torque converter issue
#2418095
12/13/17 06:49 PM
12/13/17 06:49 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
hi , there was someone on here recently with an issue where the converter wouldn't fit fully in ? was considering cutting the pump drive slots ? the search here is $hithouse . anyone remember ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: torque converter issue
[Re: tex013]
#2418154
12/13/17 09:17 PM
12/13/17 09:17 PM
tex013
Sydney,Australia
thanks Clanton , replied PM
Tex
[Re: tex013]
#2418625
12/14/17 07:53 PM
12/14/17 07:53 PM
tex013
Sydney,Australia
found the issue . had a anti balloon plate fitted - plate is hitting the pump . Converter sits out . No clearance to flexplate . 8ugger Guess that didn't save me $ after all
Tex
[Re: rickraw]
#2418692
12/14/17 09:30 PM
12/14/17 09:30 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
You could remove some material from the lugs. And that will effect the pilot length also and should be checked.
