440 top pad decode #2418353
12/14/17 06:31 AM
12/14/17 06:31 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
scope what say you?
Re: 440 top pad decode [Re: 6bblgt] #2418355
12/14/17 07:17 AM
12/14/17 07:17 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Well January 20 seems to be the assembly date...But did they skip the "I" year like they do in VIN's? If not does the M make it 1977? If they skip the "I" then my guess is 1976 EAD.
Lc is that Low Compression?
Re: 440 top pad decode [Re: 6bblgt] #2418373
12/14/17 10:11 AM
12/14/17 10:11 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Is this a trick question? I’ve never seen a post that Dan did not know the answer. Lol. My best quess is an over the counter block. Idk.
Re: 440 top pad decode [Re: fastmark] #2418519
12/14/17 03:49 PM
12/14/17 03:49 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
here's the 440's casting date & another engine with a similar font top pad stamping whistling
Re: 440 top pad decode [Re: 6bblgt] #2418552
12/14/17 05:03 PM
12/14/17 05:03 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
High Compression 426 Water Tested
Jan 3rd 1964?
Re: 440 top pad decode [Re: Cuda340] #2418555
12/14/17 05:06 PM
12/14/17 05:06 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
the top one 67 cast date and Jan 20th D=68 assembly date?
Re: 440 top pad decode [Re: Cuda340] #2418563
12/14/17 05:25 PM
12/14/17 05:25 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
work
Re: 440 top pad decode [Re: 6bblgt] #2419318
12/16/17 01:11 AM
12/16/17 01:11 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Originally Posted By 6bblgt
scope what say you?
I got lost with this one, seems to have taken a turn at Hemi Street and I missed that turn. Where are we now?
Re: 440 top pad decode [Re: A12] #2419355
12/16/17 02:59 AM
12/16/17 02:59 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
I believe:
M = marine
440 = cu.in.
L = left hand rotation
1-20 = engine assembly date 1/20/68 (3*23*67 block cast date)
D = 1968 model year
sideways "0" & little "c" shruggy
the Marysville, MI engine assembly plant was Chrysler Marine & also built Max Wedge & HEMI passenger car engines (similar top pad font & layout) this 440 was one of a pair, the other being right hand rotation - I'm trying to track that engine down to get a pic of the top pad.
Re: 440 top pad decode [Re: 6bblgt] #2419368
12/16/17 04:05 AM
12/16/17 04:05 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
I believe:
M = marine
440 = cu.in.
D = 1968 model year
Dan was that the normal EAD pad layout for all marine engines? Didn't Chrysler also make 440 engines for commercial applications and did those engines have a different assembly date pad layout than an automobile engine???
Re: 440 top pad decode [Re: A12] #2419383
12/16/17 04:56 AM
12/16/17 04:56 AM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
I'm not sure - it's the first Chrysler built big block "MARINE" engine I've seen the pad on
& not sure how the industrial engines are stamped shruggy
Re: 440 top pad decode [Re: 6bblgt] #2419853
12/17/17 02:10 PM
12/17/17 02:10 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Dan great information!
Matt
