17 05:49 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
The Chapman ported stage 6 were pretty good and very expensive!
RB COPYRIGHT © 2000-2017 Stan Weiss — World Wide Enterprises
Manufacturer
Part Number Port/Vol
Int/Exh Valve Size Int/Exh Comb. Chamber Vol .100 .200 .300 .400 .500 .600 .700 .800 .900 1.000 Average
Chrysler 250 Full Race Ported Brian Stroud Iron N/A 2.14/1.81
4.50
Pipe 88 87/60 147/112 189/151 231/177 246/194 252/207 252/212 251/217 - - -
Chrysler 286 Stage I Ported Iron N/A 2.08/- N/A - 134/- 190/- 227/- 257/- 280/- 289/- - - - -
Chrysler 346 Ported BJR Racing Iron 177/60 2.08/1.74
No Pipe 65 99/89 191/130 229/188 243/204 285/207 289/210 298/212 304/213 - - -
Chrysler 452 Iron 200/62 2.08/1.74 N/A - 142/- 208/- 244/- 264/- - - - - - -
Chrysler 452 Iron 200/62 2.08/1.74 N/A - -/103 -/132 -/143 -/146 -/148 - - - - -
Chrysler 452 Iron 200/62 2.08/1.74 N/A 61/51 126/97 188/133 208/150 218/156 219/156 - - - - -
Chrysler 452 Bowl Blend Iron 200/62 2.08/1.74 N/A 65/55 155/106 202/144 232/170 243/182 245/188 - - - - -
Chrysler 452 IQ52 Iron 200/62 2.08/1.74
Pipe N/A 61/55 130/108 188/152 213/172 227/178 230/181 - - - - -
Chrysler 452 Ported IQ52 Iron N/A 2.14/1.81
Pipe N/A 68/60 142/130 205/187 248/218 286/234 292/245 295/253 - - - -
Chrysler 452 Alum 210/70 2.14/1.81 84 - - - - - 290/217 - - - - -
Chrysler 516 Iron 182/60 2.08/1.60 N/A 62/46 126/97 177/121 199/133 210/138 219/139 - - - - -
Chrysler 516 Iron 182/60 2.08/1.74 N/A - 122/102 172/135 201/151 216/151 223/167 - - - - -
Manufacturer
Chrysler 518 Max Wedge Iron 233/77 - N/A - 159/- 222/- 262/- 284/- 295/- 300/- - - - -
Chrysler 518M Bowl Blend Iron N/A 2.14/1.81 N/A - 145/113 202/152 237/174 253/190 268/200 277/206 - - - -
Chrysler Max Wedge Bowl Blend Gasket Match BJR Racing Iron 230/- 2.08/1.88
No Pipe N/A 87/89 175/135 225/199 291/221 307/240 307/253 307/264 309/267 - - -
Chrysler 902 IQ52 Iron N/A 2.08/- N/A 65/- 137/- 185/- 206/- 218/-76 221/- - - - - -
Chrysler 902 Ported IQ52 Iron N/A - N/A 85/- 164/- 219/- 257/- 293/- 309/- 318/- - - - -
Chrysler 906 MMM Iron N/A 2.08/1.74 N/A 65/61 134/107 194/142 217/160 231/167 233/171 232/- - - - -
Chrysler 906 Iron 200/62 2.08/1.74 80 - 142/- 208/- 241/- 262/- 270/- - - - - -
Chrysler 906 Iron 200/62 2.08/1.74 N/A - -/98 -/127 -/143 -/150 -/154 - - - - -
4.44 N/A 63/62 130/107 188/131 218/146 227/155 232/164 232/169 - - - -
Chrysler 906 Iron 200/62 2.08/1.74 N/A 61/50 126/95 188/130 223/148 234/155 235/158 - - - - -
Chrysler 906 IQ52 Iron N/A 2.08/1.74
Pipe N/A 66/55 130/103 189/145 222/168 234/176 237/183 - - - - -
Chrysler 906 Ported IQ52 Iron N/A 2.14/1.81 N/A 71/- 150/- 209/- 257/- 292/- 313/- 321/- - - - -
Manufacturer
Chrysler 906 Stock Eliminator Modern Cylinder Head Iron 203/64 2.08/1.74
4.38
No Pipe N/A 72/62 138/108 184/138 232/157 260/167 - - - - - -
Chrysler 906 Dr Js Performance Iron N/A 2.08/1.74 N/A 78/54 128/99 188/126 215/147 215/157 215/166 - - - - -
Chrysler 906 Ported Dr Js Performance Iron N/A 2.08/1.74 N/A 67/57 138/108 201/140 243/168 262/184 265/194 270/200 - - - -
Chrysler 906 Ported Muscle Motors Iron N/A 2.14/1.81
4.375
No Pipe N/A - 153/128 222/165 268/200 304/215 313/223 309/223 - - - -
Chrysler 906 Ported BJR Racing Iron 213/- 2.08/1.74
No Pipe N/A 105/93 190/129 225/190 260/204 300/215 300/221 302/222 304/222 - - -
Chrysler 906 Bill Jones Iron N/A 2.08/1.74
No Pipe N/A 73/62 116/102 169/138 213/152 230/158 237/160 - - - - -
Chrysler 906 Mildly Ported Bill Jones Iron N/A 2.08/1.74
No Pipe N/A 73/66 138/115 202/149 242/180 246/193 244/199 - - - - -
Chrysler 906 Ported Bill Jones Iron N/A -
No Pipe N/A 78/60 148/111 211/158 246/192 271/201 282/210 - - - - -
Chrysler P5153524 Alum 210/70 2.14/1.81 84 - - - - - 290/217 - - - - -
Chrysler Stage IV N/A 2.08/1.75 N/A - - - - - 248/177 - - - - -
Chrysler Stage V (P4529993) Iron N/A 2.14/1.81 90 - - - - - - - - - - -
Chrysler P4876311 MMM Alum N/A 2.14/1.81
No Pipe 78 63/50 128/87 176/121 224/146 252/160 263/164 266/168 - - - -
Manufacturer
Chrysler P4876311 Ported MMM Alum N/A 2.14/1.81
No Pipe 78 67/57 135/105 199/145 251/182 289/199 305/210 308/220 - - - -
Chrysler Stage VI (P4529335) Alum 210/- 2.14/1.81 N/A - - - - - - - - - - -
Chrysler Stage VI IQ52 Out of Box Alum N/A 2.14/1.81 N/A 68/- 128/- 184/- 218/- 242/- 254/- 260/- 267/- - - -
Chrysler Stage VI Minor Pocket Porting Gasket Matching Brian Stroud Alum N/A 2.14/1.81
4.50
Pipe N/A 73/57 148/117 205/160 253/195 286/232 277/260 287/276 288/292 - - -
Chrysler Stage VI Ported Porter Racing Heads Alum N/A 2.14/1.81 N/A 68/51 146/116 211/165 258/208 288/236 321/251 331/256 - - - -
Chrysler Stage VI Ported Porter Racing Heads Alum 215/- 2.14/1.81
No Pipe N/A 67/56 142/104 204/148 253/185 287/214 307/234 310/246 - - - -
2" Pipe N/A 67/56 142/107 204/156 253/198 287/233 307/257 310/273 - - - -
Chrysler Stage VI Ported Chapman 235/- 2.18/1.81
No Pipe 77 72/55 157/112 233/177 284/211 323/233 343/242 343/252 - - - -
Chrysler Stage VI (P4876383) Ported Chapman 260/84 2.20/1.81
No Pipe 77 71/55 157/112 230/177 290/211 325/233 351/242 351/252 - - - -
Chrysler Stage VI (P4876383) Ported Chapman Out of Box Porter Racing Heads 260/84 2.20/1.81 77 71/58 150/119 219/180 279/219 324/234 352/243 348/250 - - - -
Chrysler Stage VI (P4876386) Ported Chapman Max Wedge Alum 285/84 2.25/1.81
No Pipe 74 77/55 151/112 220/177 283/211 330/233 364/242 375/252 - - - -
Chrysler Stage VI BJR Racing Out of Box Alum N/A 2.14/1.81
No Pipe N/A 94/90 141/116 218/140 258/188 307/196 322/198 324/198 324/198 - - -
Manufacturer
Chrysler Stage VI Intake Bowl BJR Racing Alum N/A 2.14/1.81
No Pipe N/A 98/90 171/116 226/140 262/188 311/196 318/198 324/198 324/198 - - -
Chrysler Stage VI Ported BJR Racing Max Wedge Alum N/A 2.14/1.81
No Pipe N/A 93/88 183/134 239/192 309/226 340/251 362/256 373/261 393/262 - - -
Brodix B1 Org SF300 Alum N/A 2.30/1.78
4.25
No Pipe N/A - 147/125 215/163 279/197 318/224 354/240 392/259 400/271 - - -
Brodix B1 MoPar Alum 300/- 2.30/1.78 68 - 151/116 220/174 277/216 325/227 364/227 396/227 - - - -
Brodix B1 MoPar Ported ET Performance Alum N/A 2.30/1.85
4.50 N/A 87/66 179/128 259/183 322/228 372/265 411/282 411/285 420/285 - - -
Brodix B1 BS Alum (OLD) 230/- 2.20/1.81 65 - 133/103 184/132 227/156 262/175 278/195 293/201 - - - -
Brodix B1 BS Alum 230/- 2.20/1.81 65 - 145/123 204/155 249/184 284/206 294/222 295/233 - - - -
Brodix STS B1 BS Alum 243/- 2.20/1.81 80 - 145/126 214/171 267/211 305/238 337/255 348/279 - - - -
Brodix B1 BS Ported ET Performance Alum N/A 2.20/1.81
4.375 N/A 77/58 148/113 198/147 253/182 299/204 332/224 334/239 338/251 342/260 - -
Brodix B1 BS Ported ET Performance Alum N/A 2.25/1.81
4.50 82 76/59 150/108 218/145 273/173 314/198 343/219 355/238 353/253 353/265 - -
Brodix B1 Ported Koffel Alum N/A 2.30/1.775 N/A - - - - - - 410/275 - 427/291 - -
Brodix B1 Ported Modern Cylinder Head Alum N/A 2.30/1.78
4.44 N/A 78/62 150/117 199/162 259/204 319/232 357/254 389/270 405/283 419/293 421/297 -
Manufacturer
Brodix B1 MO Alum 300/- 2.30/1.78 68 - 151/116 220/174 277/216 325/227 364/227 396/227 - - - -
Brodix B1 MC Alum 300/- 2.40/1.78 68 - - - - - - - - - - -
Brodix B1 MC Ported Koffel Alum N/A 2.40/1.78
4.50 N/A 99/73 183/124 270/164 339/202 388/253 409/267 429/284 443/294 449/301 - -
Brodix B1 MC Ported Modern Cylinder Head Alum N/A 2.40/1.81
4.44 N/A 80/61 168/111 222/157 283/205 341/252 382/274 409/291 414/304 418/313 421/320 -
Brodix B1 PSO Ported Best Machine Alum 388/149 2.40/1.80
4.44 N/A 74/56 149/112 229/173 292/216 346/247 393/272 425/291 454/301 465/320 470/328 -
4.50 N/A 69/57 148/117 227/177 293/221 355/252 402/275 440/291 462/308 471/320 477/330 -
Bulldog Performance Stock Intake N/A 2.19/1.81 76 78/67 146/126 211/170 260/195 297/213 293/226 294/236 - - - -
Bulldog Performance Max Wedge Intake N/A 2.19/1.81 76 74/67 147/126 213/170 257/195 307/213 308/226 307/236 - - - -
Bulldog Performance Ported Brian Stroud 268.5/- 2.19/1.81
4.50
Pipe N/A 80/53 153/112 209/157 260/188 285/218 305/245 318/265 324/282 - - -
Bulldog Performance Dvorak Ported MW N/A 2.19/1.81 N/A 78/51 153/98 215/138 271/168 314/192 332/215 338/232 341/244 - - -
Edelbrock Performer RPM 60929, 60189 SF1020 Alum 210/70 2.14/1.81 84/88 79/70 145/126 209/160 254/188 278/206 290/217 292/223 - - - -
Edelbrock Performer RPM 60929 Hughes Out of Box Alum N/A 2.14/1.81 N/A - 147/117 209/149 247/179 268/203 275/217 278/222 - - - -
Manufacturer
Edelbrock Performer RPM 60929 Ported Hughes Alum N/A 2.14/1.81 N/A - 168/115 233/157 280/194 309/219 318/223 322/228 - - - -
Edelbrock Performer RPM IQ52 Out of Box Alum N/A 2.14/1.81 N/A 73/- 148/- 209/- 254/- 276/- 287/- 291/- - - - -
Edelbrock Performer RPM Ported IQ52 Alum N/A - N/A 84/- 158/- 215/- 252/- 299/- 328/- 349/- - - - -
Edelbrock Performer RPM VJ Minor Bowl Port Clean Up Alum 210/70 2.14/1.81
4.375
No Pipe N/A 64/51 136/102 202/146 250/179 272/196 287/205 288/213 - - - -
Edelbrock Performer RPM CNC Chad Speier Alum N/A 2.14/1.81
No Pipe N/A - 140/115 214/146 264/174 292/191 307/205 319/216 321/226 - - -
Edelbrock Performer RPM Ported MRL Performance N/A 2.19/1.81
No Pipe 84 77/62 156/122 234/163 286/207 315/241 329/260 342/273 - - - -
Edelbrock RPM Ported Alum N/A 2.14/1.81
No Pipe N/A 70/58 155/106 216/143 257/179 285/197 302/217 306/225 310/233 - - -
Edelbrock RPM Ported Hughes Stage 3 SF600 Alum N/A 2.19/1.81 N/A 80/82 157/108 225/160 275/196 301/224 316/236 321/248 - - - -
Edelbrock Ported Modern Cylinder Head Alum N/A 2.14/1.81
4.38
No Pipe N/A 75/75 151/126 219/166 267/197 306/218 324/231 328/239 328/245 - - -
4.38
Pipe N/A 75/78 151/131 219/175 267/212 306/240 324/257 328/268 328/276 - - -
Edelbrock RPM Xtreme Alum 225/100 2.20/1.81 80 - - - - - - - - - - -
Edelbrock Victor 77929 SF1020 Alum 280/100 2.20/1.81 75 85/63 150/118 211/160 261/188 298/207 322/219 325/226 - - - -
Manufacturer
Edelbrock Victor Hughes Out of Box Alum 280/100 2.20/1.81 75 69/67 146/118 220/166 264/200 308/225 323/242 319/260 - - - -
Edelbrock Victor IQ52 Out of Box Alum N/A 2.20/1.81 N/A 68/- 133/- 201/- 250/- 287/- 307/- 327/- 329/- - - -
Edelbrock Victor 77929 CNC Chad Speier V3.3 I-45 E-45 Alum 285/100 2.25/1.81
4.50
1 7/8" Pipe 55 - 165/117 228/166 291/203 340/237 366/254 381/265 391/270 394/276 398/279 -
Edelbrock Victor CNC Chad Speier Alum N/A 2.25/1.81
2" Pipe N/A - 154/114 219/166 282/209 334/241 363/264 378/280 390/288 395/290 402/290 -
Edelbrock Victor Flowtech - Steven Magnotti Intake 3/4" Longer than stock SF110 Alum 280/100 2.20/1.81
4.25 N/A 68/45 128/97 235/140 275/185 296/206 315/219 - - - - -
Edelbrock Victor Alum 280/110 2.20/1.81 N/A - 136/112 207/155 255/192 288/216 308/225 326/226 - - - -
Edelbrock Victor Ported Modern Cylinder Head Alum N/A 2.20/1.81 N/A 81/67 160/120 223/157 285/187 328/208 358/225 369/236 372/246 - - -
Edelbrock Victor Max Wedge 77949 Intake Port Raised .65 Exhaust Port Raised .25 SF1020 Alum 290/100 2.20/1.81 75 85/63 150/118 211/160 261/189 298/207 322/219 325/226 - - - -
Edelbrock Victor Max Wedge 77949 NPS Alum N/A 2.20/1.81
No Pipe N/A 67/57 129/106 191/151 246/183 280/205 300/220 321/225 329/227 - - -
Edelbrock Victor Max Wedge Brian Alum N/A 2.20/1.81
4.35
2 1/8" Pipe N/A - 144/117 212/167 262/205 289/231 323/248 336/255 - - - -
Edelbrock Victor Max Wedge Ported Brian Alum N/A 2.20/1.81
4.35
2 1/8" Pipe N/A - 158/133 234/184 287/223 326/251 348/270 356/284 - - - -
Edelbrock Victor Max Wedge Ported Speed-O-Motive Alum N/A 2.20/1.81 N/A - 157/99 220/162 270/190 310/220 340/240 365/258 - - - -
Manufacturer
Edelbrock Victor Max Wedge Ported Hughes Stage 3 Alum 313/84 2.20/1.81 N/A 78/86 165/107 231/161 287/201 326/234 341/255 358/264 - - - -
Edelbrock Victor Max Wedge Ported Hughes Alum 333/- 2.20/1.81 N/A - 171/101 235/165 293/217 327/249 352/271 372/285 - - - -
Edelbrock Victor Max Wedge Ported Scott Brown Alum N/A 2.25/1.81 N/A 84/69 162/121 229/160 292/191 335/216 371/232 383/244 390/251 - - -
Edelbrock Victor Max Wedge CNCPort Alum N/A 2.25/1.81 N/A - 165/117 228/166 291/203 340/237 366/253 381/265 391/270 393/276 - -
440source Stealth Alum 212/72 2.14/1.81 84 - - - - - 290/220 - - - - -
4.375
No Pipe N/A 64/49 140/104 208/140 239/165 256/178 265/188 267/196 - - - -
No Pipe N/A 65/57 135/108 191/140 227/159 242/173 254/183 261/191 - - - -
440source Stealth Ported Alum N/A 2.14/1.81 N/A 82/81 178/147 231/169 274/194 292/211 300/224 301/231 - - - -
440source Stealth Ported Modern Cylinder Head Alum N/A 2.14/1.81
4.38
No Pipe N/A 73/71 150/128 216/166 267/198 304/218 322/231 324/239 325/246 - - -
440source Stealth Ported Modern Cylinder Head 440source Alum N/A 2.14/1.81
4.38
2" Pipe N/A 75/73 157/125 220/166 266/198 299/219 315/233 321/244 325/246 - - -
440source Stealth NPS Alum N/A 2.14/1.81
No Pipe N/A 65/57 133/107 196/140 240/164 259/179 265/188 267/191 - - - -
440source Stealth Ported NPS Alum N/A 2.14/1.81
No Pipe N/A 74/58 133/108 195/138 249/163 278/182 290/195 292/206 - - - -
Manufacturer
Super Stealth Ported IQ52 Alum N/A - N/A 74/- 153/- 216/- 267/- 309/- 344/- 352/- - - - -
Indy 440 Torquer 260/- - 75 - - - - - 298/218 - - - - -
Indy 440-SR 265/106 2.19/1.81 75 - 143/101 194/135 238/164 272/189 290/204 296/217 - - - -
Indy 440-SR Mild Bowl Port Compu-Flow SF1020 N/A 2.19/1.81 N/A 69/59 134/108 195/146 244/176 279/200 285/220 292/230 - - - -
Indy 440-SR Full Porting 295/122 2.19/1.81 N/A - 150/118 216/166 265/205 310/238 337/254 352/263 - - - -
Indy 440-SR Full Porting 295/122 2.19/1.81 N/A - 162/121 216/166 274/205 324/239 351/260 355/263 - - - -
Indy 440-SR Ported Scott Brown 296/- 2.19/1.81
4.375
2" Pipe N/A 76/62 160/123 220/185 273/229 313/258 336/283 344/288 347/294 - - -
Indy 440-SR Ported Modern Cylinder Heads 310/- 2.25/1.81
4.32
No Pipe N/A 76/70 150/112 215/167 273/200 316/224 343/240 358/254 358/264 - - -
4.32
Pipe N/A 76/71 150/128 215/178 273/212 316/239 343/260 358/275 358/287 - - -
4.50
No Pipe N/A 80/72 155/125 225/173 285/206 328/234 358/255 371/266 374/277 - - -
4.50
Pipe N/A 80/74 155/132 225/182 285/220 328/251 358/274 371/290 374/305 - - -
Indy 440-SR CNC M2 Race Systems 280/- 2.19/1.81
4.50 83 - - 217/165 275/199 317/219 336/243 349/257 357/265 - - -
Manufacturer
Indy 440-EZ 270/- 2.19/1.81
4.375 75/80 63/58 135/103 201/143 253/176 287/196 303/205 310/204 - - - -
Indy 440-EZ 270/- 2.19/1.81 75/80 - 156/98 216/129 264/158 290/178 300/199 305/215 - - - -
Indy 440-EZ Out of Box 265/- 2.19/1.81 N/A 71/54 121/97 190/137 240/170 280/194 306/209 310/222 - - - -
Indy 440-EZ IQ52 Out of Box N/A 2.19/1.81
No Pipe N/A 69/59 131/103 190/135 239/165 283/189 307/205 313/212 321/- - - -
Indy 440-EZ1 275/- 2.19/1.81 N/A - 160/98 220/129 270/158 295/178 310/199 327/215 - - - -
Indy 440-EZ CNC Bowls 295/78 2.19/1.81
4.375 75/80 65/55 141/103 210/138 266/178 308/203 333/218 344/228 - - - -
Indy 440-EZ CNC 295/78 2.19/1.81
4.375 78/82 - 162/110 216/176 274/176 324/196 351/211 355/225 - - - -
Indy 440-EZ CNC VJ Porter Racing Heads 295/78 2.19/1.81 78/82 75/55 155/109 223/158 279/196 319/224 346/239 350/251 - - - -
Indy 440-EZ CNC 325/78 2.19/1.81 78 - -/110 -/149 -/176 -/196 -/211 370/225 - - - -
Indy 440-EZ Ported Modern Cylinder Heads MMM 308/- - N/A - 152/- 217/- 266/- 305/- 337/- 351/- - - - -
Indy 440-1 Alum 310/110 2.19/1.81 N/A 72/58 139/112 204/159 265/196 308/226 317/244 326/257 - - - -
Indy 440-1 Alum, 440-C Iron 310/110 2.19/1.81 75 - 152/101 203/135 254/164 288/189 296/204 312/217 - - - -
Manufacturer
Indy 440-1 Alum, 440-C Iron Full Porting 325/122 2.19/1.81 78 - 161/132 223/177 280/218 327/248 359/267 373/279 - - - -
Indy 440-1 Alum, 440-C Iron Full Porting 345/122 2.19/1.81 78 - - 229/167 288/201 339/230 363/250 378/277 380/285 - - -
Indy 440-C Iron Full Porting SM N/A 2.19/1.81 N/A - - 215/160 280/193 325/225 344/240 362/267 362/275 - - -
Indy 440-C Mild Port MRL Performance N/A 2.19/1.81
4.50
No Pipe N/A 110/85 166/147 256/189 311/226 360/255 365/270 367/279 - - - -
Indy 440-1 Out of Box 90's BJR Racing Alum N/A 2.19/1.81
No Pipe N/A - 157/122 224/150 264/166 282/178 285/185 282/185 - - - -
Indy 440-1 Ported Brian Alum N/A 2.19/1.81 N/A - 155/118 237/171 296/212 342/245 365/270 - - - - -
Indy 440-1 Ported Dwayne Alum 345/- - N/A 71/56 149/113 218/165 275/204 328/238 362/260 376/273 - - - -
Indy 440-1 Ported Modern Cylinder Heads Alum 342/- 2.25/1.81
Pipe N/A 78/67 160/127 231/176 278/210 315/243 329/270 349/285 362/297 - - -
Indy 440-1 Ported Modern Cylinder Heads Alum 350/- 2.25/1.81
4.38
No Pipe N/A 82/71 162/120 238/166 295/200 331/228 360/251 380/267 391/- - - -
Indy 440-1 Ported Modern Cylinder Heads Flowed Porter Racing Heads Alum 342/- 2.25/1.81
No Pipe N/A 74/59 154/122 232/160 279/207 318/235 341/251 351/263 359/271 - - -
Indy 440-1 Ported R & J Alum N/A 2.25/1.81 N/A 76/58 154/117 223/170 278/209 328/245 363/270 368/287 378/301 - - -
Indy 440-1 Ported R & J Modified Alum 365/- 2.30/1.78 N/A 80/55 164/123 236/172 284/205 342/239 374/- 390/312 396/324 400/- - -
Manufacturer
Indy 440-1 Ported Scott Brown N/A 2.25/1.81
4.375
2" Pipe N/A 80/68 170/120 239/171 297/207 331/241 345/265 355/281 359/294 - - -
Indy 440-1 Ported N/A 2.30/1.78 N/A 80/55 164/122 233/169 294/206 342/237 374/274 390/304 396/324 400/334 - -
Indy 572-13 Full Porting 335/118 2.30/1.88 79 - 211/163 274/208 332/243 372/272 398/292 421/304 - - - -
Indy 572-13 Billy J Ported Alum 365/- 2.30/-
4.50 N/A 68/- 124/- 174/- 236/- 307/- 357/- 376/- 388/- - - -
Indy 572-13 Ported Modern Cylinder Head Alum 345/- 2.30/1.88
4.44 N/A 77/62 161/117 215/158 273/195 324/222 360/241 376/255 388/264 391/270 396/276 -
Indy 600-13 410/134 2.40/1.94 70 - 209/151 263/173 313/186 338/192 356/195 356/195 - - - -
Indy 600-13 Full Porting 425/140 2.40/1.94 70 - - 278/221 338/265 387/293 425/309 451/315 470/330 - - -
Indy 600-13X Full Porting 460/- 2.45/1.94 - - - - - - - - - 500/- - -
NRC Performance Alum 380/- 2.40/1.85
4.50
No Pipe 52-72 - - - - - - 485/330 - - - -
NRC Predator Alum N/A 2.40/1.85
4.50
No Pipe N/A 81/59 143/114 216/146 278/193 338/225 388/252 428/276 445/290 442/297 454/297 -
NRC Predator Bowl Blended Alum N/A 2.40/-
4.25 N/A - 165/- 240/- 307/- 360/- 402/- 430/- 453/- 470/- - -
NRC Hemi Style CNC Alum 450/- 2.45/1.85
4.530
No Pipe N/A 73/63 132/103 191/140 253/183 315/217 366/251 418/278 459/308 493/333 520/342 -
Manufacturer
Pro Comp Alum 265/78 2.25/1.88 72 71/54 146/104 208/150 251/187 274/213 287/230 296/239 295/246 - - -
Pro Comp Out of Box NPS Alum N/A 2.25/1.88
4.49
No Pipe N/A 69/54 135/107 197/149 249/179 275/197 291/211 304/217 312/217 - - -
Pro Comp CNC Alum N/A 2.20/1.81 N/A 75/55 151/118 223/168 279/215 315/251 341/276 354/292 362/303 - - -
Pro Comp Ported Modern Cylinder Heads Alum N/A 2.25/1.81
4.38
Pipe N/A 77/73 161/112 224/158 265/191 306/210 338/228 365/238 378/251 386/254 - -
World Torquer 440 Alum 260/106 2.19/1.81 75 - - - - - - - - - - -
World Pro 440 Alum 310/110 2.19/1.81 75 - - - - - - - - - - -
Zeeker Alum N/A 2.14/1.81 N/A - 137/119 193/147 249/186 306/228 346/252 375/264 370/269 - - -
Early HEMI COPYRIGHT © 2000-2017 Stan Weiss — World Wide Enterprises
Manufacturer
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Stage 6 heads [Re: DusterKid] #2418575
12/14/17 05:58 PM
12/14/17 05:58 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I have a set that I have used since 1998.
ZERO ISSUES .
I would jump on a good deal.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Stage 6 heads [Re: 6bblFLASH] #2418582
12/14/17 06:22 PM
12/14/17 06:22 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
ZERO ISSUES .
Buy a lottery ticket; you've already beaten the odds big-time if you had ZERO ISSUES with a set of MP Stage VI heads.
I've owned a couple of sets, both of which Dwayne had his hands on (or in) at one time or another. The chances of getting a pair that don't need something significant done to them (and there are too many possible issues for me to want to list right now, and this is from personal experience) are SLIM and NONE.
Not saying they can't work well ONCE all the sh!t is knocked outta them, but there are better quality -- and just as, if not more, effective -- options today that weren't around in 1998 when you bought yours, or 2000 when I bought my first set.
Re: Stage 6 heads [Re: fast68plymouth] #2418584
12/14/17 06:23 PM
12/14/17 06:23 PM
BradH Offline
BradH  Offline
+ pictures: http://www.forabodiesonly.com/mopar/threads/chapman-ported-stage-vi-heads-from-mp.393177/
Re: Stage 6 heads [Re: DusterKid] #2418595
12/14/17 06:43 PM
12/14/17 06:43 PM
AndyF Offline
AndyF  Offline
I bought a new set way back when they first came out but never used them. Ended up selling them on here to someone back around 2000 or so. I thought the super deep spring pocket was a very weird design.
Evidently Shep decided that the stock length valve was the most important thing to design around and he compromised everything else on the head just so he could use a stock length valve. No clue why he thought that was a good idea, guess it was just something that was super important to him.
Re: Stage 6 heads [Re: DusterKid] #2418647
12/14/17 08:23 PM
12/14/17 08:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
Even if they were as "perfect" as a set of stage 6's can be, the best flowing version ootb was the last, the "Zeus" castings...... Which still barely flowed 260 ootb.
Some of the earlier versions were hardly over 240, with equally awful exhaust flow.
If they didn't actually need something "fixed", and you just did the basics(valve job, flat mill, oil drain back mods), then did a nice bowl blend and bought all the parts........how cheap would the heads have to be to end up less expensive than a set of E street heads?
Of course....... I've never seen a set if stage 6's where that's all they needed....... So those would be unicorn-ish in my world.
And then, you won't really know you're out of the woods until you've run them for a while.
I've had several sets come thru the shop to have the seats that were starting to fall put replaced.
